Author Topic: Using metallized film caps instead of foil caps in MMC  (Read 1012 times)
Offline NickyLee
« on: May 28, 2023, 06:55:34 PM »
Hello everyone, this is my first time visiting this forum so please excuse and correct any etiquette oversights on my part.
I would like to collect some opinions on using metalized film capacitors in MMCs.
I have heard using them is a no-no for reliability reasons, but I have also seen builds that use them. I would love to be able to use them for my build for budget reasons, but I know that choice will probably come back and bite my a** later. The bank would be about .02uf and around 25-30kv rated. JavaTC says the coil will resonate at about 115kHz if that's important. I can share other coil info if needed.
If people have experience or stories of using metalized film caps instead of foil caps please share them. Any input is appreciated
Offline Twospoons
Re: Using metallized film caps instead of foil caps in MMC
« Reply #1 on: May 28, 2023, 11:37:12 PM »
The problem with met-film is that high peak currents can burn away the metalization from the end connection. If you have an I2t rating for your caps, and you know the voltage and frequency of operation, you can check your peak current will be within limits.  Be aware that supplied I2t generally assumes a half-sine pulse at 50 or 60 Hz, which may not be valid for high frequencies.  I would recommend derating.
Some years back I was working designing electric fence energisers, using 1200V met-film caps. Based off the I2t from the manufacturer, everything should have been within spec, but after a week of running my prototypes died - because the end termination had burnt away inside the caps. After talking to the manufacturer, describing the issue and our application, they revised the I2t down by almost 50%.   The difference was our circuit was draining the caps in a 100us pulse, not the 10ms half sine assumed by the original rating.
Offline NickyLee
« Reply #2 on: May 30, 2023, 04:05:35 AM »
Thank you for your input.
The caps I'm looking at (R76TN31505050J) have no mention of an I2t rating but they do have a non-repeated max pulse current of 450A. I'm planning on running 3 strings in parallel in my MMC for a combined max pulse rating of 1350A. JavaTC estimated the peak pulse current to be around 230A, so hopefully that is enough margin for some amount of fun before failure.
« Reply #3 on: May 30, 2023, 04:06:53 AM »
Depends greatly on the particular capacitor.  As Twospoons recommends, check capacitor specifications.  RMS current capability is key, and peak current (peak CdV/dt).  Some capacitors are combinations of foil and film.  And, of course, polypropylene dielectric.
If you have the luxury of access to a thermal imager, test a capacitor with high frequency AC current.  Good ones will be relatively cool overall, with warmest part in the middle, since leads provide some heat sinking.  Bad film parts (with poor connections to end of foil roll) will be hot at ends by leads.
Instead they have a V^2/t rating, of 9.6E12 V^2/second for that part.  Multiply by C^2 (by 0.15E-6 ^ 2) to get I2t.
RMS current is listed as 16A, down to 6.3A at 85C.  That may be most limiting specification.  Depends on your planned duty cycle and cooling.  And on desired life time.  Specifications are generally for commercial use where caps are expected to have good reliability for long term product use.  TCs are often used for only a few hours during their entire existence.
« Last Edit: May 30, 2023, 04:21:30 AM by davekni »
Offline NickyLee
« Reply #4 on: June 03, 2023, 09:57:35 PM »
I plugged everything as best I could into the Kaizer Power MMC calculator and everything looks good. All the power parameters have a SF of 2.1 or (much) greater, and the single cap temperature rise is 4.4 C.
Today at 04:52:08 PM
Today at 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
June 12, 2024, 10:23:08 PM
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
[Static Electricity]
June 12, 2024, 06:57:13 PM
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
vK
June 12, 2024, 03:42:18 AM
post Re: Bigger sparks?...
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
post Re: Benjamin's DRSSTC3
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
June 09, 2024, 05:44:29 PM
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
June 08, 2024, 05:38:14 AM
post Interrupter for SSTC
June 08, 2024, 12:47:47 AM
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
June 07, 2024, 05:08:00 AM
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
June 05, 2024, 11:11:17 PM
June 05, 2024, 10:18:57 PM
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
June 05, 2024, 08:46:53 PM
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
June 05, 2024, 01:42:04 AM
June 04, 2024, 10:31:58 PM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
June 02, 2024, 04:51:58 PM
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
June 01, 2024, 08:22:28 PM
June 01, 2024, 03:56:53 AM
Terry
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
May 30, 2024, 11:50:06 PM
post First DRSSTC questions
Hi-Deff
May 30, 2024, 11:23:35 PM
May 30, 2024, 10:43:06 PM
May 30, 2024, 10:24:35 PM
May 30, 2024, 06:10:04 PM
May 30, 2024, 04:56:11 PM
May 30, 2024, 04:48:05 PM
May 30, 2024, 04:37:22 PM
May 30, 2024, 04:16:31 PM
May 30, 2024, 03:34:10 PM
May 30, 2024, 02:53:50 PM
May 30, 2024, 12:44:47 PM
post SSTC tripping circuit breaker
May 30, 2024, 07:52:56 AM
May 30, 2024, 07:07:53 AM
May 30, 2024, 07:04:40 AM
May 30, 2024, 05:16:50 AM
May 30, 2024, 05:08:17 AM
May 30, 2024, 04:29:30 AM
May 30, 2024, 03:52:36 AM
May 30, 2024, 03:47:12 AM
May 30, 2024, 03:41:34 AM
May 30, 2024, 03:27:28 AM
