Author Topic: Successful flyback/xformer driver above 3kw  (Read 202 times)
« on: July 30, 2022, 04:55:51 AM »
Just thought I'd put this out there;
How many members here have built a successful flyback/xformer driver that can operate above 3kw (let's say 3-6kw range) without failures. Judging from what I've seen there's not many out there due to the common igbt brick failure (myself is included in this failure scenario)
Re: Successful flyback/xformer driver above 3kw
« Reply #1 on: July 30, 2022, 10:17:13 AM »
I have only pushed up around 1 kW and burned everything :)
« Reply #2 on: July 31, 2022, 12:14:19 AM »
Does the transformer output need to be high voltage and subject to arc loading to count?
I've build an isolated "PFC" that inputs single-phase 240VAC (or three-phase 208) and outputs isolated adjustable 350-450Vdc.  That feeds my DRSSTC and other projects.  Runs 8-10kW, reliably so far :)  Uses a TO247 IGBT H-bridge to feed a gapped transformer through series resonant MMC.  Transformer secondary is rectified with SiC diode array to bulk caps at 350-450Vdc.
It can handle shorted load, at least for the duration it takes to charge 44000uF of bulk capacitance.  (Charged 200000uF a few times for my low-frequency QCW experiment.)  The H-bridge runs at the higher resonant frequency of transformer's leakage inductance when output voltage is low, and at the transformer's parallel inductance frequency at normal output voltages.  Current waveforms get a bit more unpredictable at intermediate output voltages.  The H-bridge always switches close to zero current.  However, at intermediate output voltages, switching is sometimes after zero-crossing, causing some hard-switching.
Of course, this is nothing compared to Phoenix' 35kW transformer and resulting arcs:
https://highvoltageforum.net/index.php?topic=1976.msg14755#msg14755
« Last Edit: July 31, 2022, 12:18:14 AM by davekni »
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
ItsChloeUwU
July 31, 2022, 04:56:53 PM
ItsChloeUwU
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
ItsChloeUwU
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
ItsChloeUwU
July 30, 2022, 01:34:27 AM
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
July 29, 2022, 11:03:59 AM
July 29, 2022, 05:50:32 AM
July 29, 2022, 05:29:43 AM
July 29, 2022, 12:51:08 AM
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
July 28, 2022, 06:06:58 AM
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 04:06:37 AM
July 28, 2022, 03:57:19 AM
July 28, 2022, 03:46:15 AM
ItsChloeUwU
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
ItsChloeUwU
July 28, 2022, 03:27:40 AM
ItsChloeUwU
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
55#sofcopper
July 27, 2022, 06:15:44 PM
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
farleymartinez
July 27, 2022, 04:37:44 AM
ItsChloeUwU
July 26, 2022, 09:45:49 PM
ItsChloeUwU
July 26, 2022, 09:45:37 PM
ItsChloeUwU
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
ItsChloeUwU
July 26, 2022, 04:15:51 PM
ItsChloeUwU
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
July 26, 2022, 03:48:23 AM
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
July 26, 2022, 12:16:12 AM
July 25, 2022, 11:55:33 PM
July 25, 2022, 10:20:45 PM
July 25, 2022, 05:18:07 PM
ItsChloeUwU
July 25, 2022, 03:23:13 PM
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
July 24, 2022, 05:06:32 AM
July 24, 2022, 04:15:16 AM
