Author Topic: Kaizer DRSSTC 3  (Read 219 times)
Kaizer DRSSTC 3
« on: May 11, 2022, 09:40:00 PM »
I started construction on my large DRSSTC on the 24th of December 2011. What followed was a long journey of building, sourcing materials, becoming a father and at some point reach first full power light on the 31st of March 2016. A 4++ year long journey!
Bridge2x CM600DU-24FA IGBTs in a full bridge configuration
Bridge supply4x 6000uF 350V filtering capacitors, two in series, two string in parallel for 6000uF at 700V.
Primary coilFlat primary. Inner diameter 375 mm, Outer diameter 855 mm. 8 turns 10 mm copper tubing, turn spacing 20 mm
tapped at 6.75 turns.
MMC0.8uF at 15kV. Made from GTO snubber capacitors. 5 in series.
Secondary coil315 mm diameter, 1500 mm long, 1800 windings, 0,75 mm enamelled copper wire.
Resonant frequencyAround 38 kHz.
Topload7 rings of 25 mm aluminium tubing forming a 150cm diameter toroid.
Input power3x400VAC 16A / 11kW
Spark length3.6 meters
First full power light (31st of March 2016)
Kaizer DRSSTC 3 - Test After 5 Years In Storage (6th of May 2022)
Re: Kaizer DRSSTC 3
« Reply #1 on: May 11, 2022, 09:53:15 PM »
Camera as time machine!   Nice work.
We share enthusiasm for transporting large things by bicycle.  In about 1994 I stopped at a garage sale an hour away from home. Found and bought more than 50 pounds of lead metal, and got it all home in panniers and taped onto the rear rack.
Re: Kaizer DRSSTC 3
« Reply #2 on: May 13, 2022, 09:24:22 PM »
We had a good session with trying out some different interrupters, targets and lighting around the coil, for filming. Darkness did however surprise us a bit and it was hard to adjust lighting and run the coil at once, so a bit noise filled videos.
It was most of the time pulling around 5-10 kW, peaked out at 19kW with a quite insane BPS that I quickly turned down again as the 3 meter sparks was turning into a flame, it had that flicking change in sound as when sparks goes into full plasma flame. The measurements in the video is from a Merlin Gerin PM700 power meter.
The coil was, the whole time, fed through the 3 Phase 400 VAC 6 A Variac Stack With Voltage/Current Meters ( https://highvoltageforum.net/index.php?topic=2015.0 ) which did not even get warm to the touch.
The future holds a collaboration with ChaosEngine https://www.chaosengine.dk/ and https://www.instagram.com/chaos.engine/ where we will combine art and electricity in some way
Re: Kaizer DRSSTC 3
« Reply #3 on: May 15, 2022, 03:53:35 AM »
Variac wipers are often hot spots, causing the winding to fail at the wiper setpoint.  Not sure if checking overall Variac temperature is a good way to judge margin for short-term overload.
Impressive video and demonstration!  I'm wondering if you could achieve even longer arcs (at least a little bit) with further detuning and/or a shorter breakout point.  It doesn't seem to be struggling to break out initially as would be the case if detuned was close to the limit.  Of course, perhaps it is at the limit.  Hard to tell by viewing a video only.  In my case, an interruption sequence of ramped pulse widths also helped.  The ramp from short to long helped an arc form with slightly more detuning than otherwise worked.  Final enable pulse at the end of the ramp jumped to 2x longer, trying to get a tiny bit more length from an arc that had already reduced secondary frequency below primary.
Re: Kaizer DRSSTC 3
« Reply #4 on: May 15, 2022, 04:13:02 PM »
I spy a lot of tinfoil on the power cable, which looks like a pain in the ass to deal with - have you looked at using industrial control cable with shielding? That's what I moved to using (with the shield grounded) once I thought through the likely consequences of a hit on an unshielded mains cable.
Also, what controller is this currently running?
Re: Kaizer DRSSTC 3
« Reply #5 on: May 15, 2022, 08:22:11 PM »
That is good point about the variac, since its even a enclosed unit IP44 I think, its impossible to inspect the wiper, unless the entire thing is split in atoms. With the soft start box which pre-charges DC bus through power resistors, the variac is really not needed. I just brought it on this first try after storage to be sure to nurse it a bit and give the DCbus capacitors a soft low voltage start.
You are properly right about the tuning. Since its over 4 years from last tuning, I forgot why and where, but there is only one hole made in the base plate. I think its tuned exactly where JavaTC predicted it to be tuned. But considering that I, at that time, knew about detuning, it most be tuned lower. that just resonance.
To avoid buying new cable, I am putting it all through some copper braided shielding harness that I already have. Got enough to cover enough of what is in the danger zone. Then I will add some kind of protective cloth sleeve outside of that. The tin foil is just a 2 minute job, but ends up costing a roll every time as it gets a little bump or kink and there is no more unwinding it in one piece :)
Its running with my own single side version of UD2.1b, double GDTs.
