Author Topic: current transformers  (Read 599 times)
Offline thedoc298
« on: October 04, 2024, 10:25:43 PM »
I am using 3 current transformers 1000:1                     one for phase, one for ocd or current and the third for a scope to monitor.    Should the phase and ocd be in phase together and for the scope connection would I need some value of a load..?    I had them in phase and then I trimmed the wires and lost track.   Thanks
Offline flyingperson23
  • noob :)
Re: current transformers
« Reply #1 on: October 05, 2024, 12:15:59 AM »
I don't think the ocd and phase CTs need to be in phase. You probably want some sort of load (ie resistor) for the scope connection
Offline thedoc298
« Reply #2 on: October 05, 2024, 06:20:55 AM »
Thanks for feedback.
« Reply #3 on: October 05, 2024, 09:14:48 AM »
OCD feedback signal is converter to a DC level signal for the op-amp/comparator, so phasing does not matter. It could properly only mean if you switch off a single cycle later.
Load your monitor CT with the same shunt resistor as your phasing CT. So you see the same signal as your driver uses for ZCS.
Offline thedoc298
« Reply #4 on: October 05, 2024, 08:50:55 PM »
That is a good idea never gave that a thought, thanks. So close for test firing, be sending some videos soon
« Reply #5 on: October 05, 2024, 09:42:27 PM »
Yes, I can see an advantage to that.  Or scope across CT burden resistor of driver.
There is one advantage to using a lower burden resistance for scoping, such as 10 ohms instead of 51 ohms of standard UD2.7.  In case CT inductance is low enough to add significant phase lead, scope measurement would be closer to actual current phase.
noahbmaker
post Re: Big Coil Build Log
shBLOCK
dejuli2
post Re: Push Pull VTTC
myoniwy
myoniwy
Beggernator.
Mr.Cas
Beggernator.
Simranjit
Simranjit
