Author Topic: help with finding resonant frequency  (Read 147 times)
Offline HVuser
« on: November 18, 2021, 01:28:01 AM »
I am having trouble with finding the resonant frequency on my primary coil. I am using the method in the book The Ultimate Tesla Coil Design and Construction Guide. It uses signal generator with 1k ohm resistor to the coil. I have tried series and parallel capacitor to lower the theoretical resonant frequency, although I still can't find it. I even added the LEDs to visually see if the coil is in resonance. See the included image to see the setup. I am using function generator producing sine-wave at 2 volts. The highest capacitor I have is a 10 uF ceramic. The primary is 4.4 uH measured with cheap LCR meter. Together I would expect the theoretical resonant frequency to be around 23.99 kHz. What I am finding is I have not reached the resonant frequency at 12 MHz (maximum of my function generator). I found a video that was the same setup here https://www.youtube.com/watch?v=DF6WdTM8s4U. I have used lower capacitors, tried my secondary coil instead of primary, verified continuity/connecting wires and all the same results. What else can I try?
« Last Edit: Today at 04:30:28 AM by HVuser »
Offline thedoc298
Re: help with finding resonant frequency
« Reply #1 on: November 18, 2021, 05:10:43 AM »
This works for me.
« Reply #2 on: November 18, 2021, 06:44:13 AM »
Circuit shown in first post is not complete.  One side of the capacitor has no connection.  Posting a complete circuit would help.
LEDs in series with a 2V signal generator output may block any signal.  Depending on color, LEDs typically take more than 2V to conduct anything.
Don't waste time checking way beyond expected frequency.  Calculate frequency based on measured values, then sweep carefully and slowly through that frequency, at most from 0.5x to 2x frequency.  Issue is more likely missing resonance by sweeping too fast through it.
Offline HVuser
« Reply #3 on: Today at 04:43:39 AM »
Thank you thedoc298 and davekni for all the suggestions, and my apologies for not updating sooner. I increased the voltage and the LEDs did light up.  I updated the photo to include the steps I tried. After using the formula for the coil dimensions I was able to find the close to the resonant frequency. The LCR meter must be way off as the coil is very low inductance. The primary coil is way off what I need with my capacitor as I assumed the LCR meter was close (whoops). My plan is to make a new primary coil and if I did it correctly the coil will resonate.
HVuser
Today at 01:37:46 AM
post Re: DRSSTC build
post DRSSTC build
balazs
PowerTech
huntergroundmind
post Re: Driverless SSTC
PowerTech
PowerTech
post Re: Someone built Big TC
patracy
post Driverless SSTC
bismallah
post Re: "Exploding" water
Kamui
post "Exploding" water
