Author Topic: GDT minimum frequency  (Read 236 times)
Offline costas_p
« on: November 21, 2021, 06:27:03 PM »
Hello all, I designed my version of a to247 h bridge based on loneocean's "80mm full bridge plus".
As GDT i choose to use the P0584NL part.
According to the datasheet it has a max value ET of 94 VuS.
And considering loneoceans equation for finding the lowest frequency you can run the GDT before core saturation: ET(Vus) = V_gatedrive * Duty Cycle/Frequency(Mhz)
So for 24v gate drive and 50% duty cycle I calculate lowest frequency to be ~127kHz
So, this 127kHz is the lowest possible frequency I can run the primary coil without saturating the GDT?
Also, loneoceans uses 50% duty cycle for his calculation, isn't supposed a DRSSTC to operate with duty cycle around 5%? What have I not understood correctly?
gdt datasheet in attachments
Papadakis Costas
Re: GDT minimum frequency
« Reply #1 on: November 22, 2021, 12:24:39 AM »
The duty cycle that matters is that of the drive waveform _during_ each RF burst.
Typically 50% or a little bit less.
For example, at 127 kHz, each half cycle is about 3.94 microseconds.   Multiply by 24 V, that gives you almost 95 volt-microseconds, which matches ET parameter in the datasheet you referred to.  You could run at half the frequency if the drive voltage were 12 V.
Numbers like 5% or 1% sound like ratio of RF burst length to interval between bursts.  That matters for heating, but not for GDT core saturation.
post Re: QCW questions
Today at 03:15:18 AM
January 26, 2022, 07:26:22 PM
January 26, 2022, 03:46:58 PM
post QCW questions
January 26, 2022, 10:49:14 AM
January 26, 2022, 05:17:03 AM
post Re: Mixing PID loops
January 26, 2022, 04:14:02 AM
January 25, 2022, 09:50:41 PM
January 25, 2022, 03:52:42 PM
January 25, 2022, 01:48:02 PM
January 25, 2022, 04:48:06 AM
January 25, 2022, 04:37:32 AM
January 24, 2022, 08:42:57 PM
January 24, 2022, 03:55:07 PM
January 24, 2022, 12:00:50 PM
January 24, 2022, 09:05:40 AM
post Mixing PID loops
January 24, 2022, 07:28:01 AM
January 24, 2022, 04:13:06 AM
January 24, 2022, 03:34:15 AM
