Author Topic: Where To Get "Free" TO-247 IGBTs and MOSFETs  (Read 296 times)
« on: July 31, 2022, 08:57:46 PM »
A look at a box of IGBTs and MOSFETs that I have salvaged from household electronics like microwave ovens, induction stoves, solar inverters, welding machines, car and battery charges and other common high power electronics with switching inverters.
Do you have any sources for salvaging IGBTs / MOSFETs that is widely available from "household" items?
Offline ZakW
Re: Where To Get "Free" TO-247 IGBTs and MOSFETs
« Reply #1 on: July 31, 2022, 10:27:33 PM »
Hey Mads,
I don't have a household source but I am fortunate to work for an ISP in my area. I am friends with the warehouse who handles recycling old equipment so every now and again i go take a look at what they have. There is usually a huge crate (5ft cubed) full of all kinds of PCBs. I have built up a nice stock of heasinks, MOSFETs, and misc diodes.
    • My Youtube Channel
« Reply #2 on: August 02, 2022, 07:36:07 PM »
As I commented on youtube, SMA solar inverters are popular here around. The models that are now slowly being retired/failing (a.k.a. the stuff that shows up for cheap or free) are just full of salvageable parts. Unfortunately, more recent models seem to be less salvage-friendly; f.ex. one we got installed in our house has the heatsink integrated into the casing. They're also noticeably smaller now.
Anyways, those older ones only contain the good, expensive name brand stuff. TI opamps, Avago opto-isolated gate drivers, big made-in-germany inductors, huge heatsinks, silicone cables, WAGO connectors, ... Even the unisolated faston crimp contacts all the wires give you immediately a feel of quality (it's the type with latch like these).
Also, all SMD parts on all PCBs were conformally coated.
Below the picture I included a list of everything I salvaged out of a 4 or 5kW unit whose bus capacitors blew up (MOSFETs and IGBTs seem fine). I didn't do any sort of reverse engineering but it is interesting to note that the main inverter apparently uses 1200V MOSFETs, not IGBTs.
  • Passives
    • Bunch of good quality WIMA and EPCOS foil capacitors (top right)
    • 4x EPCOS 680uF 450V (possibly bad condition, since some of them blew up (cf PCB))
    • 3x 2x2.8mH 10A 250V EPCOS Common Mode Choke Product Link
    • 3x "small", 2x large inductors - all made in germany by SMP. The small ones are likely associated to each of the three solar DC inputs, the larger ones likely related to the single phase AC output. Based on another, similar inductor from another SMA unit, the big inductors are in the ballpark of 2mH 25A.
  • Sensors
  • ICs
    • Bunch of logic ICs (74HC/AHC)
    • 7x LM258 OpAmp Dual 700kHz GBW
    • 3x TI TL084 Quad OpAmp JFET 3MHz GBW Product Link
    • 8x LM293 Comparator Dual
    • 3x TL2843 Current Mode PWM Controller Product Link
    • 3x HEF4066BT Quad SPST Analog Switch Product Link
    • 4x SFH6156-3 Opto-Coupler Product Link
    • 4x Avago HCPL-J312 2A Optio-Isolated Gate Drivers Product Link
    • 3x IR4427 Dual Low-Side Driver Product Link
  • Power
  • Misc
    • Clips for mounting the TOxxx power semiconductors to the heatsink standoffs. These weren't cheap either I'm sure.
    • 2x Massive heatsinks - about 20cm x 50cm
    • 6x EPCOS Varistor (625Vrms 6.5kApk) + Thermal fuse (3A 250V 102°C)
    • Bunch of massive WAGO PCB Connectors
    • Bunch of nice silicone cables with "solar" connectors
    • Some wires with high quality crimp contacts (these faston crimps were probably 20-30 cent each in bulk).
    • 4x Panasonic Relay SPST-NO 250V 20A (9V coil)
    • 1x 16x2 character LCD module (no backlight).
« Last Edit: August 02, 2022, 08:58:15 PM by Max »
« Reply #3 on: August 04, 2022, 08:50:24 PM »
That is an impressive amount of good stuff in one unit.
I agree on the whole-cast being shite thing. I dug through a pile of maybe 20 solar inverters and only 5 of them even had TO-247 IGBTs, rest were multi phase bricks or press-fit skiip modules. Heat sinks are cast as part of the chassis, with DC bus capacitors and inductors imbedded into it with epoxy. Its complete trash to the metal scrappers as its now a whole unit of electronics waste and they cant get the heat sink or inductors "out".
Legislation is properly so badly made that when manufacturers have to assure it will be recycled, its not necessarily recycled in a smart, re-useable or low energy cost way. It is just possible.
Offline TMaxElectronics
« Reply #4 on: August 08, 2022, 09:50:49 PM »
I found it very helpful to just search ebay for the big IGBT manufacturer names from time to time. I found everything from skm200 bricks for 5€ to an entire 400A VFD output stage which included a 20kg heatsink, 12 electrolytic caps and 6 SKM300 halfbridges for 5€ :)
Same thing goes for electrolytic capacitors, even the big ones can sometimes be found for als little as 2,50€.
Oh and regarding salvaged IGBTs from induction cookers: you can just use an induction cooker powerstage directly for a tesla coil. Thats how I got started building coils ;D
post Re: Aluminium Nitride Thermal Pads
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
post Re: Problem with VTTC Staccato interrupter PLZ HELP
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
post Re: Half-bridge for my first sstc
August 13, 2022, 10:14:40 PM
post Problem with VTTC Staccato interrupter PLZ HELP
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
post A little idea I had for my dual full bridge design
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
post Aluminium Nitride Thermal Pads
August 12, 2022, 04:31:17 AM
post Re: Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 12, 2022, 02:55:27 AM
post Re: Small DRSSTC Questions
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
post Say what -- arcing TO polycarbonate!
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
post Re: Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
post Half-bridge for my first sstc
LoOdaK
August 11, 2022, 11:13:20 AM
post Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
post Re: Painfully Amazing Stuff
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
post Re: HV AC Current Measurement
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
post Re: How To Varnish A Tesla Coil Secondary Coil
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
post Re: Coherent VersaPulse VPW - what should I do with it?
August 09, 2022, 08:15:54 PM
post High Voltage pcb
August 09, 2022, 08:15:10 PM
post Top load material selection
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
post Loneoceans UD 2.7 rev c issue
mthome4
August 09, 2022, 03:11:56 PM
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
post HV AC Current Measurement
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
post Coherent VersaPulse VPW - what should I do with it?
August 08, 2022, 11:24:45 PM
post Re: Optic fiber interrupter in EU
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
Maju
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
post How To Varnish A Tesla Coil Secondary Coil
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
post Optic fiber interrupter in EU
ItsChloeUwU
August 08, 2022, 08:09:38 PM
post Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
