Author Topic: Help With Filament Supply For X-Ray Tube  (Read 195 times)
Offline Achtung
« on: May 21, 2023, 04:40:53 PM »
Hello I am constructing my own X-ray machine and I need help with the filament supply. So far I have built my own high voltage supply and filament supply for my tube(https://www.alibaba.com/product-detail/X-Ray-generator-Glass-Electronics-Baggage_60785041349.html
), and I have been able to produce small bursts of X-rays. Unfortunately, the reason why it runs for only a short period of time is that it renders the filament supply inoperable. Specifically there is a computer psu/switching mode power supply that blows up whenever I turn on the high voltage and trips the breakers to my room. This computer psu is only to input 12V into a voltage regulator/lm338 that then steps it down to a smaller voltage for the filament of the tube. I am unsure why the computer psu is blowing up but I have a hunch that I haven't properly grounded something. I would appreciate any insight on this. Thank you.
Re: Help With Filament Supply For X-Ray Tube
« Reply #1 on: May 21, 2023, 05:40:37 PM »
Let's see a more complete schematic.   The computer PSU and HV power supply each have at least four connections, maybe five.   Don't dismiss the AC power and grounding wires as not relevant, until you are more experienced.
Pictures of the power supplies would be an easy way to add information.
Offline Luca c.
« Reply #2 on: May 21, 2023, 09:56:31 PM »
Hi, if the PSU transistor blows, then I am pretty sure you are encountering the same problem I had a short time ago, the problem was grounding.
The solution was earth-grounding (so connecting the negative side of everything to the same ground that then is connected to the building earth) so I connected the PSU and the voltage regulator negative to the earth of the PSU, (in my PSU only the chassis was grounded)after this all the problem with static electricity (the voltage regulator screen going mad), and the transistor blowing, disappeared.
You can find more information here: https://highvoltageforum.net/index.php?topic=2449.msg18037#msg18037 .
Just out of curiosity, what type of HV power supply are you using?
Offline Achtung
« Reply #3 on: May 22, 2023, 01:10:35 PM »
Hello, that does seem like the problem. I haven't yet grounded the supply in the way in which you described so I will have to report back and see if it still blows up. Just to add more information, I have updated the circuit to show the supply connections. The high voltage supply is a 15-stage Cockcroft–Walton multiplier, and the input voltage comes from an AC transformer that outputs around 2.2 kilovolts. I have driven the AC transformer using a commercial ZVS driver which is powered by a 12-volt lead acid battery. As for the computer psu, I just connected the AC cable and the output DC voltage to the voltage regulator.
June 09, 2023, 05:24:42 AM
7824c5a4
June 09, 2023, 03:08:12 AM
June 09, 2023, 02:43:23 AM
June 08, 2023, 03:28:43 AM
June 08, 2023, 01:36:47 AM
June 07, 2023, 10:34:32 AM
June 07, 2023, 05:04:43 AM
June 06, 2023, 11:16:55 AM
June 06, 2023, 07:05:39 AM
post Re: A few questions
June 05, 2023, 01:41:45 AM
June 05, 2023, 01:38:02 AM
ako
June 05, 2023, 01:04:41 AM
June 05, 2023, 12:55:10 AM
June 04, 2023, 10:25:53 PM
YSPACE Labs
June 04, 2023, 09:04:00 PM
June 04, 2023, 04:17:14 PM
June 04, 2023, 01:20:51 PM
June 04, 2023, 04:09:52 AM
June 04, 2023, 03:23:08 AM
ako
June 04, 2023, 02:20:40 AM
June 04, 2023, 12:13:41 AM
Boilerbots
June 03, 2023, 11:27:50 PM
NickyLee
June 03, 2023, 09:57:35 PM
June 03, 2023, 08:16:03 PM
June 03, 2023, 07:00:02 AM
June 03, 2023, 06:24:39 AM
June 03, 2023, 05:31:49 AM
June 03, 2023, 04:40:21 AM
breezetix
June 03, 2023, 02:13:24 AM
June 02, 2023, 11:11:58 PM
June 02, 2023, 10:21:50 PM
June 02, 2023, 09:06:34 PM
June 02, 2023, 08:31:37 PM
June 02, 2023, 07:19:37 PM
June 02, 2023, 06:55:39 PM
June 02, 2023, 06:34:00 PM
June 02, 2023, 05:27:03 PM
nsled
June 02, 2023, 05:16:15 PM
June 02, 2023, 04:38:17 PM
nsled
June 02, 2023, 04:11:41 PM
June 02, 2023, 05:52:52 AM
June 02, 2023, 05:20:44 AM
June 02, 2023, 04:19:51 AM
June 02, 2023, 03:53:33 AM
June 02, 2023, 03:17:52 AM
ako
June 02, 2023, 02:33:51 AM
June 01, 2023, 09:34:26 PM
June 01, 2023, 08:39:13 PM
ako
June 01, 2023, 08:29:30 PM
June 01, 2023, 07:39:52 PM
June 01, 2023, 07:32:38 PM
ako
June 01, 2023, 02:57:06 PM
June 01, 2023, 07:41:02 AM
Boilerbots
June 01, 2023, 07:11:05 AM
post Re: Bridge output
June 01, 2023, 04:52:33 AM
June 01, 2023, 04:27:21 AM
June 01, 2023, 04:21:42 AM
June 01, 2023, 04:18:52 AM
June 01, 2023, 02:05:59 AM
June 01, 2023, 12:26:35 AM
nsled
May 31, 2023, 06:44:47 PM
May 31, 2023, 04:31:36 AM
May 31, 2023, 04:25:19 AM
Manz
May 31, 2023, 01:27:17 AM
May 31, 2023, 01:14:49 AM
May 30, 2023, 11:44:22 PM
ElectroNex
May 30, 2023, 11:21:52 PM
Felix M.
May 30, 2023, 11:20:23 PM
ElectroNex
May 30, 2023, 11:06:42 PM
Felix M.
May 30, 2023, 11:03:31 PM
Manz
May 30, 2023, 10:19:14 PM
May 30, 2023, 09:52:24 PM
ElectroNex
May 30, 2023, 09:22:10 PM
May 30, 2023, 09:19:37 PM
ElectroNex
May 30, 2023, 08:48:34 PM
ElectroNex
May 30, 2023, 08:41:34 PM
Felix M.
May 30, 2023, 08:30:51 PM
ElectroNex
May 30, 2023, 08:15:12 PM
Felix M.
May 30, 2023, 08:02:34 PM
ElectroNex
May 30, 2023, 06:36:54 PM
ElectroNex
May 30, 2023, 06:35:22 PM
Felix M.
May 30, 2023, 06:32:46 PM
May 30, 2023, 04:05:24 PM
ElectroNex
May 30, 2023, 12:48:19 PM
May 30, 2023, 11:11:38 AM
ako
May 30, 2023, 10:43:53 AM
May 30, 2023, 04:58:50 AM
May 30, 2023, 04:54:19 AM
May 30, 2023, 04:28:11 AM
May 30, 2023, 04:14:20 AM
May 30, 2023, 04:06:53 AM
NickyLee
May 30, 2023, 04:05:35 AM
May 30, 2023, 03:58:51 AM
May 30, 2023, 02:04:44 AM
May 30, 2023, 01:58:34 AM
May 30, 2023, 01:48:06 AM
May 29, 2023, 10:44:47 PM
May 29, 2023, 10:40:20 PM
Kizmo
May 29, 2023, 10:31:11 PM
RubyWindow
May 29, 2023, 09:11:37 PM
