Author Topic: SSTC - Asymmetric waveform  (Read 919 times)
« on: April 29, 2021, 04:50:17 AM »
Hello guys!
I'm currently building a small SSTC in a half-bridge configuration. I'm using this simple circuit:
And my gate waveforms are pretty weird, I have never had this problem before.
10V/div 2us/div
10V/div 500ns/div
Is this a GDT problem? Or what could cause this duty cycle and voltage asymmetry?
Thanks for any help!
Marek Novotny
www.uhvlab.org
Re: SSTC - Asymmetric waveform
« Reply #1 on: April 29, 2021, 05:56:30 AM »
One issue is that the interrupter needs to force both driver-chip outputs low (or both high).  As is, C6 will be charged at the start of each pulse.
  • All the gear, no idea. UK
« Reply #2 on: April 29, 2021, 06:30:40 AM »
Weird, looks like core saturation in one direction. Are you really using 22v TVS diodes or zeners? Can you add a pull down resistor of about 10k between input of the gate drive IC's and ground, maybe it's not being shut off correctly.
Show pic of your circuit.
« Last Edit: April 29, 2021, 06:48:09 AM by John123 »
« Reply #3 on: April 29, 2021, 07:24:25 PM »
So I found out the problem is with the antenna itself. Once the signal from the secondary gets too weak, the antenna waveform gets asymmetric and it has some DC offset. The C5 cap should block the offset shouldn't it? Unfortunately I cannot place probe on the DC blocking capacitor, when I do it, the signal from the antenna gets totally lost. Probably the impedance of the probe is loading the circuit too much.
Would a 1k 2W resistor across the output of the TC4451/2 drivers solve this issue? RC = 1k * 220nF = 220us, should be enough to discharge the cap before the next interrupt comes in.
Good catch about the zeners, I actually forgot them. Now i placed 2 15V zener diodes anti-series. I have tried the 10k even 1k pull down resistors, it did not do anything to the circuit.
I have made a quick video to show this issue better. My setup is that I'm driving the secondary with signal generator. Connecting only the low pole of the secondary to the signal generator, where I feed it with 364kHz sine wave with 20V pk-pk amplitude.
No real feedback for now, I'm not powering the bridge yet.
Marek Novotny
www.uhvlab.org
« Reply #4 on: April 30, 2021, 04:36:41 AM »
Once the antenna signal is less than 6Vpp, duty cycle depends on the somewhat random tiny leakage currents of the UF4007 diodes.  There is nothing explicit to center the HC14 input voltage in the middle of its input threshold voltages.  The original SSTC version used germanium diodes.  Lower forward drop protects HC74 inputs better, and their higher leakage current likely biases the HC14 closer to center.  (A scope probe on the HC14 will likely force asymmetry, as it's 10meg input impedance is much lower than UF4007 leakage impedance.  The DC load of the probe is more of a problem than it's AC load.)
The driver chips are not being disabled.  One is output is forced high and the other output forced low by the AND gate.  A resistor will dissipate power, but will not fix anything.
Today at 04:13:06 AM
Today at 03:34:15 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
January 08, 2022, 09:05:41 AM
January 07, 2022, 10:20:10 PM
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
