Author Topic: Ferrite core test (low output?)  (Read 1318 times)
Offline nielsquake
« on: March 22, 2022, 07:04:41 PM »
Hey guys :D long time since I posted on here since I had been busy with school and unable to work on my HV projects but recently I got into it again by using some of my old ferrite cores from old TV's and wind my own secondary on a 3D printed frame. The one I made with a ferrite from a tv worked really well but I found out I had a bigger ferrite laying around from the old filament transformer for an XRay tube. I made a secondary with many more turns (I made quite a few that seemed to have failed for some reason) but it never even came close to the output on the smaller one made from the old TV flyback.  Here is a pic from the ferrite in the xray tank
As you can see it is huge, it had small plastic discs in between for the airgap. I think it was like 0.5mm thick plastic so only tiny gap.
IDK if they use other material for high current transformers but look at this comparison powering it from the same supply and driver compared to the one made with the TV flyback core.
TV one:
Xray one:
The tv one was also gapped I think but I just used a bit of tape for that, probably at around 1mm
Does anyone know why it won't work better, could it be the ferrite material or is it more likely I messed something else up. Both of em have a 3+3 centertapped primary wound in the same direction as the secondary. I dont know why the colors of the plasma ball are so different but the output in the second vid is lower for sure when drawing arcs aswell.
« Last Edit: March 22, 2022, 07:08:23 PM by nielsquake »
Offline nielsquake
Re: Ferrite core test (low output?)
« Reply #1 on: March 22, 2022, 07:07:45 PM »
also its driven by cheap ebay zvs board.
Offline nielsquake
« Reply #2 on: March 22, 2022, 08:16:26 PM »
I think this was the original primary for the fillament transformer
Doesn´t seem like the turn ratio for the secondary is much higher. I´d say 1/2 or 1/3 idk. Maybe this shows some info on what kind of ferrite it could be
« Reply #3 on: March 24, 2022, 02:19:55 AM »
There are many transformer parameters that are important, along with driver voltage and frequency and output load (plasma globe).  Could be too-high unloaded output voltage, with correspondingly high output impedance, which is loaded down too much by the globe.  Or could be the opposite or a different frequency or ...
I'd suggest measuring primary and secondary inductances of your transformers along with leakage inductance (inductance with opposite winding shorted).  Then run analog simulation (ie. LTSpice) with those parameters.  If you have access to a scope and signal generator and some capacitors, you can measure inductance manually if no LRC meter is available.
Today at 02:25:25 AM
Today at 01:39:11 AM
post Re: Plasma Toroid
Today at 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
Michelle_
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
Michelle_
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
Michelle_
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
Michelle_
May 12, 2024, 02:51:27 PM
Michelle_
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
Michelle_
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
Michelle_
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
Michelle_
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
May 10, 2024, 09:38:05 PM
Michelle_
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
Michelle_
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
Michelle_
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
Michelle_
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
Michelle_
May 09, 2024, 03:42:49 PM
Michelle_
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
Lasr8
May 09, 2024, 04:45:33 AM
May 09, 2024, 03:56:52 AM
Michelle_
May 09, 2024, 02:16:30 AM
Michelle_
May 09, 2024, 02:00:28 AM
unrealcrafter2
May 09, 2024, 12:48:57 AM
post Re: Capacitor Blowout
radioman
May 08, 2024, 09:04:54 PM
post Question about using mains power and variacs to power this circuit
Michelle_
May 08, 2024, 08:10:41 PM
Michelle_
May 08, 2024, 07:33:43 PM
unrealcrafter2
May 08, 2024, 07:33:31 PM
May 08, 2024, 01:31:28 PM
May 08, 2024, 06:41:48 AM
post Tesla coil amplitude dies after one corona discharge.
Simranjit
May 08, 2024, 05:42:07 AM
Michelle_
May 07, 2024, 06:46:16 PM
post What capacitor configuration to explode foil?
May 07, 2024, 03:51:32 PM
May 07, 2024, 03:20:23 PM
May 07, 2024, 11:00:00 AM
post Aluminum electrolytic capacitor ripple current issue
May 07, 2024, 06:07:48 AM
Michelle_
May 06, 2024, 04:43:19 PM
May 06, 2024, 04:26:44 PM
post Re: Feedback core for Tesla coil
May 06, 2024, 04:24:57 PM
May 06, 2024, 04:20:37 PM
post Feedback core for Tesla coil
Simranjit
May 06, 2024, 04:28:59 AM
May 06, 2024, 02:57:19 AM
May 06, 2024, 02:07:38 AM
Michelle_
May 05, 2024, 11:29:46 PM
May 05, 2024, 10:27:01 PM
May 05, 2024, 10:10:11 PM
Michelle_
May 05, 2024, 08:06:11 PM
post Re: Ferrite material for GDT SSTC/DRSSTC
May 05, 2024, 04:28:35 PM
Michelle_
May 05, 2024, 06:31:32 AM
post Re: Big Coil Build Log
May 05, 2024, 05:48:43 AM
thedark
May 05, 2024, 04:49:39 AM
thedark
May 05, 2024, 04:28:40 AM
May 05, 2024, 03:05:44 AM
May 05, 2024, 02:54:42 AM
post Ferrite material for GDT SSTC/DRSSTC
thedark
May 05, 2024, 02:21:54 AM
Michelle_
May 05, 2024, 01:46:25 AM
post Re: TVS diode vs RCD snubber for protect IGBT peak voltage
May 05, 2024, 12:26:38 AM
thedark
May 04, 2024, 10:48:10 PM
May 04, 2024, 10:40:15 PM
post TVS diode vs RCD snubber for protect IGBT peak voltage
thedark
May 04, 2024, 09:30:32 PM
May 04, 2024, 08:56:27 PM
May 04, 2024, 04:25:00 AM
May 04, 2024, 04:21:02 AM
May 04, 2024, 01:33:40 AM
May 04, 2024, 01:02:48 AM
May 03, 2024, 11:39:10 PM
May 03, 2024, 10:59:34 PM
markus
May 03, 2024, 09:59:22 AM
post What happened to ArcAttack?
rusirius
May 03, 2024, 02:34:36 AM
May 02, 2024, 05:18:56 AM
post Re: Adjustable High Voltage Electrostatic Precipitator Power Supply with 30KV 300W
dante
May 01, 2024, 10:06:40 PM
dante
May 01, 2024, 10:01:33 PM
post Re: Watercooling
May 01, 2024, 07:26:03 PM
Michelle_
May 01, 2024, 05:53:47 PM
May 01, 2024, 04:05:23 PM
post Re: X-ray generation from nixie bulbs?
May 01, 2024, 03:58:29 PM
May 01, 2024, 12:00:01 PM
