Author Topic: Phase Lead Tuning without differential probes?  (Read 1638 times)
Offline GrantV
« on: April 09, 2021, 01:37:33 PM »
Hi there,
Is it possible to do phase lead tuning (UD2.7C) using a scope without differential probes?
Yes, I am feeding my inverter from a isolation transformer and my scope is mains powered. As such I am ok with scoping the EC on one of my IGBT's but do not know what to do about the current sense scope lead hookup?
« Last Edit: April 09, 2021, 06:04:37 PM by GrantV »
Re: Phase Lead Tuning without differential probes?
« Reply #1 on: April 09, 2021, 08:24:55 PM »
Current sense should be via a CT (current transformer), with no galvanic connection = already isolated. Use the same CT setup as you use for feedback except with 10 ohms or something across the output as a burden (measure the voltage across this with the scope, output will be input current * burden resistance / CT turns ratio).
You don't actually need to isolate the inverter to scope the voltage either (especially if it's a voltager double config with neutral feeding the capacitor centre-point), just scope from earth to the bridge output with a 100x probe and you'll see enough to tune the phase lead (output may be riding ontop of a mains voltage however, depending on the rectifier setup).
Offline Da_Stier
« Reply #2 on: April 09, 2021, 08:28:46 PM »
Not quite a real answer but if you have a somewhat modern scope you could use two channels and a math trace to show A-B for a differential signal.
Like this you could avoid using a differential probe.
« Reply #3 on: April 10, 2021, 04:14:05 AM »
If you are using UD2.7 or similar, you can scope across R1 (the 51-ohm feedback CT load resistor on the UD2.7 ECB) to measure current.  That along with Vce of one of the low-side IGBTs is all you need.
Often you can see the IGBT switching glitch capacitively-coupled to the current signal across R1 when phase lead is insufficient.  There are usually much worse switching spikes when phase is lagging, as IGBT diodes are conducting when the opposite IGBTs turn on, forcing rapid reverse-recovery of the diodes.  It is often possible to adjust phase lead looking at only the current signal by monitoring the switching glitch position and amplitude.
Offline GrantV
« Reply #4 on: April 11, 2021, 11:23:47 AM »
Hi guys,
Hydron, Da_Stier and Dave, thank you very much for your answers! That is exactly the info I was looking for :-)
Really just wanted to make sure that I was on the right track and not about to blow my scope  ;D
Should have some sparks soooon!
post Re: Big Coil Build Log
Today at 05:47:34 AM
post Re: capacitor and diodes. Voltage values for a CW
Today at 04:45:07 AM
Today at 04:18:27 AM
post Push Pull VTTC
janno288
Today at 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
Michelle_
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
March 16, 2024, 08:46:20 PM
post Re: Bleeder resistor for MMC
March 16, 2024, 08:39:24 PM
March 16, 2024, 08:21:44 PM
post Best forum for vacuum tube amplifiers?
March 16, 2024, 08:20:13 PM
