Author Topic: Phase Lead using a RC circuit  (Read 1964 times)
« on: February 23, 2018, 04:47:15 PM »
I was looking at using a potentiometer with a capacitor to adjust phase lead.  I attached a simulation of the circuit, as well as a simulation of the conventional inductor circuit.  It seems to perform similarly, except that the phase lead decreases with frequency rather than increase of course.
Re: Phase Lead using a RC circuit
« Reply #1 on: February 23, 2018, 05:21:25 PM »
Sorry for the double post, but there is a slight improvement here.
Offline Chrisader
« Reply #2 on: August 22, 2021, 11:46:26 PM »
Hi!
Did You check these simulations in reality?
Does results are quite similar like results of simulations?
« Reply #3 on: August 23, 2021, 01:24:51 AM »
Yes, potentiometer adjustment of phase lead is possible.  Given the difficulty some encounter finding suitable adjustable inductors, I'm surprised potentiometer circuits aren't used more often.
This circuit looks workable.  However, it is better to have phase lead increase with increasing frequency.  The ideal is constant time lead to compensate for roughly-constant time delay in the driver and H-Bridge.  Even the normal phase-lead circuit isn't quite constant-time.  Phase lead doesn't quite double at twice the frequency.
The simplest way to make the normal UD2.7 phase-lead potentiometer-adjustable is by trading places of the 51-ohm CT burden resistor R1 with phase-lead inductor L1, so L1 goes to ground.  Then change R1 for a potentiometer, or add a potentiometer across R1, and use the potentiometer center lead to drive the rest of the circuit.
It is also possible to make a capacitor phase-lead circuit where phase increases with frequency.  Easiest with an opamp included.
I built an LRC phase-lead circuit for my DRSSTC that had roughly constant time-lead over my 50-80kHz frequency range.  However, it has a disadvantage of amplitude response peaking, around 120kHz if I recall correctly.  So, I don't recommend copying my circuit.
Offline alan sailer
« Reply #4 on: August 23, 2021, 03:16:04 AM »
The SimpleDriver UD that Eugene makes and sells has a combination L/R and L/C phase adjustment circuit.
It has worked well in two coils I made, a phase shift QCW and a small DRSSTC.
The schematic is here;
http://bsvi.ru/projects/SimpleDriver2/SimpleDriver_2.3.pdf
And the circuit description here;
https://tqfp.org/simple-tesla/simpledriver-v23-in-english.html
By the way, profdc9, thanks very much for the interrupter and UD circuits you made. I found them VERY helpful.
Cheers.
« Reply #5 on: August 23, 2021, 05:38:26 AM »
I'm not spotting any significant capacitor contribution to phase lead.  Looks much like UD2.7 with fixed phase lead.
Offline alan sailer
« Reply #6 on: August 23, 2021, 03:59:16 PM »
David,
When I tuned the phase for my QCW I used the R/C network. It has a trim-pot, R13.
On my latest DRSSTC the trim pot did adjust the phase but not enough. So I changed
out the resistor is series with the inductor to rough tune the phase and then used
the R/C to fine tune the phase.
Both the L/R and R/C networks interact with a large chip (micro processor, ASIC, ?) so I
don't know what is going on from a circuit point of view.*
Eugene also describes this two stage tuning in his manual for the SimpleDriver. So I still claim
(from both documentation and use) that there are two phase tuning sections in this driver.
Whether they would be useful in a more conventional UD is above my pay grade.
Cheers.
* EDIT: It's a PLA.
« Last Edit: August 23, 2021, 10:51:09 PM by alan sailer »
« Reply #7 on: August 24, 2021, 04:53:53 AM »
Alan,
Thank you for the explanation.  I hadn't looked past the input stage where L1 adds phase-lead.  The R19 circuit is adding delay.  Thus L1 needs to add excess phase-lead, then R19... removes some by adding delay.
Adding extra phase-lead and then removing some with delay works, but has a disadvantage.  Ideal phase lead would be constant time independent of frequency (to compensate for fixed driver and bridge delays).  L1 phase lead as measured in time (ns of lead) changes some with frequency.  Making L1 larger (more lead) increases the time change with frequency.  Thus any circuit that uses extra phase-lead and then removes some with delay ends up having more change with frequency.  May be fine.  I'm a perfectionist, so avoid solutions that are sub-optimal.
Offline alan sailer
« Reply #8 on: August 24, 2021, 03:40:27 PM »
David,
Happy that I'm not crazy. In electronics perfectionism is not any thing I can aspire to.
Cheers.
Offline Chrisader
« Reply #9 on: August 26, 2021, 10:45:39 PM »
In mentioned schematic what exactly is responsible for phase lead?
After C1 is marked where is lead but what makes it?
Only C1 and his capacity?
C1 with R4 and their relationship of values?
R3 and C2 paralelly seems to make phase lag, because we have already phase lead after C1?
What for is R7 and why their resistance is so large?
Schematic seems to be matched for single power supply comparator, so it shouldn't be problem to fit for dual power supply comparator?
I want to make simulations in Spice and need to know what in this schematic is necessary to make phase lead...
How simulations are credible in that case where we looking for proper phase lead? We cannot have in reality get ideal conditions of some things like current source, parasitic properties of components etc...
ItsChloeUwU
Today at 07:54:59 AM
Today at 06:44:04 AM
Today at 12:31:43 AM
ItsChloeUwU
ItsChloeUwU
post Go Big or Go Home
[Static Electricity]
ItsChloeUwU
HVuser
post Re: DRSSTC build
post DRSSTC build
ItsChloeUwU
ItsChloeUwU
ItsChloeUwU
Intra
PowerTech
ItsChloeUwU
ItsChloeUwU
huntergroundmind
post Re: Driverless SSTC
ItsChloeUwU
paulj
PowerTech
PowerTech
post Re: Someone built Big TC
patracy
post Driverless SSTC
bismallah
post Re: "Exploding" water
Intra
paulj
ItsChloeUwU
