Author Topic: QCW questions  (Read 19588 times)
Offline Rafft
Re: QCW questions
« Reply #180 on: March 25, 2023, 04:00:17 PM »
David
I have placed all my electronics 'in a box' except for the dc-dc boost, 16v8 battery -> 330vdc. I have tried placing the C=23uF(4u7 5parallel mkp x2) on the inverter full-bridge side. It serves as the C from buck LC. Inductor is around 4inches(end to end) wire connection from inductor L -> full-bridge. And also serves as full-bridge snubber.
In my head, its 'calculated' as a snubber of single 4u7 only? Or as a whole ~23uF? Is it ok though this kind of arrangement? Though ive also soldered a single 4u7(same make/type) of the 5p placed underneath the board. Just making sure(?) I still have a proper 'snubber'  on the bridge.. So in total, C on bridge is 4u7 6p. With the single 4u7 wired (top of board)to be 'as close as possible to ecb(as snubber low lead inductance).
Added are some scope shots during phase lead tuning.
Yellow = bridge output
Magenta = Iprim
Single shot of Iprim, with ch1 probe physically detached from scope.it affects the other channel/s reading. Bottom shots show as 'tuned' , by getting a cleaner Iprim and not minding of 'spike' at bridge output
« Last Edit: March 25, 2023, 04:13:54 PM by Rafft »
SGTC / SSTC / DR-SSTC / QCW
Re: QCW questions
« Reply #181 on: March 25, 2023, 05:33:39 PM »
Presuming I understand correctly, this is ideal.  Wire inductance between inductor and caps is no issue at all.  Just adds a tiny bit to buck inductance.  BTW, I have ~20inches of wire from buck inductor to H-bridge on my new QCW experiment platform, with caps on H-bridge board.
All looks good.
Offline Rafft
Re: QCW questions
« Reply #182 on: May 18, 2023, 02:20:31 AM »
David
For reference I will use MBQ60T65PES
If I use IGBT internal diode(across CE), how do I determine its forward current? Can I safely assume x10 current to be its peak(qcw use)? Same as whats done/calculated on real fast diodes.
What do I look for in the datasheet?  Should I ask for more questions im not aware of?
Is this 'diode' affected by switching speed?
Pls take note IGBT gate=gnd.
Re: QCW questions
« Reply #183 on: May 18, 2023, 04:26:31 AM »
Spec. sheet for this part looks great.  However, I don't see any in normal electronics distribution.  Haven't since I first heard of this part.  No evidence of this, but I'd guess that any parts you purchase are counterfeit.  So no way to know actual spec's.
IGBT diodes generally can't handle 10x current.  Look at spec peak current, but even that is usually for only 1ms, shorter than QCW.
Yes, at least if you run buck inductor current in continuous mode, where current doesn't ramp all the way to 0 between pulses.  Most IGBT diodes will be fast enough.
