Author Topic: 60hz synchronous motor on 50hz?  (Read 6782 times)
Offline paulj
Re: 60hz synchronous motor on 50hz? Yes !!!!
« Reply #20 on: December 31, 2021, 07:19:02 PM »
It's a success, I just started the engine using only two of the three wires.
Without capacitor it starts quite easily but not every time, the stator remains lukewarm without more, on the other hand as I expected, its speed of rotation has been modified.
as evidenced by this picture which was taken under a fluorescent tube at a shutter time of 1/50 s
the position of the axis (golden color) remains constant it is located between 9h and 3h I therefore deduce that this synchronous motor rotating at 3600 rpm in 60 hz, turns at about 3000 rpm in 50 hz.
regardless of the starting position of the rotor, each time the motor is started, the axis always seems synchronized with the frequency of the current, moreover the motor can even start at 50v 80v and even 150 volts (spot test) and this does not even change its speed of rotation.
For the history of the capacitor, I will therefore wait a bit because for the moment helping it to start is not a problem.
CONCLUSION, The 60 Hz synchronous motors are compatible in 50 Hz and are therefore perfectly suited to rotary spark gaps.
« Reply #21 on: December 31, 2021, 09:50:59 PM »
Applause!   Nice stroboscopic picture, without un-necessary effort.  I bet it would not work if the fluorescent light had modern "electronic" ballast.
Let's see if this link works. Fancy line-synchronized LED stroboscope, primitive modification of a shaded-pole induction motor.
https://www.flickr.com/photos/r_k_f/3688448113
« Last Edit: January 01, 2022, 01:06:32 AM by klugesmith »
Offline paulj
« Reply #22 on: January 01, 2022, 06:53:46 PM »
I actually tested on a compact fluorescent lamp which has a transitor ballast, it does not work at all
The strobe effect is even more visible with a discharge lamp.
however, i think the motor draws a little more current in 50hz
Did you make the video? it's fun when the motor is braked it stays synchronous but the mark is not in the same location so it is a hysteresis synchronous motor
« Reply #23 on: January 02, 2022, 01:17:37 AM »
It's not a hysteresis synchronous motor (though my collection includes that kind).
This one has an ordinary induction rotor with two flat places filed onto it.  I guess that makes it a "reluctance synchronous motor". (It would probably work better if the flats were bigger.)
In synchronous operation it has two stable rotation phase angles, 180 degrees apart.
We see both in the video.
I think that behavior would be fine in a SRSG, if the rotor has a conducting bar across whole diameter, and two fixed electrodes 180 degrees apart.
« Last Edit: January 02, 2022, 01:19:41 AM by klugesmith »
post Re: Help an EE student
Today at 08:26:41 PM
Today at 06:54:05 PM
Today at 05:04:41 PM
post Re: Tesla Synth Player for Syntherrupter
AntoineRcbs
Today at 12:13:47 PM
post Re: Help with primary voltages of unknown transformer
Domo
Today at 06:58:12 AM
post Re: New EE student asks about Cutting-Edge fields
Today at 06:47:09 AM
Today at 06:00:49 AM
Today at 05:45:08 AM
Today at 05:03:41 AM
post Re: DRSSTC grounding issues
Today at 04:58:40 AM
Today at 04:36:40 AM
post Re: colored 50 Ohm coax
Today at 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
post Re: Schmitt trigger schematic question
Michelle_
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
post New EE student asks about Cutting-Edge fields
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
Michelle_
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
post Schmitt trigger schematic question
Michelle_
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
Michelle_
May 14, 2024, 05:55:24 AM
Michelle_
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
post Help with primary voltages of unknown transformer
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
OmGigaTron
May 13, 2024, 06:50:59 PM
Michelle_
May 13, 2024, 03:47:08 PM
Michelle_
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
Michelle_
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
Michelle_
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
Michelle_
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
Michelle_
May 12, 2024, 02:51:27 PM
Michelle_
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
Michelle_
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
Michelle_
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
Michelle_
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
May 10, 2024, 09:38:05 PM
Michelle_
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
Michelle_
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
Michelle_
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
Michelle_
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
Michelle_
May 09, 2024, 03:42:49 PM
Michelle_
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
Lasr8
May 09, 2024, 04:45:33 AM
May 09, 2024, 03:56:52 AM
Michelle_
May 09, 2024, 02:16:30 AM
Michelle_
May 09, 2024, 02:00:28 AM
unrealcrafter2
May 09, 2024, 12:48:57 AM
post Re: Capacitor Blowout
radioman
May 08, 2024, 09:04:54 PM
post Question about using mains power and variacs to power this circuit
Michelle_
May 08, 2024, 08:10:41 PM
Michelle_
May 08, 2024, 07:33:43 PM
unrealcrafter2
May 08, 2024, 07:33:31 PM
May 08, 2024, 01:31:28 PM
May 08, 2024, 06:41:48 AM
post Tesla coil amplitude dies after one corona discharge.
Simranjit
May 08, 2024, 05:42:07 AM
