Author Topic: Ultra-High Temperature Carbon Fiber for Drones/Rockets  (Read 970 times)
  • Guest
« on: March 14, 2022, 11:02:49 PM »
I need you guys to check my "crazy factor" on this one.
I've been looking at high speed aircraft and rockets or jets and the areas that normally are just too hot from traditional fiberglass or carbon. Typically epoxy or polyester doesn't survive much past 450 degrees. The carbon and glass fibers themselves certainly will, but with a damaged matrix the fibers just go limp and the structure collapses, not ideal at Mach 2.2 in the mid-atmosphere.
So my mind jumped to intumecents used in buildings for fire protection while "Integza" was able to make a carbon fiber tube for a pulse jet https://www.youtube.com/watch?v=hk-fXjkV0ho I began to see issues with long term structure and repeatable builds using the gray intumecent method seen below.
With that background I came up with a solution using a carbon fiber and water-glass matrix.  I guess Ill call it CF-Na2SiO3 i dont know what other formal notation would be used.
But the method involves layers of the common CF layed up in the desired shape then wet out with water-glass solution of Na2SiO3. The following pictures show the initial prototype sample.
I have a thermocouple up to 1800 degrees F and a ring stand waiting. There have been some failures, those are seen below too.
So any thoughts on my crazy idea ?
UPDATE: The clear soda glass CF is physically dry, but softish. I'm going to heat it with a thermocouple and report back.
« Last Edit: March 14, 2022, 11:05:04 PM by Patrick »
Offline Twospoons
Re: Ultra-High Temperature Carbon Fiber for Drones/Rockets
« Reply #1 on: March 15, 2022, 05:14:03 AM »
You might want to look into phosphate bonded ceramics as a binder, if the sodium silicate doesn't perform. Also polyimide resins are commonly used as a high temperature binder - though obviously more expensive than silicate.  Between polyimide and epoxies there's also phenolic resin - which is thermosetting I believe.
You  might do better posting this at https://www.sciencemadness.org/whisper/
Offline rikkitikkitavi
« Reply #2 on: March 15, 2022, 10:02:47 AM »
Wasn't thermosetting phenolic resins early adaptations of ablation shields on reentry vessels.
Tougher than that, I Dont know what is?
Perhaps the pusher plate on the Orion starship.
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
post Re: Kaizer VTTC 1
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
Alberto
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
Michelle_
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
