Author Topic: How to power up gate driving Chip?  (Read 584 times)
Offline hashtala
« on: April 28, 2021, 03:17:04 PM »
Hello
I am building SSTC that will be running on rectified mains voltage for high arcs. I will be using a gate driver for IGBT's and will be providing control signal from microcontroller isolated using transformer winded on a ferrite ring.
However, the chip requires 12-20V DC to be turned on and it cannot be fed mains voltage unlike other drivers. I was wondering building a small SMPS with 15V output isolated with optocoupler from mains. Can I combine mains rectified voltages negative side with SMPS 15V negative and directly connect 15V from SMPS to chips power pin?
I am planning to use isolated DC-DC to power up microcontroller as well.
What could go wrong ?
  • All the gear, no idea. UK
Re: How to power up gate driving Chip?
« Reply #1 on: April 28, 2021, 09:04:12 PM »
What chip is it? Depending on how much current you need a capacitive dropper would probably suffice.
You probably could get away with it but I would put protection (such as a TVS diode) on the SSTC driver chips DC supply rails and maybe a 1kV diode in series between the 15v supply and driver chips, that way if the driver chip were to fail you wouldn't end up with mains across the output of the DC supply.
You'd need to treat the supply as live and all isolation needs to be rated for mains, they do this sort of thing in double insulated control panels (washers etc) where the electronics behind the plastic buttons on the front of the machine are all referenced to mains.
Will this SSTC and the microcontroller have any control buttons or dials? If so then they also need to be isolated for safety if they're user adjustable and are referenced to mains.
I've seen people use standard wall warts for the control side which they connected to the negative side of the mains referenced supply, they just kept the DC output wires away from everything else as the wire insulation isn't rated for mains.
« Last Edit: April 28, 2021, 09:15:10 PM by John123 »
post Mixing PID loops
Today at 07:28:01 AM
Today at 04:13:06 AM
Today at 03:34:15 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
January 08, 2022, 09:05:41 AM
January 07, 2022, 10:20:10 PM
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
