Author Topic: Driving Nixie-tubes with arduino  (Read 3909 times)
Offline RocketScienceSmurf
« on: December 03, 2019, 09:04:42 AM »
There are many circuits out there using arduino and some extra components to drive nixie tubes but I am trying to figure out a cheap way that don't take up too much space so I would like to use ULN2003 if possible.
When looking at the IN12 Nixie tube drive voltage seem to be around 145V DC and recommended current is 2,5-3,5mA. Do these thing behave like a resistor? Can I assume each digit is like a ~48k resistor? If so I should be able to use a bussed resistor array with 7 pcs of 22k resistor to make sure the ULN2003 is never exposed to more than ~45V (50v is ABSOLUTE MAX according to the data sheet).
Assuming that the internal DC resistance of each digit is never LOWER than ~48k I should be safe right?
The other potential problem is the current when the digit is NOT lit. There will still be close to 2mA running through each digit. Will they be dark or will the probably be dimly lit?
Re: Driving Nixie-tubes with arduino
« Reply #1 on: December 03, 2019, 10:45:58 AM »
Nixie tube digits are not even close to constant-resistance devices.
The normal glowing state is much like a LED: small, and sometimes negative, voltage change with large current change.  There are 10s of volts of hysteresis at the off/on transition.
A digit with 2 mA will be seen as plenty On.
A Google search for ULN2003 Nixie revealed some circuits that work.
Your mission is to learn how they work.
« Last Edit: December 03, 2019, 11:09:37 AM by klugesmith »
« Reply #2 on: December 03, 2019, 01:24:00 PM »
When I built a Nixie tube clock I used common resistors for the Cathodes. I used high voltage NPN transistors MPSA42 to interface the 5V logic to driving the individual numbers.
http://kaizerpowerelectronics.dk/general-electronics/nixie-tube-clock/
« Reply #3 on: December 03, 2019, 02:14:00 PM »
Perhaps SN75468 with its 100V rating would work instead? A transistor array instead of using discrete transistors would save space and make it much easier to connect.
« Reply #4 on: December 03, 2019, 07:54:08 PM »
the best way is to find some 74141 ics that were designed to drive nixies direct from TTL logic
Today at 05:24:19 AM
Tesla Junior
Today at 04:24:09 AM
Michelle_
Today at 04:20:35 AM
Bobakman
Today at 04:05:28 AM
Today at 04:03:54 AM
Michelle_
Today at 03:19:19 AM
Today at 03:09:29 AM
unrealcrafter2
Today at 01:47:37 AM
Bobakman
Today at 12:19:21 AM
April 18, 2024, 11:33:01 PM
Bobakman
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
unrealcrafter2
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
unrealcrafter2
April 18, 2024, 09:50:09 PM
Michelle_
April 18, 2024, 09:15:55 PM
post Re: 100kHz CM300 gate resistor choice
April 18, 2024, 08:50:49 PM
unrealcrafter2
April 18, 2024, 08:11:27 PM
April 18, 2024, 07:28:05 PM
Bobakman
April 18, 2024, 06:30:30 PM
Michelle_
April 18, 2024, 06:03:57 PM
Michelle_
April 18, 2024, 05:26:13 PM
April 18, 2024, 04:03:38 PM
Michelle_
April 18, 2024, 02:56:40 PM
post Re: DIY induction guns? (warning:long)
April 18, 2024, 06:17:15 AM
Michelle_
April 18, 2024, 05:46:07 AM
April 18, 2024, 05:18:31 AM
April 18, 2024, 04:34:52 AM
April 18, 2024, 04:11:53 AM
Michelle_
April 18, 2024, 04:02:44 AM
April 18, 2024, 03:35:52 AM
April 17, 2024, 11:54:05 PM
post 100kHz CM300 gate resistor choice
April 17, 2024, 11:37:16 PM
post Re: Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
post Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
Michelle_
April 16, 2024, 06:18:40 PM
Michelle_
April 16, 2024, 06:14:53 PM
unrealcrafter2
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
unrealcrafter2
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
Michelle_
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