Re: Kaizer DRSSTC 3
Range4Harry
Today at 11:25:14 PM
Robert3z
Today at 02:21:11 PM
CwhyteKGMS
Today at 07:29:15 AM
Today at 04:53:18 AM
Today at 04:36:44 AM
CwhyteKGMS
Today at 03:53:48 AM
Robert3z
Today at 02:20:58 AM
post Re: Problem with SSTC
May 15, 2022, 11:59:37 PM
Nunu00
May 15, 2022, 11:08:49 PM
May 15, 2022, 09:43:07 PM
post Re: Kaizer DRSSTC 3
Nunu00
May 15, 2022, 08:03:13 PM
May 15, 2022, 07:49:51 PM
Nunu00
May 15, 2022, 06:58:45 PM
May 15, 2022, 06:47:53 PM
Nunu00
May 15, 2022, 02:38:18 PM
post Bipolar CW
May 15, 2022, 03:46:25 AM
May 15, 2022, 03:40:42 AM
[Static Electricity]
May 15, 2022, 02:06:53 AM
May 14, 2022, 10:26:32 PM
Nunu00
May 14, 2022, 09:52:06 PM
May 14, 2022, 09:25:23 PM
Nunu00
May 14, 2022, 08:14:38 PM
May 14, 2022, 08:02:22 PM
Coileone
May 14, 2022, 06:15:59 PM
Coileone
May 14, 2022, 06:12:32 PM
post Problem with SSTC
Nunu00
May 14, 2022, 05:18:16 PM
post Re: Wago "Lever Nuts"?
May 14, 2022, 03:24:48 PM
May 13, 2022, 11:06:50 PM
May 13, 2022, 09:28:35 PM
Coileone
May 13, 2022, 02:13:19 PM
Coileone
May 13, 2022, 02:09:23 PM
May 13, 2022, 06:16:20 AM
May 13, 2022, 01:57:25 AM
Coileone
May 12, 2022, 10:05:32 PM
May 12, 2022, 09:41:04 PM
post Re: Thermometers
May 12, 2022, 09:33:38 PM
May 12, 2022, 09:27:40 PM
Robert3z
May 12, 2022, 02:13:03 PM
May 12, 2022, 06:39:55 AM
May 12, 2022, 06:27:47 AM
May 12, 2022, 06:22:48 AM
post Wago "Lever Nuts"?
May 12, 2022, 04:32:19 AM
post Re: Transistor choice
May 12, 2022, 03:32:22 AM
May 12, 2022, 12:00:11 AM
post Kaizer DRSSTC 3
CarldeLevis
May 11, 2022, 09:39:21 PM
post Thermometers
May 11, 2022, 09:36:59 PM
Nicolas
May 11, 2022, 09:29:45 PM
post Re: Litz Wire?
May 11, 2022, 08:45:57 PM
May 11, 2022, 08:43:38 PM
CarldeLevis
May 11, 2022, 05:44:40 PM
May 11, 2022, 04:17:34 PM
Robert3z
May 11, 2022, 03:10:27 PM
May 11, 2022, 01:46:57 PM
Robert3z
May 11, 2022, 12:37:19 PM
May 11, 2022, 11:33:30 AM
May 11, 2022, 11:00:59 AM
May 11, 2022, 06:30:45 AM
May 11, 2022, 06:11:08 AM
post Re: Litz Wire?
May 11, 2022, 04:00:41 AM
Robert3z
May 11, 2022, 02:06:34 AM
May 10, 2022, 07:52:45 PM
Nicolas
May 10, 2022, 10:04:27 AM
May 10, 2022, 09:31:39 AM
post Re: Litz Wire?
May 10, 2022, 09:29:19 AM
May 10, 2022, 09:23:38 AM
May 10, 2022, 07:24:33 AM
post Transistor choice
May 10, 2022, 03:33:10 AM
post Litz Wire?
May 10, 2022, 03:16:29 AM
May 09, 2022, 07:41:51 AM
May 09, 2022, 05:39:51 AM
May 09, 2022, 12:44:13 AM
Nicolas
May 09, 2022, 12:24:37 AM
Nicolas
May 09, 2022, 12:21:40 AM
May 09, 2022, 12:13:01 AM
post Re: QCW questions
May 08, 2022, 06:43:31 PM
May 08, 2022, 07:43:13 AM
May 07, 2022, 07:59:36 PM
Robert3z
May 07, 2022, 06:41:41 PM
post Re: Capacitor Esoterica
May 07, 2022, 05:57:22 PM
May 07, 2022, 03:43:57 PM
May 07, 2022, 03:21:16 PM
May 07, 2022, 06:52:29 AM
May 07, 2022, 04:57:41 AM
May 06, 2022, 08:54:52 AM
May 06, 2022, 02:54:44 AM
Dhaygoh
May 05, 2022, 05:26:27 PM
Dhaygoh
May 05, 2022, 05:14:32 PM
May 05, 2022, 06:29:00 AM
May 05, 2022, 05:56:01 AM
May 05, 2022, 05:11:45 AM
May 05, 2022, 04:37:42 AM
May 05, 2022, 04:19:47 AM
May 04, 2022, 11:22:09 PM
May 04, 2022, 11:04:19 PM
