Author Topic: 60 hz hum in KLH receiver  (Read 162 times)
« on: July 25, 2022, 10:20:45 PM »
I have an old KLH R3100 receiver which has recently developed a 60 hz hum in both speakers. It does it for all inputs. I have tried all sorts of grounding ideas to no avail. The amp has worked perfectly for about 10 years. It just recently developed the 60 hum. Are there any ideas as to the problem? My initial thought was that perhaps a capacitor has failed.
I could just buy another old used receiver on Craigslist for $50 but if this one can be easily repaired I would rather just fix this one.
Re: 60 hz hum in KLH receiver
« Reply #1 on: July 25, 2022, 11:55:33 PM »
That does sound like you have hum on an internal supply rail, rather than a grounding fault.  Can you get hold of a service manual? Can you scope the supply rails? At the very least run an eyeball over the internals to see is there's something obvious.
« Reply #2 on: July 26, 2022, 12:16:12 AM »
Just my 2 cents, but I'd look for a bad electrolytic capacitor in the power supply.
« Reply #3 on: July 26, 2022, 03:48:23 AM »
Have you scoped the hum to verify it is indeed 60Hz and not 120Hz?  And the waveform shape of the hum?  Presuming no half-wave rectification, bad electrolytic capacitors (most likely cause) would show up as 120Hz hum.  A failed rectifier diode should make 60Hz hum with a flat portion between dips or rises.  60Hz reasonably sine wave hum would suggest grounding.
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
August 06, 2022, 07:49:05 PM
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
post Re: a substitute for FDD8424H
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
post Where to find a "small" focal spot x-ray tube
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
post Where To Get "Free" TO-247 IGBTs and MOSFETs
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
July 31, 2022, 04:56:53 PM
post Re: Successful flyback/xformer driver above 3kw
July 31, 2022, 12:14:19 AM
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
July 30, 2022, 10:17:13 AM
post Successful flyback/xformer driver above 3kw
July 30, 2022, 04:55:51 AM
post Primary Wire Getting Hot, Secondary flashovers, RSG Not Alway Fireing? Help pls.
July 30, 2022, 01:34:27 AM
post Re: Reverse Engineering a Design for a Transmitter - Real Deal
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
post Lightnovo Raman Spectrometer Demonstration At Roskilde Festival 2022
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
post a substitute for FDD8424H
July 29, 2022, 11:03:59 AM
post AC v. Pulsed DC for transformers
July 29, 2022, 05:50:32 AM
post Re: Solder v. Wago junctions
July 29, 2022, 05:29:43 AM
post Re: Full wave CW Multiplier possible punch through
July 29, 2022, 12:51:08 AM
post Re: DRSSTC from Aliexpress
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
post Re: Help with TC schematic
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
post Re: Just a quick question on NST insulation...
July 28, 2022, 06:06:58 AM
post Re: OKY CHAT... EXPLAIN ME THIS SORCERY PLS... Xshion Coil on AliexPress?!
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 04:06:37 AM
July 28, 2022, 03:57:19 AM
post Re: gdt is giving a perfect signal and good current but the mosfet are not swithing
July 28, 2022, 03:46:15 AM
post Just a quick question on NST insulation...
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
July 28, 2022, 03:27:40 AM
post Re: Looking for a good schematic to follow for my first audio sstc coil :3
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
post gdt is giving a perfect signal and good current but the mosfet are not swithing
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
post Re: Secondary former material
55#sofcopper
July 27, 2022, 06:15:44 PM
post Re: Gate waveform question
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
post Secondary former material
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
post Smoke detector carrying plutonium
farleymartinez
July 27, 2022, 04:37:44 AM
July 26, 2022, 09:45:49 PM
July 26, 2022, 09:45:37 PM
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
July 26, 2022, 04:15:51 PM
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
post Re: 60 hz hum in KLH receiver
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
post 60 hz hum in KLH receiver
July 25, 2022, 05:18:07 PM
post Looking for a good schematic to follow for my first audio sstc coil :3
July 25, 2022, 03:23:13 PM
post Total Pro Tp40 Servis Manuel Gerekli
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
post Re: Racing arcs on secondary
July 24, 2022, 05:06:32 AM
July 24, 2022, 04:15:16 AM
