Author Topic: Flanging sound coming from DRSSTC  (Read 210 times)
Offline Coileone
« on: May 12, 2022, 10:05:32 PM »
Good Afternoon,
I'll try my best to describe this as accurate as possible.
When I turn up my pw to around 500-800 us @ 50 bps, I begin to hear a flanging sound. The sound starts out with a higher pitch flanging sound and progresses to a lower pitch as I turn up the pw further. At around 700-1ms, the sound is gone and doesn't return if I continue to increase the pw further.
The same thing happens with 150bps, but the sound starts earlier.. at a lower pw.. not sure exactly but id say between 100-400us? It also has the same behavior as above.
The sound is NOT coming from the streamers.
My output has the longest arcs right before the flanging sound starts. The output still increases as I turn up the pw, but mainly thicker streamers, not length.
Does anyone have a similar experience as this? It doesn't seem to be an issue, but it could be. Idk.. I would just love to understand why its doing it.
Not sure if this will help, but here are the specs:
6 x 28 secondary 27awg 1550turns ish
6 x 28 Toroid
95khz ish res freq
3/8" Flat Copper Primary tapped around 6.5 turns
6s/13p 325nf 12kv MMC (78 CDE .15uf @ 2kv)
(2) CM400-12 Full Bridge
(2) 4700uf parallel = 9400uf @ 450v bus caps
208v In - 290vdc bus
UD 2.7C w/ OCD @ 1000amps
EVR Interrupter 1.0
Thank you for taking the time to read this. Hope all is well!
Kyle
Re: Flanging sound coming from DRSSTC
« Reply #1 on: May 13, 2022, 01:57:25 AM »
Can you post an audio recording of the "flanging sound" of which you speak?
« Reply #2 on: May 13, 2022, 06:16:20 AM »
Scoping current waveforms before and after onset of "flanging sound" might also help.  Even better would be both current and H-Bridge output (or UD2.7 output to GDT if you don't have isolated or differential probes).
Offline Coileone
« Reply #3 on: May 13, 2022, 02:09:23 PM »
Sure! It starts around 4-5 seconds into it.
https://youtube.com/shorts/hJkYXoYHmwE?feature=share
Offline Coileone
« Reply #4 on: May 13, 2022, 02:13:19 PM »
Ok. I will try that. Thank you for your feedback.  :)
« Reply #5 on: May 13, 2022, 09:28:35 PM »
I think that is just a artifact of matching on-time / breakrate that produces some overtone or harmony like situation.
You are running very long on-time and when you say its there at 50 Hz and 150 Hz, you are at the fundamental and harmonic frequencies of the mains supply frequency? It could be that you are discharging right where your DCbus is being charged, if DCbus capacitance is too low, you could get some harmonic induced ramping going on.
« Last Edit: May 13, 2022, 11:53:26 PM by Mads Barnkob »
« Reply #6 on: May 13, 2022, 11:06:50 PM »
Agree with Mads.  I don't see or hear anything indicating a problem.  Might be a transition where the base of the previous arc is hot and ionized enough to make the next enable pulse start immediately with significant arc length.  If bridge voltage and current are still properly phased (ideally bridge output voltage switching slightly before current zero-crossing), it should be fine.
Offline Coileone
« Reply #7 on: May 14, 2022, 06:12:32 PM »
Oh, I don’t feel there’s any issue. My post was to learn and understand more about the coil and why certain things do what they do etc. Thank you
Offline Coileone
« Reply #8 on: May 14, 2022, 06:15:59 PM »
It’s there between those freq. That’s the lowest and highest bps settings on my interrupter. My bus capacitance is 9400uf so I kind of assumed that was plenty unless I’m mistaken?
I will agree it does sound like something harmonic related.
