Author Topic: Half-Bridge SSTC Failed  (Read 1386 times)
Re: Half-Bridge SSTC Failed
« Reply #20 on: May 24, 2023, 03:46:37 AM »
Or I just use Fast recovery rectifier diode to replace those schottkys ?
That should work well.  Or TVS diodes across schottkys.  Whatever is easiest for you.
Offline NyaaX_X
« Reply #21 on: May 25, 2023, 05:17:49 AM »
OK Thank you Dave ~ Then I go in this way keep simulating
« Last Edit: May 25, 2023, 05:19:59 AM by NyaaX_X »
Offline NyaaX_X
« Reply #22 on: May 25, 2023, 01:49:04 PM »
Here I want to build a simple bridge rectifier. But I see that if I place a extra electrolytic capacitor parallel to two bridge polarized electrolytic capacitors, there will be some reverse current flow into them (bridge capacitors). But the voltage is still positive cross them. Is that harmful to the electrolytic capacitors?
« Last Edit: May 25, 2023, 02:22:53 PM by NyaaX_X »
« Reply #23 on: May 25, 2023, 07:34:15 PM »
I don't think this forum is an appropriate place for basic electronics questions.  However, I'll provide a hint to this one:  Consider any capacitor, electrolytic or not.  What would happen if current was always one polarity?  Try that in simulation.
Offline NyaaX_X
« Reply #24 on: May 26, 2023, 07:36:10 AM »
My fault . Stupid question stuck my brain... Yes charging and discharging current in capacitors are in two direction. I was thinking why my two capacitor getting hot after mosfets died. Those two capacitor is always push and pull a high value of current before I cutdown the power supply? I guess.
Here my question is turning into "if 200V polarized capacitors misconnected to 125V AC for few seconds. There's some chance won't break those capacitors?"
« Last Edit: May 26, 2023, 08:26:58 AM by NyaaX_X »
« Reply #25 on: May 26, 2023, 06:58:41 PM »
Simulate that circuit, just the AC input diodes and caps, with a shorted load.  Check capacitor voltages and currents.
125Vac for long will cause the capacitors to physically explode due to internal steam generation.  For shorter durations, capacitor will likely degrade, especially with higher ESR than before, and perhaps higher leakage current.
Offline NyaaX_X
« Reply #26 on: May 27, 2023, 04:09:09 AM »
Thank you Dave for keep replying my low level questions. Wish you always have a nice day.
I have simulated that so I wondering why they didn't blow up, or even nothing blow up. I expected mosfets or this two capacitor will crack or smoking but the only thing was a hissing sound then I cut the power. The value of capacitors do not change. Maybe the ESR will increase after the accident? I don't have implement to measure this. According to there're something heating I think I was lucky that cutting the power before anything blow up?
« Reply #27 on: May 30, 2023, 02:04:44 AM »
Hissing sound was probably from electrolytic capacitors venting steam.  Electrolytic capacitors are usually designed to have an intentional weak spot in the case top or bottom seal, something that will break open and vent steam to avoid explosion.  If you had left power applied, steam might have been generated too fast for the vent and made an explosion.  If my guess is correct about venting, ESR will be higher.  ESR will likely continue to rise over time unless vent self-seals again after venting.  Many don't reseal.
Offline NyaaX_X
« Reply #28 on: May 30, 2023, 04:14:20 AM »
The only things broken are mosfets, and I can't confirm which component is heating. Sorry for wasting your time. I will take care of that next time. But I think I will make half-bridge and power supply separately.
By the way here I post some images of my layout of the half bridge. Maybe give me some advices if have time~ Thank you very much.
« Last Edit: May 30, 2023, 04:26:17 AM by NyaaX_X »
« Reply #29 on: May 30, 2023, 04:28:11 AM »
Do you have a second ECB layer for ground plane?  Two-layer ECBs can have much lower parasitic inductance compared to single-layer ECBs, presuming reasonable layout.  May be sufficient exactly as is.  Adding a ground plane (plane connected to - supply (or + supply) would be a big improvement.
Offline NyaaX_X
« Reply #30 on: May 30, 2023, 04:54:19 AM »
Wow OK here I only draw one layer. I was thinking to make two same shape layput in two layout. So now I may create the other layout cover with power + -. Maybe the upper half with negtive and lower with postive? According to my image.
« Last Edit: May 30, 2023, 05:09:51 AM by NyaaX_X »
« Reply #31 on: June 01, 2023, 04:21:42 AM »
Rather, I was suggesting that the other layer be only one supply voltage or the other, not both.  And cover the entire other layer (obviously with clearance for through-holes).
Offline NyaaX_X
« Reply #32 on: June 01, 2023, 07:41:02 AM »
OK I connect it with power supply (-) but I don't know which is better for my gate signal and protection.
« Reply #33 on: June 01, 2023, 07:39:52 PM »
Your second image is best.  To be a perfectionist like me, you could remove a tiny bit of the Vbus- plane under high-side IGBT gate trace.  That is the only place where parasitic capacitance to Vbus- could be an issue.  Low-side gate is referenced to Vbus- (low side emitter), so Vbus- plane under there is good.
Offline NyaaX_X
« Reply #34 on: June 02, 2023, 04:19:51 AM »
Well... My bad. I love a symmetry one. So I make two new case of it.
« Reply #35 on: June 02, 2023, 05:20:44 AM »
Either will be fine.  Circuit itself is not symmetric.  IGBTs are not complimentary (not like one PFET and one NFET).  That is why ideal layout is not symmetric.
Offline NyaaX_X
« Reply #36 on: June 02, 2023, 05:52:52 AM »
I will use MOSFET.. what do that mean "complimentary" I have no idea.
