Author Topic: Schmitt trigger schematic question  (Read 175 times)
Offline Michelle_
« on: May 14, 2024, 09:45:38 PM »
So in the attached schematic I think both of the right facing triangle symbols are part of the same Schmitt inverter, the numbers are the pins; pin 2 is connected to pin 3. Is that right?
I'm assuming both of the triangles represent a channel of the Schmitt inverter, why is one channel going into another one then out? What's going on here exactly?
This is part of Steve Ward's SSTC5 schematic (https://www.stevehv.4hv.org/SSTC5/miniSSTCfnlsch.JPG) and the only part that I am not really following. I think the purpose of this is to convert the feedback from the antenna into a square wave.
Offline Benjamin Lockhart
Re: Schmitt trigger schematic question
« Reply #1 on: May 14, 2024, 11:00:00 PM »
Yes that's correct. 2 of the inverters are being used so the signal is inverted then uninverted again. You can actually omit the inverters though because the UCC gate drive ICs have hysteresis on the inputs already. Also I prefer to use current transformer secondary base feedback for SSTCs.
Here is the schematic of my small half bridge SSTC which is similar but very simplified and works great.
The schematic shows a 12V regulator for the gate drive supply but you could use 15V as well it would probably be better. The single UCC27425 works fine as long as you're only driving a half bridge with it. For a full bridge that requires twice the drive current I would use the 2 separate UCC chips.
You can see the little coil here. It does about 6" sparks but the secondary is about 400kHz which is a bit high, putting the primary impedance higher than it would be with a lower frequency.
Offline Michelle_
« Reply #2 on: May 14, 2024, 11:12:22 PM »
Thanks that's very helpful! I wonder why he included the inverters then, just good practice?
You aren't the first person that's suggested secondary feedback over the antenna. Would you use the same kind of ferrite core as the gate driver? What kind of wire do you use to make 50 turns, magnet wire? And does the secondary just pass through the middle or does it need a loop? (sorry for all the question lol).
Thanks again for the answer by the way. I see what you mean about the single UCC as well.
« Reply #3 on: May 15, 2024, 04:58:02 AM »
The inverters don't hurt but it works fine without them, and then you don't need the 5V rail to power just one inverter IC.
Yes the same kind of ferrite as the gate drive transformer is good for feedback current transformers. I used an N87 core for both, material 77 and 75 are also good.
You can use quite a small core for a CT and the secondary base wire passes through only once, no loops. Turns are counted by the number of times the wire passes through the core.
If you have some CAT5 cable you can use an individual wire from it, or just use any hookup wire. I would avoid magnet wire though, some people had problems with it arcing to the core.
The UCC27425 is an inverting and non inverting gate driver in one, but it's only rated for 4A instead of 9A like the UCC27322/UCC37321.
The questions are all good, when you're new to electronics things that are easy for many to take for granted are not always obvious.
Offline Michelle_
« Reply #4 on: May 15, 2024, 03:32:57 PM »
Thank you this is very helpful. You're right that many things aren't always obvious when you're new, even if the overall concept is understandable!
post Re: Pulse Power High Current Discharges from 3 Phase PFC Capacitors
Today at 05:22:43 AM
Today at 05:08:46 AM
Today at 04:49:16 AM
post Re: Ring Launcher AC vs DC?
Today at 03:55:37 AM
Today at 02:48:22 AM
Domo
Today at 02:05:05 AM
Today at 01:43:10 AM
May 18, 2024, 11:30:11 PM
May 18, 2024, 10:10:56 PM
post Want to build HV HF oscilloscope probe.
Domo
May 18, 2024, 09:46:17 PM
May 18, 2024, 08:05:36 PM
post Re: Help an EE student
May 18, 2024, 05:59:21 AM
post Re: What capacitor configuration to explode foil?
May 18, 2024, 05:44:41 AM
May 18, 2024, 01:55:42 AM
May 17, 2024, 11:49:33 PM
May 17, 2024, 10:18:46 PM
post Pulse Power High Current Discharges from 3 Phase PFC Capacitors
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
post Re: Aluminum electrolytic capacitor ripple current issue
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
post Re: Tesla Synth Player for Syntherrupter
AntoineRcbs
May 16, 2024, 12:13:47 PM
post Re: Help with primary voltages of unknown transformer
Domo
May 16, 2024, 06:58:12 AM
post Re: New EE student asks about Cutting-Edge fields
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
post Re: DRSSTC grounding issues
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
post Re: Schmitt trigger schematic question
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
post New EE student asks about Cutting-Edge fields
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
post Schmitt trigger schematic question
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
post Re: Weird AC/DC mini SSTC build review
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
post Help with primary voltages of unknown transformer
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
OmGigaTron
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
post Re: Quick question about steve ward mini SST5 resonant frequency
May 12, 2024, 05:10:40 PM
post Re: Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
post Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
hal7rr
May 11, 2024, 05:24:34 PM
post Re: Type 77 Metglas Laced Ferrite Core
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
post Type 77 Metglas Laced Ferrite Core
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
post Re: designing and building electron gun help!
May 11, 2024, 12:10:44 AM
post designing and building electron gun help!
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
post Quick question about steve ward mini SST5 resonant frequency
May 10, 2024, 08:33:47 PM
