Author Topic: Racing arcs on secondary  (Read 480 times)
Online 55#sofcopper
« on: July 04, 2022, 07:03:50 PM »
I'm new to the forum. I have a medium size sgtc with a 4in secondary. I want to put a 6in secondary coil but when I do I get arcs racing up the secondary coil. It works good with the 4 in. I've tapped the primary every possible place. Added extra turns on primary but I can't get rid of the arcs. For a power supply I have 4 12000v 30ma net's
 in parallel.  The cap is mma made with good caps. Anyone have any idea what I can do?
Online 55#sofcopper
Re: Racing arcs on secondary
« Reply #1 on: July 04, 2022, 07:16:40 PM »
 [ Invalid Attachment ]
Offline AstRii
« Reply #2 on: July 04, 2022, 09:42:39 PM »
The new bigger secondary is now closer to the primary coil, this way you increased coupling and there is a limit to what coupling you can have before you'll see overvoltage on the secondary.
Lower your primary coil / raise your secondary a bit to reduce coupling.
Bigger topload could also work.
Marek Novotny
www.uhvlab.org
Online 55#sofcopper
« Reply #3 on: July 05, 2022, 05:57:54 AM »
Thanks. I should have mentioned, I opened up the primary coil in the center and I also left several inches unwound on the secondary to get it above my primary. The primary is completely flat. But I think you're right about it being overcoupled. I'll try moving it slightly higher and maybe remove a winding or 2 from the center of the primary.  My top load is 30 in × 4.5in toroidal shape. Thanks for the advice.
« Reply #4 on: July 05, 2022, 08:18:40 PM »
Did you simulate your original coil and changed coil in JavaTC? http://www.classictesla.com/java/javatc/javatc.html
This calculates the coupling and also gives you a recommended coupling. For a SGTC that is 0.136 that is usually suggested by JavaTC.
A few other causes of racing sparks could be badly tuned primary circuit, so that its running too much off the secondary circuit resonance or bad/insufficient grounding of the secondary.
Online 55#sofcopper
« Reply #5 on: July 06, 2022, 08:58:24 PM »
I actually don't own a computer so no I haven't simulated the coil. I'm building by trial and error mostly. As far as tuning of the primary I have moved my tap all over the primary. I have a piece of 1.5ft of copper clad steel bar .5in diameter driven into the ground to serve as my ground. Connected with the same 26awg magnet wire that the secondary is wound with. Should I use a wire with less resistance to connect my ground ? The secondary is wound on 6in cardboard tube. I sprayed it with a light coat of polyurethane before winding and after we r winding I coated the whole secondary with a generous coat of 2 part epoxy. Could my construction method have any cause on the unwanted arcs ?
« Reply #6 on: July 07, 2022, 06:16:08 AM »
I would use a much bigger ground wire. At these frequencies, almost all the current is flowing on the outer surface of the wire so 26 AWG wire is not going to provide a very good ground. I use 0.75 inch tin-plated copper braid for my ground connection.
Online 55#sofcopper
« Reply #7 on: July 09, 2022, 08:34:50 PM »
Thanks. I'll try a bigger ground. I have some 2awg welding cable. Maybe that will help my problem.
« Reply #8 on: July 09, 2022, 09:52:15 PM »
At these frequencies most of the copper in your welding cable will be wasted due to the skin effect. If you don't mind the waste go ahead. Flat copper braid or copper strip would work just as well with much less waste.
Online 55#sofcopper
« Reply #9 on: July 24, 2022, 01:22:34 AM »
Since I have the cable I don't mind the waste. I will probably invest in some braided copper strapping. Is there a minimum with I should keep in mind. I now added a 60ma 12000v nst to the other four 12000v 30ma net's.
« Reply #10 on: July 24, 2022, 05:06:32 AM »
I use one inch wide braided copper cable although there isn't anything crucial about this size.
post Re: Aluminium Nitride Thermal Pads
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
post Re: Problem with VTTC Staccato interrupter PLZ HELP
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
post Re: Half-bridge for my first sstc
August 13, 2022, 10:14:40 PM
post Problem with VTTC Staccato interrupter PLZ HELP
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
post A little idea I had for my dual full bridge design
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
post Aluminium Nitride Thermal Pads
August 12, 2022, 04:31:17 AM
post Re: Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 12, 2022, 02:55:27 AM
post Re: Small DRSSTC Questions
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
post Say what -- arcing TO polycarbonate!
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
post Re: Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
post Half-bridge for my first sstc
LoOdaK
August 11, 2022, 11:13:20 AM
post Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
post Re: Painfully Amazing Stuff
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
post Re: HV AC Current Measurement
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
post Re: How To Varnish A Tesla Coil Secondary Coil
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
post Re: Coherent VersaPulse VPW - what should I do with it?
August 09, 2022, 08:15:54 PM
post High Voltage pcb
August 09, 2022, 08:15:10 PM
post Top load material selection
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
post Loneoceans UD 2.7 rev c issue
mthome4
August 09, 2022, 03:11:56 PM
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
post HV AC Current Measurement
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
post Coherent VersaPulse VPW - what should I do with it?
August 08, 2022, 11:24:45 PM
post Re: Optic fiber interrupter in EU
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
Maju
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
August 08, 2022, 09:50:49 PM
post How To Varnish A Tesla Coil Secondary Coil
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
post Optic fiber interrupter in EU
ItsChloeUwU
August 08, 2022, 08:09:38 PM
post Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