Re: QCW questions
June 09, 2023, 05:24:42 AM
7824c5a4
June 09, 2023, 03:08:12 AM
June 09, 2023, 02:43:23 AM
June 08, 2023, 03:28:43 AM
June 08, 2023, 01:36:47 AM
June 07, 2023, 10:34:32 AM
June 07, 2023, 05:04:43 AM
June 06, 2023, 11:16:55 AM
June 06, 2023, 07:05:39 AM
post Re: A few questions
June 05, 2023, 01:41:45 AM
June 05, 2023, 01:38:02 AM
ako
June 05, 2023, 01:04:41 AM
June 05, 2023, 12:55:10 AM
June 04, 2023, 10:25:53 PM
YSPACE Labs
June 04, 2023, 09:04:00 PM
June 04, 2023, 04:17:14 PM
June 04, 2023, 01:20:51 PM
June 04, 2023, 04:09:52 AM
June 04, 2023, 03:23:08 AM
ako
June 04, 2023, 02:20:40 AM
June 04, 2023, 12:13:41 AM
Boilerbots
June 03, 2023, 11:27:50 PM
NickyLee
June 03, 2023, 09:57:35 PM
June 03, 2023, 08:16:03 PM
June 03, 2023, 07:00:02 AM
June 03, 2023, 06:24:39 AM
June 03, 2023, 05:31:49 AM
June 03, 2023, 04:40:21 AM
breezetix
June 03, 2023, 02:13:24 AM
June 02, 2023, 11:11:58 PM
June 02, 2023, 10:21:50 PM
June 02, 2023, 09:06:34 PM
June 02, 2023, 08:31:37 PM
June 02, 2023, 07:19:37 PM
June 02, 2023, 06:55:39 PM
June 02, 2023, 06:34:00 PM
June 02, 2023, 05:27:03 PM
nsled
June 02, 2023, 05:16:15 PM
June 02, 2023, 04:38:17 PM
nsled
June 02, 2023, 04:11:41 PM
June 02, 2023, 05:52:52 AM
June 02, 2023, 05:20:44 AM
June 02, 2023, 04:19:51 AM
June 02, 2023, 03:53:33 AM
June 02, 2023, 03:17:52 AM
ako
June 02, 2023, 02:33:51 AM
June 01, 2023, 09:34:26 PM
June 01, 2023, 08:39:13 PM
ako
June 01, 2023, 08:29:30 PM
June 01, 2023, 07:39:52 PM
June 01, 2023, 07:32:38 PM
ako
June 01, 2023, 02:57:06 PM
June 01, 2023, 07:41:02 AM
Boilerbots
June 01, 2023, 07:11:05 AM
post Re: Bridge output
June 01, 2023, 04:52:33 AM
June 01, 2023, 04:27:21 AM
June 01, 2023, 04:21:42 AM
June 01, 2023, 04:18:52 AM
June 01, 2023, 02:05:59 AM
June 01, 2023, 12:26:35 AM
nsled
May 31, 2023, 06:44:47 PM
May 31, 2023, 04:31:36 AM
May 31, 2023, 04:25:19 AM
Manz
May 31, 2023, 01:27:17 AM
May 31, 2023, 01:14:49 AM
May 30, 2023, 11:44:22 PM
ElectroNex
May 30, 2023, 11:21:52 PM
Felix M.
May 30, 2023, 11:20:23 PM
ElectroNex
May 30, 2023, 11:06:42 PM
Felix M.
May 30, 2023, 11:03:31 PM
Manz
May 30, 2023, 10:19:14 PM
May 30, 2023, 09:52:24 PM
ElectroNex
May 30, 2023, 09:22:10 PM
May 30, 2023, 09:19:37 PM
ElectroNex
May 30, 2023, 08:48:34 PM
ElectroNex
May 30, 2023, 08:41:34 PM
Felix M.
May 30, 2023, 08:30:51 PM
ElectroNex
May 30, 2023, 08:15:12 PM
Felix M.
May 30, 2023, 08:02:34 PM
ElectroNex
May 30, 2023, 06:36:54 PM
ElectroNex
May 30, 2023, 06:35:22 PM
Felix M.
May 30, 2023, 06:32:46 PM
May 30, 2023, 04:05:24 PM
ElectroNex
May 30, 2023, 12:48:19 PM
May 30, 2023, 11:11:38 AM
ako
May 30, 2023, 10:43:53 AM
May 30, 2023, 04:58:50 AM
May 30, 2023, 04:54:19 AM
May 30, 2023, 04:28:11 AM
May 30, 2023, 04:14:20 AM
May 30, 2023, 04:06:53 AM
NickyLee
May 30, 2023, 04:05:35 AM
May 30, 2023, 03:58:51 AM
May 30, 2023, 02:04:44 AM
May 30, 2023, 01:58:34 AM
May 30, 2023, 01:48:06 AM
May 29, 2023, 10:44:47 PM
May 29, 2023, 10:40:20 PM
Kizmo
May 29, 2023, 10:31:11 PM
RubyWindow
May 29, 2023, 09:11:37 PM
