Author Topic: Racing arcs on secondary  (Read 466 times)
Offline 55#sofcopper
« on: July 04, 2022, 07:03:50 PM »
I'm new to the forum. I have a medium size sgtc with a 4in secondary. I want to put a 6in secondary coil but when I do I get arcs racing up the secondary coil. It works good with the 4 in. I've tapped the primary every possible place. Added extra turns on primary but I can't get rid of the arcs. For a power supply I have 4 12000v 30ma net's
 in parallel.  The cap is mma made with good caps. Anyone have any idea what I can do?
Re: Racing arcs on secondary
« Reply #1 on: July 04, 2022, 07:16:40 PM »
 [ Invalid Attachment ]
Offline AstRii
« Reply #2 on: July 04, 2022, 09:42:39 PM »
The new bigger secondary is now closer to the primary coil, this way you increased coupling and there is a limit to what coupling you can have before you'll see overvoltage on the secondary.
Lower your primary coil / raise your secondary a bit to reduce coupling.
Bigger topload could also work.
Marek Novotny
www.uhvlab.org
« Reply #3 on: July 05, 2022, 05:57:54 AM »
Thanks. I should have mentioned, I opened up the primary coil in the center and I also left several inches unwound on the secondary to get it above my primary. The primary is completely flat. But I think you're right about it being overcoupled. I'll try moving it slightly higher and maybe remove a winding or 2 from the center of the primary.  My top load is 30 in × 4.5in toroidal shape. Thanks for the advice.
« Reply #4 on: July 05, 2022, 08:18:40 PM »
Did you simulate your original coil and changed coil in JavaTC? http://www.classictesla.com/java/javatc/javatc.html
This calculates the coupling and also gives you a recommended coupling. For a SGTC that is 0.136 that is usually suggested by JavaTC.
A few other causes of racing sparks could be badly tuned primary circuit, so that its running too much off the secondary circuit resonance or bad/insufficient grounding of the secondary.
« Reply #5 on: July 06, 2022, 08:58:24 PM »
I actually don't own a computer so no I haven't simulated the coil. I'm building by trial and error mostly. As far as tuning of the primary I have moved my tap all over the primary. I have a piece of 1.5ft of copper clad steel bar .5in diameter driven into the ground to serve as my ground. Connected with the same 26awg magnet wire that the secondary is wound with. Should I use a wire with less resistance to connect my ground ? The secondary is wound on 6in cardboard tube. I sprayed it with a light coat of polyurethane before winding and after we r winding I coated the whole secondary with a generous coat of 2 part epoxy. Could my construction method have any cause on the unwanted arcs ?
« Reply #6 on: July 07, 2022, 06:16:08 AM »
I would use a much bigger ground wire. At these frequencies, almost all the current is flowing on the outer surface of the wire so 26 AWG wire is not going to provide a very good ground. I use 0.75 inch tin-plated copper braid for my ground connection.
« Reply #7 on: July 09, 2022, 08:34:50 PM »
Thanks. I'll try a bigger ground. I have some 2awg welding cable. Maybe that will help my problem.
« Reply #8 on: July 09, 2022, 09:52:15 PM »
At these frequencies most of the copper in your welding cable will be wasted due to the skin effect. If you don't mind the waste go ahead. Flat copper braid or copper strip would work just as well with much less waste.
« Reply #9 on: July 24, 2022, 01:22:34 AM »
Since I have the cable I don't mind the waste. I will probably invest in some braided copper strapping. Is there a minimum with I should keep in mind. I now added a 60ma 12000v nst to the other four 12000v 30ma net's.
« Reply #10 on: July 24, 2022, 05:06:32 AM »
I use one inch wide braided copper cable although there isn't anything crucial about this size.
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
ItsChloeUwU
July 31, 2022, 04:56:53 PM
July 31, 2022, 12:14:19 AM
ItsChloeUwU
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
ItsChloeUwU
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
July 30, 2022, 10:17:13 AM
July 30, 2022, 04:55:51 AM
ItsChloeUwU
July 30, 2022, 01:34:27 AM
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
July 29, 2022, 11:03:59 AM
July 29, 2022, 05:50:32 AM
July 29, 2022, 05:29:43 AM
July 29, 2022, 12:51:08 AM
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
July 28, 2022, 06:06:58 AM
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 04:06:37 AM
July 28, 2022, 03:57:19 AM
July 28, 2022, 03:46:15 AM
ItsChloeUwU
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
ItsChloeUwU
July 28, 2022, 03:27:40 AM
ItsChloeUwU
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
55#sofcopper
July 27, 2022, 06:15:44 PM
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
farleymartinez
July 27, 2022, 04:37:44 AM
ItsChloeUwU
July 26, 2022, 09:45:49 PM
ItsChloeUwU
July 26, 2022, 09:45:37 PM
ItsChloeUwU
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
ItsChloeUwU
July 26, 2022, 04:15:51 PM
ItsChloeUwU
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
July 26, 2022, 03:48:23 AM
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
July 26, 2022, 12:16:12 AM
July 25, 2022, 11:55:33 PM
July 25, 2022, 10:20:45 PM
July 25, 2022, 05:18:07 PM
ItsChloeUwU
July 25, 2022, 03:23:13 PM
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
July 24, 2022, 04:15:16 AM
