Author Topic: GDT (Gate Drive Transformer) tutorial  (Read 398 times)
« on: November 28, 2021, 11:40:56 PM »
Hopefully this isn't wasted redundant work.  I've seen many builds with good GDT construction, using both halves of each twisted pair.  However, all the GDT construction guides I've found use a single primary wire.  Below is construction of a half-bridge GDT using two twisted pairs from CAT5 cable.  This is easier to see in pictures.  Extension to full-bridge isn't difficult.  Use four pairs, with four paralleled windings for primary, one wire from each pair.  (BTW, CAT5 isn't necessary.  If starting with single wires, twist pairs together, and use those pairs exactly as you would with pairs extracted from CAT5 cable.)
Start with a suitable high-permeability ferrite core.  (Some options listed at the end.)  The core I'm using here works, although the shape is not typical.  Pay attention to winding technique, not so much to core shape.
Wind two (for half-bridge) twisted pairs around the core.  More discussion about the number of turns to follow.  I'm using 4 turns here.  Mark the starting end of all four wires for later identification.  Here I've "marked" starting ends by length (short), with the tail ends left longer.  Other (preferred) options are to add bits of tape to the starting ends or strip insulation from the starting ends only.
Untwist the pairs almost to the core:
Twist each wire (each winding) with itself all the way back to where the pair twisting starts.  Don't leave any significant loop area of untwisted wire:
Pair one winding of each pair together for the primary.  I've chosen the lighter-color wire of each pair for simplicity, white and light-blue.  Most important: connect the two starting ends (short ends or stripped ends or however you marked them) together, then the two tail ends together.  If pairing is swapped, driver can be damaged by the shorted load.  (Test at very-low duty cycle initially just in case of error.)  The remaining winding of each pair is for an IGBT.  Starting end of one IGBT winding is gate.  Starting end of other IGBT winding is emitter of other IGBT.
Since I hadn't used tape to identify starting ends at the beginning, I added tape now.  Then cut the tail ends to length and strip.  Connect the two primary tail ends together:
The reason for the twisting is to minimize leakage inductance.  Leakage inductance slows down gate waveforms and causes overshoot and undershoot and generally-sloppy gate drive.  Twisting forces the wires to remain close together with little loop area between wires for magnetic field to slip through.  Best to maintain this pairing all the way to the driver for primary and all the way to gate and emitter terminals of IGBTs (or FETs) for the secondaries.  Avoid excess loop area when adding gate series resistors.  Keep the emitter wire adjacent the resistor to minimize loop area.
Now for a bit about cores and turns.  I'll add a second post on measuring cores and finished GDTs, a bit more advanced topic.
Toroid shape is generally preferred, but E-cores work if ungapped (no air gap or spacer between the two halves).
Most important two parameters are:
     Core material (reasonably-high permeability and saturation flux density).
     Core cross-sectional area.  Picture the area of a core slice inside one turn of the GDT winding.
Iron and other compressed-powder cores never work well.  Most (but not all) ferrite materials are OK.
Low-frequency EMI suppression cores are reasonable.  That is what I used above.  Most larger EMI cores are low-frequency, so workable.  This includes common-mode chokes found in power supplies.  (Remove existing windings.)  Such EMI materials include:
3C11, 3E6, 3E12, 3E10, 3E15, 3E25, 3E26, 3E27, 3E65
More ideal ferrite materials are generally designed for switching power supply transformers etc.  These include:
PC40, PC200
N27, N30, N35, N41, N49, N51, N72, N87, N88, N92, N95, N96, N97
T35, T37, T37, T38, T46, T57, T65, T66
3C90 through 3C97
Concerning cross-sectional area, more is better, within constraints of fitting the GDT mechanically into the build.  The core I used above is 28mm long, 14mm ID, 28mm OD.  The ring is 7mm thick (0.5 * (OD - ID)).  So cross-sectional area is 7mm thick * 28mm long = 196mm^2.  If using a more-typical ring toroid, the formula includes a factor of PI/4:  Area = length * 0.5 * (OD - ID) * PI / 4.
In general, look for cross-sectional area to be at 50mm^2 or more.  A bit smaller is fine for high-frequency Tesla coils.  Larger for low-frequency coils.  10 turns is usually plenty.  Excess turns increases wire length and therefore leakage inductance.  The above example is 4 turns.
(All my GDTs have either 2 turns or 3 turns.  That works with large area cores and careful measurement to make sure its enough.  A few more turns is generally safer.  Too many turns causes subtle issues due to leakage inductance.  Too few turns is more catastrophic, possibly damaging the driver and/or IGBTs when the core saturates.)
Here's a great picture from Mads of a full H-Bridge GDT constructed this way:
https://highvoltageforum.net/index.php?topic=1856.msg13969#msg13969
A couple other posts with images that aren't quite as obvious.  For this first, look at the upper GDT wound with CAT5 cable including jacket:
https://highvoltageforum.net/index.php?topic=588.msg3779#msg3779
And this 3-turn GDT from my bridge tutorial:
https://highvoltageforum.net/index.php?topic=1324.msg9886#msg9886
« Last Edit: December 02, 2021, 04:56:06 AM by davekni »
Today at 03:00:04 AM
post Re: Muon Decay
Today at 02:16:57 AM
January 20, 2022, 06:56:35 PM
post Re: Muon Decay
January 20, 2022, 05:19:26 PM
post Re: Muon Decay
January 20, 2022, 03:53:54 PM
post Re: Muon Decay
January 20, 2022, 01:20:19 PM
post Re: Muon Decay
January 20, 2022, 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
post Re: Hi! 811 A tesa coil
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
jpvvv123
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
paulj
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