« Reply #37 on: June 02, 2023, 06:34:00 PM »
I am not recommending changing to FETs.  Even if you did change, N-channel MOSFETs (NFETs) have better specifications than their compliments, PFETs.  So most H-bridges that do use FETs use all NFETs, so are just as asymmetric as IGBT H-bridges.
BTW, look at typical DRSSTC drivers such as UD2.7.  The final stage driving GDT is complimentary, pairs of one NFET and one PFET for each GDT primary lead.
Offline NyaaX_X
« Reply #38 on: June 03, 2023, 04:40:21 AM »
Sorry maybe I didn't express clearly. I am makeing a simple N-mosfet half bridge single resonant SSTC. And the frequency will be too high for IGBTs.. The "symmetric" is about the ECB shape.. Not for circuit like pmos nmos inverter or something. If I exposure two pair of GDT to mosfet wiring from Vbus ECB covering. Will the leakage inductance like that make a trouble?
« Reply #39 on: June 03, 2023, 06:24:39 AM »
Probably fine.  I'm just a perfectionist, so try to optimize everything.
June 09, 2023, 05:24:42 AM
7824c5a4
June 09, 2023, 03:08:12 AM
June 09, 2023, 02:43:23 AM
June 08, 2023, 03:28:43 AM
June 08, 2023, 01:36:47 AM
June 07, 2023, 10:34:32 AM
June 07, 2023, 05:04:43 AM
June 06, 2023, 11:16:55 AM
June 06, 2023, 07:05:39 AM
post Re: A few questions
June 05, 2023, 01:41:45 AM
June 05, 2023, 01:38:02 AM
ako
June 05, 2023, 01:04:41 AM
June 05, 2023, 12:55:10 AM
June 04, 2023, 10:25:53 PM
YSPACE Labs
June 04, 2023, 09:04:00 PM
June 04, 2023, 04:17:14 PM
June 04, 2023, 01:20:51 PM
June 04, 2023, 04:09:52 AM
June 04, 2023, 03:23:08 AM
ako
June 04, 2023, 02:20:40 AM
June 04, 2023, 12:13:41 AM
Boilerbots
June 03, 2023, 11:27:50 PM
NickyLee
June 03, 2023, 09:57:35 PM
June 03, 2023, 08:16:03 PM
June 03, 2023, 07:00:02 AM
June 03, 2023, 05:31:49 AM
breezetix
June 03, 2023, 02:13:24 AM
June 02, 2023, 11:11:58 PM
June 02, 2023, 10:21:50 PM
June 02, 2023, 09:06:34 PM
June 02, 2023, 08:31:37 PM
June 02, 2023, 07:19:37 PM
June 02, 2023, 06:55:39 PM
June 02, 2023, 05:27:03 PM
nsled
June 02, 2023, 05:16:15 PM
June 02, 2023, 04:38:17 PM
nsled
June 02, 2023, 04:11:41 PM
June 02, 2023, 03:53:33 AM
June 02, 2023, 03:17:52 AM
ako
June 02, 2023, 02:33:51 AM
June 01, 2023, 09:34:26 PM
June 01, 2023, 08:39:13 PM
ako
June 01, 2023, 08:29:30 PM
June 01, 2023, 07:32:38 PM
ako
June 01, 2023, 02:57:06 PM
Boilerbots
June 01, 2023, 07:11:05 AM
post Re: Bridge output
June 01, 2023, 04:52:33 AM
June 01, 2023, 04:27:21 AM
June 01, 2023, 04:18:52 AM
June 01, 2023, 02:05:59 AM
June 01, 2023, 12:26:35 AM
nsled
May 31, 2023, 06:44:47 PM
May 31, 2023, 04:31:36 AM
May 31, 2023, 04:25:19 AM
Manz
May 31, 2023, 01:27:17 AM
May 31, 2023, 01:14:49 AM
May 30, 2023, 11:44:22 PM
ElectroNex
May 30, 2023, 11:21:52 PM
Felix M.
May 30, 2023, 11:20:23 PM
ElectroNex
May 30, 2023, 11:06:42 PM
Felix M.
May 30, 2023, 11:03:31 PM
Manz
May 30, 2023, 10:19:14 PM
May 30, 2023, 09:52:24 PM
ElectroNex
May 30, 2023, 09:22:10 PM
May 30, 2023, 09:19:37 PM
ElectroNex
May 30, 2023, 08:48:34 PM
ElectroNex
May 30, 2023, 08:41:34 PM
Felix M.
May 30, 2023, 08:30:51 PM
ElectroNex
May 30, 2023, 08:15:12 PM
Felix M.
May 30, 2023, 08:02:34 PM
ElectroNex
May 30, 2023, 06:36:54 PM
ElectroNex
May 30, 2023, 06:35:22 PM
Felix M.
May 30, 2023, 06:32:46 PM
May 30, 2023, 04:05:24 PM
ElectroNex
May 30, 2023, 12:48:19 PM
May 30, 2023, 11:11:38 AM
ako
May 30, 2023, 10:43:53 AM
May 30, 2023, 04:58:50 AM
May 30, 2023, 04:06:53 AM
NickyLee
May 30, 2023, 04:05:35 AM
May 30, 2023, 03:58:51 AM
May 30, 2023, 01:58:34 AM
May 30, 2023, 01:48:06 AM
May 29, 2023, 10:44:47 PM
May 29, 2023, 10:40:20 PM
Kizmo
May 29, 2023, 10:31:11 PM
RubyWindow
May 29, 2023, 09:11:37 PM
