Author Topic: Single mosfet bifiliar gdt  (Read 2040 times)
Offline aie212
« on: April 11, 2021, 07:34:21 AM »
hey ..
I tried to make another sstc based on steve half bridge ..
but i want it to work only 1 mosfet .. for simplicity.
I also removed the 7414 and connected the secondary directly to the gate driver ..
well .. is it safe to connect the secondary directly to the gate driver ..
outside the schematic and it appears in the photo I add RC
Re: Single mosfet bifiliar gdt
« Reply #1 on: April 11, 2021, 06:50:56 PM »
That is a nice little driver chip with plenty of input hysteresis.  It should work just fine without 7414.
Offline aie212
« Reply #2 on: April 11, 2021, 10:49:01 PM »
thanks for the response Dave ..
but is it safe to connect directly to the secondary ..?
because with the antenna, I only got a 2cm small arc
« Reply #3 on: April 12, 2021, 03:33:06 AM »
If connecting to the bottom of the secondary winding without a current-transformer, you will need higher-current diodes than 1N60, perhaps  1N5819 (1A schottky).  Even a 3A schottky diode wouldn't hurt depending on your coil's secondary impedance.  (There is also a possibility that the secondary current could over-drive the 12V supply - feed more average current through the upper diode than the gate drive needs.  Haven't heard of that occurring in practice, but such is theoretically possible.)  Perhaps a 12V TVS diode across the 12V supply would be a good idea just in case.  Or use a current transformer to reduce the feedback current.
Offline aie212
« Reply #4 on: April 12, 2021, 01:51:36 PM »
good dave ..  :)
I've tried antenna and CT
but still a little bow that I got ..
until I connect directly ..
and got a long bow like in the video ..
currently i am using 1N4148 according to the attached schematic ..
I will try to replace the 1N5819 according to your suggestion ...
thank you for the advice and input  :D ;)
Offline aie212
« Reply #5 on: April 13, 2021, 09:08:57 AM »
final test
clamp diode change
GDT changes
« Reply #6 on: April 13, 2021, 06:46:21 PM »
Nice performing coil!
Offline aie212
« Reply #7 on: April 13, 2021, 07:11:06 PM »
thanks Dave ..
I thought .. for a mosfet the irfp460 might be the maximum
with a voltage of 180 volts from the 5ampere transformer voltage multiplier
I tried it for 30 minutes it just felt warm ..
and it's time to pack it well ..
some pieces of acrylic and led may be beautiful ..
but do not rule out if you suggest something
which can add a longer bow, without abandoning its simplicity ...
very grateful for the advice and attention ..
« Reply #8 on: April 13, 2021, 08:02:34 PM »
Appears to be working quite well.  I can't think of any changes to recommend.
Offline aie212
« Reply #9 on: April 13, 2021, 08:43:07 PM »
thank you dave ..
then .. I will start packing properly
« Reply #10 on: April 14, 2021, 07:39:14 PM »
I completely agree with Dave. Getting some 25'ish cm discharge from a 12cm secondary coil driven by a single IRF460 MOSFET is a great result and trying to improve on that length is most likely going to end up in shattered silicon :)
Great job on simplifying the SSTC, but how stable is it? Will it get more and more unstable at higher DC bus voltage? Like flickering discharges, change in discharge sound etc?
Offline aie212
« Reply #11 on: April 14, 2021, 09:19:51 PM »
Thank you Mads ..
right .. above 180volt start unstable .. mosfet like losing power
although sometimes there is a longer bow ...
I stopped at 180volt .. and I started tidying up
and put it on the table for decoration ..
happy for your correction ..
Offline MHV
« Reply #12 on: January 01, 2022, 06:39:05 PM »
Hi can you send me the original schematic please
« Reply #13 on: January 12, 2022, 05:45:26 PM »
aie,
It is a nice looking coil. I would like to build one to play with.
A few questions;
1) The MUR860 diode. The IRFP460 has a reverse voltage protection diode built in according to the data sheet. Why a second one?
2) The 05uF tank capacitor. Is it 0.05uF? That value looks good from a quick JavaTC run.
3) You appear to have four electrolytic caps to the one side of the input choke. What was your buss cap value?
4) There is a cluster of resistors and a blue capacitor attached to the driver board (in the photo). I don't see that in the schematic.
« Last Edit: January 12, 2022, 06:41:19 PM by alan sailer »
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
January 12, 2022, 06:18:15 PM
January 12, 2022, 03:29:04 PM
AFreshLad
January 12, 2022, 01:30:38 PM
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
January 08, 2022, 09:05:41 AM
January 07, 2022, 10:20:10 PM
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
AFreshLad
Zbig
