Author Topic: Solder v. Wago junctions  (Read 244 times)
Offline abstruse1
« on: July 03, 2022, 10:00:15 PM »
I'm assembling another CW and am trying to find the best layout for the components and the easiest way to assemble the CW as well as to remove diodes when they blow.
My previous CWs have mostly used soldered junctions, but I'm wondering if I can use Wago junctions to make things much easier.  I measured the resistance of 16AWG solid wire, both twisted/soldered and clamped in a Wago connector.  The solder joint measured .32 milliohms, and the Wago measured 2.4 milliohms.  Percentage wise, this is a big difference, but it may be trivial, especially given the high voltage levels these loints will see.
Any ideas?  Thanx.
Abstruse1
Re: Solder v. Wago junctions
« Reply #1 on: July 06, 2022, 10:22:13 PM »
Well folks,   I had no idea what a "CW" was.  It took a while to find it.  CW stands for lots of things, by the way.
Turns out it's the Cockcroft-Walton Generator (I assume, anyway).   It multiplies an AC input to higher DC voltages using a "ladder" of diodes and capacitors.
From what I just read, these devices are not designed for high current applications.
I wouldn't think you'd be blowing a lot of diodes if the circuit was designed and applied properly.
But if you are going for thousands or tens of thousands of volts, a few milli ohms could make quite a difference.
---It appears that the whole world is in love with those Waco connectors, but I am not a fan.
OTOH, I do use solderless breadboards a lot, so don't pay any attention to me!!!
Pete Stanaitis
« Reply #2 on: July 07, 2022, 06:11:16 AM »
You may want to have a look at my 14-stage CW posting. All of my joints are done with brass screws but I also use doorknob capacitors and everything is under oil. My device is easily serviceable.
Offline rikkitikkitavi
« Reply #3 on: July 07, 2022, 10:46:45 PM »
Current is as Peterspco pointed out low, perhaps not in the first stages but still far below compared to what the WAGO is rated for. Insulationwise it is not an issue, as the voltage is far beyound WAGOs rating and additional insulation is necssary (air , oil etc)
Apart from cost,  WAGOs are not cheap and the difficulty of getting a good connection with thin component leads (they are far thinner than normal electrical wiring) and might not create a reliable connection. That is what I see as a main risc. They are not designed for this task. You must check teh WAGOs specification.
Also, soldering might be troublesome due to faulty solder joints. They must all be thoroughly inspected, a loose joint will create arcing and voltage stress on components.
I have used them extensivly in my house. Very nifty. But get the ones that can accomodate both multistrand and single strand wiring if that is approved in your country.
Offline abstruse1
« Reply #4 on: July 29, 2022, 05:29:43 AM »
I would think that higher voltages wouldbe less affected by small (<1ohm) resistances, even if the current carried is very small (a few mA).  Am I wrong?
Consider modern automotive ignition wire that has resistive cores for radio emission purposes.  It has significant ohms/ft. resistance but conducts a great deal of the coil's output to the plugs.
Abstruse1
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
August 04, 2022, 08:50:24 PM
Didik
August 04, 2022, 08:08:09 AM
August 02, 2022, 07:36:07 PM
August 02, 2022, 02:34:46 PM
August 02, 2022, 11:59:53 AM
Davide
August 01, 2022, 10:21:53 PM
August 01, 2022, 06:07:03 PM
July 31, 2022, 10:27:33 PM
July 31, 2022, 08:57:46 PM
July 31, 2022, 06:36:38 PM
ItsChloeUwU
July 31, 2022, 04:56:53 PM
July 31, 2022, 12:14:19 AM
ItsChloeUwU
July 30, 2022, 08:46:44 PM
July 30, 2022, 08:34:09 PM
ItsChloeUwU
July 30, 2022, 01:06:49 PM
July 30, 2022, 10:20:31 AM
July 30, 2022, 10:17:13 AM
July 30, 2022, 04:55:51 AM
ItsChloeUwU
July 30, 2022, 01:34:27 AM
Distilled29
July 29, 2022, 09:58:33 PM
July 29, 2022, 03:18:59 PM
July 29, 2022, 02:52:32 PM
July 29, 2022, 11:53:16 AM
July 29, 2022, 11:03:59 AM
July 29, 2022, 05:50:32 AM
July 29, 2022, 12:51:08 AM
July 28, 2022, 08:57:59 PM
July 28, 2022, 02:19:26 PM
MoonMatthew
July 28, 2022, 01:52:46 PM
July 28, 2022, 12:40:29 PM
MoonMatthew
July 28, 2022, 11:12:50 AM
July 28, 2022, 06:06:58 AM
July 28, 2022, 05:59:17 AM
July 28, 2022, 05:42:54 AM
July 28, 2022, 04:06:37 AM
July 28, 2022, 03:57:19 AM
July 28, 2022, 03:46:15 AM
ItsChloeUwU
July 28, 2022, 03:35:48 AM
post DRSSTC from Aliexpress
ItsChloeUwU
July 28, 2022, 03:27:40 AM
ItsChloeUwU
July 28, 2022, 03:19:17 AM
July 28, 2022, 03:04:48 AM
July 28, 2022, 03:00:59 AM
July 28, 2022, 01:40:37 AM
July 28, 2022, 01:18:31 AM
alex
July 27, 2022, 11:21:13 PM
post Help with TC schematic
MoonMatthew
July 27, 2022, 07:01:22 PM
55#sofcopper
July 27, 2022, 06:15:44 PM
July 27, 2022, 02:17:25 PM
July 27, 2022, 02:10:20 PM
July 27, 2022, 02:07:24 PM
July 27, 2022, 02:01:29 PM
55#sofcopper
July 27, 2022, 08:06:36 AM
July 27, 2022, 05:40:14 AM
farleymartinez
July 27, 2022, 04:37:44 AM
ItsChloeUwU
July 26, 2022, 09:45:49 PM
ItsChloeUwU
July 26, 2022, 09:45:37 PM
ItsChloeUwU
July 26, 2022, 09:44:28 PM
July 26, 2022, 06:00:18 PM
July 26, 2022, 04:22:27 PM
ItsChloeUwU
July 26, 2022, 04:15:51 PM
ItsChloeUwU
July 26, 2022, 04:11:27 PM
July 26, 2022, 03:57:42 PM
July 26, 2022, 08:59:32 AM
Mike
July 26, 2022, 06:08:01 AM
July 26, 2022, 05:51:33 AM
July 26, 2022, 04:41:00 AM
July 26, 2022, 04:24:36 AM
post A big-ish diy xformer
July 26, 2022, 04:10:58 AM
July 26, 2022, 03:48:23 AM
Mike
July 26, 2022, 03:10:06 AM
July 26, 2022, 01:46:12 AM
July 26, 2022, 12:16:12 AM
July 25, 2022, 11:55:33 PM
July 25, 2022, 10:20:45 PM
July 25, 2022, 05:18:07 PM
ItsChloeUwU
July 25, 2022, 03:23:13 PM
Cem888
July 24, 2022, 10:16:27 PM
post HBK-2216 power supply
July 24, 2022, 12:15:54 PM
July 24, 2022, 05:06:32 AM
July 24, 2022, 04:15:16 AM