Not sure if this is relevant but the sound begins when my bus voltage drops to 265-270v
Range4Harry
May 16, 2022, 11:25:14 PM
Robert3z
May 16, 2022, 02:21:11 PM
CwhyteKGMS
May 16, 2022, 07:29:15 AM
May 16, 2022, 04:53:18 AM
May 16, 2022, 04:36:44 AM
CwhyteKGMS
May 16, 2022, 03:53:48 AM
Robert3z
May 16, 2022, 02:20:58 AM
post Re: Problem with SSTC
May 15, 2022, 11:59:37 PM
Nunu00
May 15, 2022, 11:08:49 PM
May 15, 2022, 09:43:07 PM
post Re: Kaizer DRSSTC 3
May 15, 2022, 08:22:11 PM
Nunu00
May 15, 2022, 08:03:13 PM
May 15, 2022, 07:49:51 PM
Nunu00
May 15, 2022, 06:58:45 PM
May 15, 2022, 06:47:53 PM
May 15, 2022, 04:13:02 PM
Nunu00
May 15, 2022, 02:38:18 PM
May 15, 2022, 03:53:35 AM
post Bipolar CW
May 15, 2022, 03:46:25 AM
May 15, 2022, 03:40:42 AM
[Static Electricity]
May 15, 2022, 02:06:53 AM
May 14, 2022, 10:26:32 PM
Nunu00
May 14, 2022, 09:52:06 PM
May 14, 2022, 09:25:23 PM
Nunu00
May 14, 2022, 08:14:38 PM
May 14, 2022, 08:02:22 PM
Coileone
Coileone
post Problem with SSTC
Nunu00
May 14, 2022, 05:18:16 PM
post Re: Wago "Lever Nuts"?
May 14, 2022, 03:24:48 PM
May 13, 2022, 09:24:22 PM
Coileone
Coileone
Coileone
May 12, 2022, 09:41:04 PM
post Re: Thermometers
May 12, 2022, 09:33:38 PM
May 12, 2022, 09:27:40 PM
Robert3z
May 12, 2022, 02:13:03 PM
May 12, 2022, 06:39:55 AM
May 12, 2022, 06:27:47 AM
May 12, 2022, 06:22:48 AM
post Wago "Lever Nuts"?
May 12, 2022, 04:32:19 AM
post Re: Transistor choice
May 12, 2022, 03:32:22 AM
May 12, 2022, 12:00:11 AM
May 11, 2022, 09:53:15 PM
post Kaizer DRSSTC 3
May 11, 2022, 09:40:00 PM
CarldeLevis
May 11, 2022, 09:39:21 PM
post Thermometers
May 11, 2022, 09:36:59 PM
Nicolas
May 11, 2022, 09:29:45 PM
post Re: Litz Wire?
May 11, 2022, 08:45:57 PM
May 11, 2022, 08:43:38 PM
CarldeLevis
May 11, 2022, 05:44:40 PM
May 11, 2022, 04:17:34 PM
Robert3z
May 11, 2022, 03:10:27 PM
May 11, 2022, 01:46:57 PM
Robert3z
May 11, 2022, 12:37:19 PM
May 11, 2022, 11:33:30 AM
May 11, 2022, 11:00:59 AM
May 11, 2022, 06:30:45 AM
May 11, 2022, 06:11:08 AM
post Re: Litz Wire?
May 11, 2022, 04:00:41 AM
Robert3z
May 11, 2022, 02:06:34 AM
May 10, 2022, 07:52:45 PM
Nicolas
May 10, 2022, 10:04:27 AM
May 10, 2022, 09:31:39 AM
post Re: Litz Wire?
May 10, 2022, 09:29:19 AM
May 10, 2022, 09:23:38 AM
May 10, 2022, 07:24:33 AM
post Transistor choice
May 10, 2022, 03:33:10 AM
post Litz Wire?
May 10, 2022, 03:16:29 AM
May 09, 2022, 07:41:51 AM
May 09, 2022, 05:39:51 AM
May 09, 2022, 12:44:13 AM
Nicolas
May 09, 2022, 12:24:37 AM
Nicolas
May 09, 2022, 12:21:40 AM
May 09, 2022, 12:13:01 AM
post Re: QCW questions
May 08, 2022, 06:43:31 PM
May 08, 2022, 07:43:13 AM
May 07, 2022, 07:59:36 PM
Robert3z
May 07, 2022, 06:41:41 PM
post Re: Capacitor Esoterica
May 07, 2022, 05:57:22 PM
May 07, 2022, 03:43:57 PM
May 07, 2022, 03:21:16 PM
May 07, 2022, 06:52:29 AM
May 07, 2022, 04:57:41 AM
May 06, 2022, 08:54:52 AM
May 06, 2022, 02:54:44 AM
Dhaygoh
May 05, 2022, 05:26:27 PM
Dhaygoh
May 05, 2022, 05:14:32 PM
May 05, 2022, 06:29:00 AM
May 05, 2022, 05:56:01 AM
May 05, 2022, 05:11:45 AM
May 05, 2022, 04:37:42 AM
May 05, 2022, 04:19:47 AM
May 04, 2022, 11:22:09 PM
May 04, 2022, 11:04:19 PM
