Author Topic: 60hz synchronous motor on 50hz?  (Read 1528 times)
Offline paulj
Re: 60hz synchronous motor on 50hz? Yes !!!!
« Reply #20 on: December 31, 2021, 07:19:02 PM »
It's a success, I just started the engine using only two of the three wires.
Without capacitor it starts quite easily but not every time, the stator remains lukewarm without more, on the other hand as I expected, its speed of rotation has been modified.
as evidenced by this picture which was taken under a fluorescent tube at a shutter time of 1/50 s
the position of the axis (golden color) remains constant it is located between 9h and 3h I therefore deduce that this synchronous motor rotating at 3600 rpm in 60 hz, turns at about 3000 rpm in 50 hz.
regardless of the starting position of the rotor, each time the motor is started, the axis always seems synchronized with the frequency of the current, moreover the motor can even start at 50v 80v and even 150 volts (spot test) and this does not even change its speed of rotation.
For the history of the capacitor, I will therefore wait a bit because for the moment helping it to start is not a problem.
CONCLUSION, The 60 Hz synchronous motors are compatible in 50 Hz and are therefore perfectly suited to rotary spark gaps.
« Reply #21 on: December 31, 2021, 09:50:59 PM »
Applause!   Nice stroboscopic picture, without un-necessary effort.  I bet it would not work if the fluorescent light had modern "electronic" ballast.
Let's see if this link works. Fancy line-synchronized LED stroboscope, primitive modification of a shaded-pole induction motor.
https://www.flickr.com/photos/r_k_f/3688448113
« Last Edit: January 01, 2022, 01:06:32 AM by klugesmith »
Offline paulj
« Reply #22 on: January 01, 2022, 06:53:46 PM »
I actually tested on a compact fluorescent lamp which has a transitor ballast, it does not work at all
The strobe effect is even more visible with a discharge lamp.
however, i think the motor draws a little more current in 50hz
Did you make the video? it's fun when the motor is braked it stays synchronous but the mark is not in the same location so it is a hysteresis synchronous motor
« Reply #23 on: January 02, 2022, 01:17:37 AM »
It's not a hysteresis synchronous motor (though my collection includes that kind).
This one has an ordinary induction rotor with two flat places filed onto it.  I guess that makes it a "reluctance synchronous motor". (It would probably work better if the flats were bigger.)
In synchronous operation it has two stable rotation phase angles, 180 degrees apart.
We see both in the video.
I think that behavior would be fine in a SRSG, if the rotor has a conducting bar across whole diameter, and two fixed electrodes 180 degrees apart.
« Last Edit: January 02, 2022, 01:19:41 AM by klugesmith »
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
post Re: Hi! 811 A tesa coil
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
jpvvv123
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
paulj
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
paulj
Zbig
