Author Topic: Full wave CW Multiplier possible punch through  (Read 886 times)
Re: Full wave CW Multiplier possible punch through
« Reply #20 on: July 28, 2022, 04:06:37 AM »
As soon as I begin to draw some current, popping.
Only possibility that comes to mind is that some component (diode or capacitor) might have failed.  This two-sided (full-wave) multiplier will function even if only one side is good.  If some capacitor has failed to much lower value, that would explain different loaded vs. unloaded behavior.  Perhaps a bad diode could cause issues, but I haven't thought through any possibilities to match your symptoms.
One option is to ignore the popping until something fails harder.  However, that could mean more failed parts in the end.
Good luck!
Offline FonziDaytona
« Reply #21 on: July 29, 2022, 12:51:08 AM »
My transformer failed :-(
That’s what I get for winding a coil with wide dimensions and little space near the edges.
I’m now thinking about switching to a multi section bobbin, 3D printed (no access to or ability with a machine shop). Fortunately, I found what looks to be the perfect design already made.
https://www.thingiverse.com/thing:5241175#Summary
I’ll need to scale up a little because my core is very large. I plan to use a nylon SLS 3D print. The 11 sections will be divided into two coils (5 sections per coil) with one section left empty for the center tap connection.
Before I order a pricey print, anything I’m missing here?
-Matt
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
ItsChloeUwU
July 31, 2022, 04:56:53 PM
July 31, 2022, 12:14:19 AM
ItsChloeUwU
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
ItsChloeUwU
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
July 30, 2022, 10:17:13 AM
July 30, 2022, 04:55:51 AM
ItsChloeUwU
July 30, 2022, 01:34:27 AM
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
July 29, 2022, 11:03:59 AM
July 29, 2022, 05:50:32 AM
July 29, 2022, 05:29:43 AM
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
July 28, 2022, 06:06:58 AM
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 03:57:19 AM
July 28, 2022, 03:46:15 AM
ItsChloeUwU
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
ItsChloeUwU
July 28, 2022, 03:27:40 AM
ItsChloeUwU
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
55#sofcopper
July 27, 2022, 06:15:44 PM
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
farleymartinez
July 27, 2022, 04:37:44 AM
ItsChloeUwU
July 26, 2022, 09:45:49 PM
ItsChloeUwU
July 26, 2022, 09:45:37 PM
ItsChloeUwU
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
ItsChloeUwU
July 26, 2022, 04:15:51 PM
ItsChloeUwU
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
July 26, 2022, 03:48:23 AM
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
July 26, 2022, 12:16:12 AM
July 25, 2022, 11:55:33 PM
July 25, 2022, 10:20:45 PM
July 25, 2022, 05:18:07 PM
ItsChloeUwU
July 25, 2022, 03:23:13 PM
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
July 24, 2022, 05:06:32 AM
July 24, 2022, 04:15:16 AM
