Author Topic: Adjustable High Voltage Electrostatic Precipitator Power Supply with 30KV 300W  (Read 2484 times)
Offline IonWind
Bought one :
https://www.ebay.co.uk/itm/374582175842
Now that it's arrived i'm scared of using it :/
Not the most professional-looking construction viewing it close up, even has solder traces that go nowhere !
Probably safer to just salvage the flybacks from it.
Gary.
I know a little about a lot and a lot about a little.
Offline IonWind
It works.
Gary.
Offline alan sailer
I used one on a fusor attempt. the only solid advice I can give you is to not try and make the thing easier to adjust by
using an external pot (ie wires from PC board to pot).
I did this and the thing died instantly. After repair and using the on-board pot it worked fine.
Cheers.
Offline IonWind
Thanks Alan, good to know.
Gary.
Offline dante
Hi, I bought one of these a few days ago. I was hoping to use it for corona discharge experiments, but it failed after a few minutes of (almost) open circuit operation. Has anyone else experienced this?
Offline alan sailer
I never tried running one of these open circuit.
You probably already know this but, in general, open circuit operation of HV power supplies is
a very challenging mode...the flybacks in the circuit will be operating at their maximum
voltage, which really stresses the insulation.
Good luck.
Cheers.
Offline dante
Thanks Alan - yes indeed that is what I assume has happened. Do you know if there is an alternative solution for a HV, relatively high current DC PS that will tolerate open circuit / full output voltage operation? I have a VdG, but that obviously delivers very low current.
Could you limit the open circuit voltage by including a spark gap? For example, smooth convex electrodes separated by 1/3 mm for 10 kV.
Offline alan sailer
I'd assume that companies like Spellman do this routinely. But I'd also guess that low price is part of the equation.
Have you looked into building a voltage multiplier circuit? Or do you need a plug and play solution.
Cheers.
« Last Edit: May 01, 2024, 04:17:16 PM by alan sailer »
Offline dante
Hi @klugesmith - I guess you're suggesting letting the output spark-over continuously at e.g. 10 kV, so that the PS operates under load. I guess that might work. What I'm not sure is whether under such conditions the output maintains DC 10 kV or instead drops significantly (i.e. under short-circuit) until the arc quenches, at which point the voltage rises again. That might not actually be a problem for my application however. I will give it a go - thanks.
Offline dante
Hi Alan, Indeed price is a key limiting factor. I am hoping for a plug-and-play solution, but if I can find a suitable device, I might find it second-hand on ebay I guess.
The CW in the video is very cool! I'm not an expert electronics hobbyist (I'm actually a physicist rather than an electronic engineer) but if I can find a CW then indeed that might be a good solution - thanks!
Today at 05:22:43 AM
Today at 05:08:46 AM
Today at 04:49:16 AM
post Re: Ring Launcher AC vs DC?
Today at 03:55:37 AM
Today at 02:48:22 AM
Domo
Today at 02:05:05 AM
Today at 01:43:10 AM
May 18, 2024, 11:30:11 PM
May 18, 2024, 10:10:56 PM
Domo
May 18, 2024, 09:46:17 PM
May 18, 2024, 08:05:36 PM
post Re: Help an EE student
May 18, 2024, 05:59:21 AM
May 18, 2024, 05:44:41 AM
May 18, 2024, 01:55:42 AM
May 17, 2024, 11:49:33 PM
May 17, 2024, 10:18:46 PM
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
AntoineRcbs
May 16, 2024, 12:13:47 PM
Domo
May 16, 2024, 06:58:12 AM
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
May 10, 2024, 08:33:47 PM
