Author Topic: Coulometric hourmeters  (Read 680 times)
« on: May 27, 2024, 08:26:11 AM »
Storage space cleanup revealed a gadget I made about 20 years ago, to demonstrate a "Curtis" type hourmeter.
Full scale in this one is 2500 hours when connected to 12 volts DC.
A glass capillary tube contains a tiny slug of clear electrolyte between two columns of mercury metal.
Last Thursday I replaced the broken 9-volt battery connector, then plugged in a battery to start the clock.
Initial battery voltage is 9.09 V, with 7.48 V across the hourmeter and 1.61 V across the indicator LED.
Current is about 80 microamps.  In a few days we will be able to see how fast the gap is moving, and in which direction.
This gadget was reported at 4hv forum in 2009.
https://4hv.org/e107_plugins/forum/forum_viewtopic.php?p=1&id=77016
« Last Edit: May 28, 2024, 11:06:24 PM by klugesmith »
Re: Coulometric hourmeters
« Reply #1 on: May 28, 2024, 11:30:50 PM »
When re-commissioning the demonstration, I guessed at the meter polarity.
Now we see it's "wrong".
In 4.75 days, the gap moved from about 518 hours to about 450 hours on the scale.
The indicated change is -68 hours,  actual elapsed time 114 hours, ratio -0.60.
Consistent with applying -7.2 volts to a 12 volt meter.  We have used about 9 mAh of the battery capacity.
Let's run it backwards for a few more days, and see what happens to the irregularities on mercury column between 350 and 400 on the scale.
[edit] p.s. How do you like that LED at 80 microamps?   I bet we could read a book by its light, in spot diameter of 1 or 2 inches.
« Last Edit: May 28, 2024, 11:39:27 PM by klugesmith »
« Reply #2 on: June 04, 2024, 10:31:58 PM »
I came here with a question for some applied physics expert, after looking up the number density of conduction electrons in mercury. Then figured it out while typing the question.  Here presented for review.
The only reference I've found is a table at hyperphysics website: http://hyperphysics.phy-astr.gsu.edu/hbase/Tables/fermi.html#c2.
That cites a venerable solid-state physics textbook by Ashcroft and Mermin.
The value for copper is familiar from drift velocity presentations all over the place:  8.47e22 free_electrons/cm^3.
The values given for Al, Fe, Cu, Ag, and Hg are 3.00, 2.00, 1.00, 1.00, and 2.13 times the atom number densities I computed for the metals.
Why the non-integer ratio for Hg?   It's listed in table as Hg**, and the double asterisk refers to a unique note "at 78K".
6.5% seemed like a lot for thermal contraction between room temperature and 78 K, but I think it's the real explanation.
Most of the factor is from liquid to solid transition.  The remainder is from change in specific volume, which is always 3x greater than linear dimension change in a solid.  How do they even measure mobile charge density except by Hall effect?  In metals that's a challenge even with very thin films, because density of mobile charge is high, so its velocities are low. (Hall established that its sign is  usually negative, long before electrons were discovered.)
Here is the hourmeter picture near end of day 12.
We've run about 20 mAh through the instrument, so far. 73 coulombs.  If it all went through the electrolyte, we have transferred 5 cubic millimeters of Hg.  I think the capillary ID is too narrow for that, especially considering the optical magnification from thick glass tube.  Must remember to get it x-rayed at my next visit to dentist.  There might be a current divider inside the black box, but what purpose would that serve, compared to just using a higher value metering resistor for 12 volt service?
« Last Edit: June 05, 2024, 01:49:00 AM by klugesmith »
« Reply #3 on: June 08, 2024, 05:38:14 AM »
After 15 days of this experiment, I made some dimensional measurements.
Concluded that of the 71 uA in meter, only about 3 uA is going through mercury and electrolyte -- the rest has another path inside the black box.   Turns out I'd reported the same numerical answers in that old 4hv post from 2010!  In which this specimen is called "the Russian meter".
The 2500-hour scale is 40 mm long, so the nominal speed of visible gap (and speed of drifting electrons in liquid Hg) is 0.016 mm per hour.   That's a little more than 1 cm per month.   The day-of-month wheel in a mechanical watch moves faster, but the high digits in a mechanical odometer move slower.
Each cubic mm of mercury represents 13.03 coulombs of what Faraday called "electricity" 200 years ago.
So for nominal speed we need 57.9 amperes per square meter, 57.9 microamps per square millimeter.
Apparent diameter of capillary bore is 0.35 mm, for area of 0.096 mm^2, so it needs only 5.6 microamps, about 5% of what the instrument draws at 12 volts. (Measured resistance between terminals is 102.5 kΩ.)
Of course our view of capillary ID is magnified by the cylindrical glass OD.   Has anyone here ever run the optics numbers (lens formula) to get a factor for that?
[edit] Battery voltage is down to 8.79, meter voltage 7.18, after 15 days and 26 mAh.   Zinc anode metal in each battery cell is being depleted much faster than the mercury on left side of gap.
« Last Edit: June 08, 2024, 05:44:58 AM by klugesmith »
Today at 07:43:37 PM
Today at 04:52:08 PM
Today at 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
June 12, 2024, 10:23:08 PM
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
[Static Electricity]
June 12, 2024, 06:57:13 PM
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
vK
June 12, 2024, 03:42:18 AM
post Re: Bigger sparks?...
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
post Re: Benjamin's DRSSTC3
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
June 09, 2024, 05:44:29 PM
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
post Interrupter for SSTC
June 08, 2024, 12:47:47 AM
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
June 07, 2024, 05:08:00 AM
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
June 05, 2024, 11:11:17 PM
June 05, 2024, 10:18:57 PM
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
June 05, 2024, 08:46:53 PM
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
June 05, 2024, 01:42:04 AM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
June 02, 2024, 04:51:58 PM
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
June 01, 2024, 08:22:28 PM
June 01, 2024, 03:56:53 AM
Terry
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
May 30, 2024, 11:50:06 PM
post First DRSSTC questions
Hi-Deff
May 30, 2024, 11:23:35 PM
May 30, 2024, 10:43:06 PM
May 30, 2024, 10:24:35 PM
May 30, 2024, 06:10:04 PM
May 30, 2024, 04:56:11 PM
May 30, 2024, 04:48:05 PM
May 30, 2024, 04:37:22 PM
May 30, 2024, 04:16:31 PM
May 30, 2024, 03:34:10 PM
May 30, 2024, 02:53:50 PM
May 30, 2024, 12:44:47 PM
post SSTC tripping circuit breaker
May 30, 2024, 07:52:56 AM
May 30, 2024, 07:07:53 AM
May 30, 2024, 07:04:40 AM
May 30, 2024, 05:16:50 AM
May 30, 2024, 05:08:17 AM
May 30, 2024, 04:29:30 AM
May 30, 2024, 03:52:36 AM
May 30, 2024, 03:47:12 AM
May 30, 2024, 03:41:34 AM
