Author Topic: Filament voltage and current in and old valve rectifier  (Read 858 times)
Offline Alberto
« on: May 24, 2023, 06:39:23 PM »
Hello.
I got this nice old valve rectifier
In the glass is wirtten ATES 8008   made in Italy RCA license.
I have looked up in the internet and the filament values are 5V and 6,75 amps. Before triying it I measure the resistance of the filament and is around 0,1 ohms, and of course, when I connect it, when the voltage is 0,35V the current goes to 1,3 Amps and raising faaster than the voltage, so I don´t know how to turn on the filament.
Any advice?
Thank you!
Best regards
Offline DashApple
Re: Filament voltage and current in and old valve rectifier
« Reply #1 on: May 24, 2023, 07:23:01 PM »
The cold resistance of the tube will always be lower than its hot running resistance and due to this when you connect this to a voltage source you will experiance inrush.
If you set the voltage to 0.35V on a constant voltage source and wait you will see the current start to drop as the heater heats up and its resistance increases so you could manually do this over a period of time. The other option is if you connect it directly to a 5V  supply is to soft start it but placing a higher value resistor in series with the tube heater for 10 seconds or so then shorting this out with a relay or such, this limits the current to something you can pick, somehere around the expect hot heater resistance would be a good start.
In this case with 5V @ 6.75A the heater resistance is around 0.74 ohms when hot, something like a 1 Ohm soft start resistor would do but bear in mind it will be dissipating 25W or so at startup. There are also solid state soft starts based on MOSFETs on the web too, Though a relay / resistor and switch is an option as above.
Offline Alberto
« Reply #2 on: May 24, 2023, 07:53:49 PM »
Thank you.
I have tried rising the voltage slowly to maintain the filament at 6,25 amps and it took almost 10 minutes to increase the reistance. I give up when the voltage was around  3,6 volts.
But yes, it works and I really want to know if it work.
Offline Twospoons
« Reply #3 on: May 25, 2023, 03:08:58 AM »
Exceeding rated current at power-on is normal for a filament. The  6A @5V  spec is for steady-state, not an absolute limit.  If you really want to soft-start your filament you could limit the current to about 12A, with a voltage limit set to 5V.
Offline Alberto
« Reply #4 on: May 25, 2023, 10:02:31 AM »
Thank you!
And other question, is rated to 10Kv and 1,25 amps. But, with voltage I have to apply in anothe and cathode to be able to measure some corrent?
« Last Edit: May 25, 2023, 09:58:35 PM by Alberto »
Today at 04:12:52 AM
Today at 03:22:21 AM
post Re: Success!!!
June 15, 2024, 09:03:06 PM
post Success!!!
Terry
June 15, 2024, 08:29:43 PM
post Re: Benjamin's DRSSTC3
June 15, 2024, 05:38:36 AM
Jj
June 15, 2024, 03:09:41 AM
June 15, 2024, 01:53:07 AM
June 15, 2024, 01:07:30 AM
June 15, 2024, 12:45:22 AM
June 14, 2024, 10:41:03 PM
June 14, 2024, 10:20:00 PM
June 14, 2024, 09:47:48 PM
June 14, 2024, 09:40:33 PM
June 14, 2024, 07:44:12 AM
June 14, 2024, 05:21:55 AM
June 14, 2024, 03:24:43 AM
June 14, 2024, 03:13:44 AM
June 14, 2024, 02:27:06 AM
June 14, 2024, 01:56:58 AM
June 13, 2024, 11:21:46 PM
post Re: Bigger sparks?...
Teslaventje
June 13, 2024, 08:50:56 PM
June 13, 2024, 07:43:37 PM
June 13, 2024, 04:52:08 PM
June 13, 2024, 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
June 12, 2024, 10:23:08 PM
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
[Static Electricity]
June 12, 2024, 06:57:13 PM
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
vK
June 12, 2024, 03:42:18 AM
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
June 09, 2024, 05:44:29 PM
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
June 08, 2024, 05:38:14 AM
post Interrupter for SSTC
June 08, 2024, 12:47:47 AM
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
June 07, 2024, 05:08:00 AM
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
June 05, 2024, 11:11:17 PM
June 05, 2024, 10:18:57 PM
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
June 05, 2024, 08:46:53 PM
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
June 05, 2024, 01:42:04 AM
June 04, 2024, 10:31:58 PM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
June 02, 2024, 04:51:58 PM
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
June 01, 2024, 08:22:28 PM
June 01, 2024, 03:56:53 AM
Terry
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
