Author Topic: Looking for a good schematic to follow for my first audio sstc coil :3  (Read 497 times)
Offline ItsChloeUwU
  • Love You All 💗✌🏻🏳️‍🌈
    • My Site UwU
i was designing my drsstc, and with the help of the forum i got pretty much the 3d project done and i was ready to start doing the bridge but then i realized that i knowed just a little and instead of starting with full on bricks ::) i would have liked to start with something smaller in a TO-247 format  ;D.
So here i am asking for a good yet affordable schematic to make an sstc with good henaf spark lenght and that is audiomodulated, preferibly high quality (with midi and cheap optic cable perhaps?).
Im a bit on a budget so i cant really spend all my moneys on this project but i would also like to have around 30 to 50cm of sparks if is possible..
i was following a youtube channel that really had some nice resolts! im gonna leve the link at the end of this post so that you can have an idea of what i would like to have as a spark lenght.
i was planning to use some 60n65 since they are pretty easy and common to diagnosticate if it fails..
please leave me some good schematics that i can follow/edit to my needs (i would need help for that tho).
this is the yt vid (around 20secs in):
I highly recommend using CD4046 to drive an SSTC, it's quite reliable, easy to modulate with analog audio and in case of feedback error it won't destroy your transistors.
I have built such coil with schematics https://www.uhvlab.org/sstc-ii
My coil is just slightly modified version of https://www.vn-experimenty.eu/teslov-transformator/sstc/sstc-5.html (not available in english)
Marek Novotny
www.uhvlab.org
Offline ItsChloeUwU
    • My Site UwU
well yeah... this looks good.. but i was looking for something less "noisy" with the audio and a bit longer sparks with audio... so something a bit more.. midi style lets say.. also i looked into the schematics and buildings.. it not THAT easy haha a lot of transistors etc... im looking for something simpler with the driver too.. i mean.. i have a ud2.7C driver so maybe i could use that.. but i need to check if its in good shape...
if its not i need something more simple to do...
this said.. i would like to ask for something with less transistors.. easyer driver.. and more clear sparks with audio modulation :3
« Last Edit: July 26, 2022, 04:15:22 PM by ItsChloeUwU »
Offline ItsChloeUwU
    • My Site UwU
UD2.7 can drive an SSTC but DRSSTCs usually run very short duty cycles, for continuous or long duty cycles, adding a little more DC capacitance to the driver board might be a good idea. Also those small SMD packages with Gate drivers might overheat.
Before creating my first SSTC, I wanted the exact same thing as you; a simple, easy to build driver but those drivers are usually unreliable in one way or another. I ended up building 4 different drivers until I finally decided to build PLL CD4046 driver which finally solved everything. This driver can also be easily modified for using MIDI instead of mp3 audio. For example using ENABLE pin of Gate drivers.
But in case you don't want to get your hands on phase lock loop I suggest you try following driver:
From https://www.vn-experimenty.eu/teslov-transformator/sstc/sstc-4.html
It uses 74HC14 in combination with capacitor and resistor to create a simple oscillator which drives the coil before an antenna/CT feedback is up and running.
Also, there is no need to use so many transistors as I have used in my coil. My coil was drawing over 3kW of power, in case you're aiming for lower input power you may build a single full bridge or even a half bridge.
« Last Edit: July 26, 2022, 04:28:20 PM by AstRii »
Marek Novotny
www.uhvlab.org
Online ZakW
This topic has been discussed a lot before and there are a lot of great starter SSTCs out there (also forum rule #2...). Have you tried looking for similar questions on the forum? Which circuits have you considered building?
Here are a few great links that have several builds and varying levels of power and complexity. Most of them can be modified slightly to add audio modulation.
https://kaizerpowerelectronics.dk/
https://www.stevehv.4hv.org/SSTCindex.htm
https://www.loneoceans.com/labs/#
-Zak
Offline ItsChloeUwU
    • My Site UwU
-Zak
Hi Zak,
yes im aware of role 2 but tbh i could not find any good MIDI interrupted sstc and with great sparks like the Fabricio one... so yeah... :c
Offline ItsChloeUwU
    • My Site UwU
Seeing the Fabricio one (the video above) his coil is easy and small packaged wich is another thing im trying to aim for... so yeah... idk... i guess a drsstc then? :c
Offline ItsChloeUwU
    • My Site UwU
DRSSTC adds a bit of complexity as you need to design an MMC (which can be costly) and there is much higher chance of over-coupling creating racing sparks.
