Author Topic: Air cored inductors proximity to conductive objects  (Read 145 times)
Offline John123
  • All the gear, no idea. UK
« on: November 23, 2022, 01:10:17 AM »
Can air cored inductors be influenced by proximity to other conductive things such as heatsinks even if nothing actually enters the inside of the windings? I'm talking about simple ones such as this:
Re: Air cored inductors proximity to conductive objects
« Reply #1 on: November 23, 2022, 04:44:20 AM »
Yes, but much less so than similar ferrite-core inductors.  With air-core, most of the magnetic reluctance is where field is concentrated through core center.  With lots of area for field to return outside of the coil, blocking some of that return path has only a tiny effect.  Unless you block much of it, such as if you milled a slot in a heatsink and placed it over the coil blocking most field return paths.
Offline Twospoons
« Reply #2 on: November 23, 2022, 09:29:01 AM »
It would be very dependent on the aspect ratio of the coil - long skinny vs wide flat.  This is how basic metal detectors work, after all, by using a wide flat coil.
Offline John123
« Reply #3 on: November 23, 2022, 11:27:18 PM »
Thanks Dave, here's some photos of it. Excuse the messy amateur DIY construction.
It's a single layer coil measuring 32.5mm x 15mm and about 26 turns of litz wire (was aiming for a couple uH). It's 12mm at its closest point from the grounded heatsink. Flying blue wire is circuit ground.
« Last Edit: November 23, 2022, 11:30:29 PM by John123 »
« Reply #4 on: November 24, 2022, 03:02:11 AM »
Looks fine.  Heat sink should have negligible effect on inductance of coil with that geometry.
post Re: IF D95T vs IF D95OC
RoamingD
Today at 06:56:51 AM
Solhi
Solhi
Solhi
AkashaStar
Solhi
post Re: Vacuum pump
Kirby4life
RickNitro
Solhi
LoOdaK
post Re: Trichel pulses
post Trichel pulses
mthome4
Solhi
post Re: Plasma Toroid
prabhatkumar
Solhi
AkashaStar
dru
Solhi
prabhatkumar
post Re: Non-laser pointer
post IF D95T vs IF D95OC
RoamingD
Solhi
post Non-laser pointer
post Buck converter question
dru
Solhi
November 17, 2022, 03:26:32 AM
November 16, 2022, 11:23:37 PM
November 16, 2022, 08:00:54 PM
November 16, 2022, 05:09:00 PM
November 16, 2022, 04:57:27 PM
post TV flyback number of primary turns rule of thumb
November 16, 2022, 03:27:06 PM
November 16, 2022, 03:16:13 PM
post Bluetooth to aux for plasma speaker circuits
November 16, 2022, 03:00:54 PM
Solhi
November 16, 2022, 11:43:49 AM
post Re: Electrical resistance cooking
November 16, 2022, 09:00:46 AM
November 16, 2022, 08:53:42 AM
November 16, 2022, 05:45:24 AM
November 15, 2022, 08:17:46 PM
November 15, 2022, 07:25:04 PM
post Re: Yet another UD2.x pulse skipper
November 14, 2022, 12:26:19 PM
November 14, 2022, 04:57:41 AM
November 14, 2022, 12:32:54 AM
post Vacuum pump
November 13, 2022, 11:06:55 PM
November 13, 2022, 06:32:11 PM
November 13, 2022, 04:41:20 PM
post Re: QCW questions
November 13, 2022, 02:38:41 PM
November 13, 2022, 05:23:09 AM
November 12, 2022, 10:39:21 PM
November 12, 2022, 12:45:16 PM
November 12, 2022, 05:44:35 AM
November 12, 2022, 05:30:10 AM
November 12, 2022, 01:11:31 AM
November 12, 2022, 12:42:54 AM