DRSSTC offers much higher efficiency due to zero current switching, that's why DR coils are usually quite "small packaged", there is no need for big heatsinks. However SSTC can be compact as well, it's all about layout design.
If you're aiming for smaller design, you just have to accept you'll be switching lower power.
Pretty much any SSTC driver is able (or can be modified) to play MIDI. But being able to play MIDI is not just a matter of having a coil, you also need a good interrupter and MIDI files which sounds good on the coil. Not every MIDI file can be played on a Tesla coil.
Franzoli is well known for creating his own MIDI files with special features which allows him to play great sounding MIDI on his coils.
Marek Novotny
www.uhvlab.org
AFAIK he is not even using MIDI files.
He prepares stereo audio files in Fruity Loop and uses each positive and negative side of a audio stereo signal as a channel, so he has 4 channels/coils in a stereo signal. So all his signal processing is done in Fruity Loops.
Offline ItsChloeUwU
    • My Site UwU
hewwo Mads!
nice to have you in my comments!
I knowed franzoli since i was really young, and yeah.. i knowed about that... but dang it sound complicated haha.. i mean.. i used FL Studio before.. and its oky.. but the composition to make it sound so good i never understood how he did that hahahaha... perhaps any suggestions? also would like to know if you have any good coil to suggest to me! a nice sstc that is not SUPER complicated that plays midi with nice lenght of sparks.. otherwise i sould go back to my drsstc but im a bit scared to start with a full on brick dr LoL
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
August 06, 2022, 07:49:05 PM
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
post Re: a substitute for FDD8424H
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
post Where to find a "small" focal spot x-ray tube
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
post Where To Get "Free" TO-247 IGBTs and MOSFETs
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
July 31, 2022, 04:56:53 PM
post Re: Successful flyback/xformer driver above 3kw
July 31, 2022, 12:14:19 AM
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
July 30, 2022, 10:17:13 AM
post Successful flyback/xformer driver above 3kw
July 30, 2022, 04:55:51 AM
post Primary Wire Getting Hot, Secondary flashovers, RSG Not Alway Fireing? Help pls.
July 30, 2022, 01:34:27 AM
post Re: Reverse Engineering a Design for a Transmitter - Real Deal
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
post Lightnovo Raman Spectrometer Demonstration At Roskilde Festival 2022
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
post a substitute for FDD8424H
July 29, 2022, 11:03:59 AM
post AC v. Pulsed DC for transformers
July 29, 2022, 05:50:32 AM
post Re: Solder v. Wago junctions
July 29, 2022, 05:29:43 AM
post Re: Full wave CW Multiplier possible punch through
July 29, 2022, 12:51:08 AM
post Re: DRSSTC from Aliexpress
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
post Re: Help with TC schematic
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
post Re: Just a quick question on NST insulation...
July 28, 2022, 06:06:58 AM
post Re: OKY CHAT... EXPLAIN ME THIS SORCERY PLS... Xshion Coil on AliexPress?!
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 04:06:37 AM
July 28, 2022, 03:57:19 AM
post Re: gdt is giving a perfect signal and good current but the mosfet are not swithing
July 28, 2022, 03:46:15 AM
post Just a quick question on NST insulation...
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
July 28, 2022, 03:27:40 AM
post Re: Looking for a good schematic to follow for my first audio sstc coil :3
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
post gdt is giving a perfect signal and good current but the mosfet are not swithing
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
post Re: Secondary former material
55#sofcopper
July 27, 2022, 06:15:44 PM
post Re: Gate waveform question
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
post Secondary former material
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
post Smoke detector carrying plutonium
farleymartinez
July 27, 2022, 04:37:44 AM
July 26, 2022, 09:45:49 PM
July 26, 2022, 09:45:37 PM
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
July 26, 2022, 04:15:51 PM
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
post Re: 60 hz hum in KLH receiver
July 26, 2022, 03:48:23 AM
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
July 26, 2022, 12:16:12 AM
July 25, 2022, 11:55:33 PM
post 60 hz hum in KLH receiver
July 25, 2022, 10:20:45 PM
July 25, 2022, 05:18:07 PM
post Looking for a good schematic to follow for my first audio sstc coil :3
July 25, 2022, 03:23:13 PM
post Total Pro Tp40 Servis Manuel Gerekli
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
post Re: Racing arcs on secondary
July 24, 2022, 05:06:32 AM
July 24, 2022, 04:15:16 AM
