Author Topic: Variac Isolation  (Read 273 times)
Offline abstruse1
Variac Isolation
« on: April 26, 2022, 04:54:15 AM »
I have a 10 A. Variac.  To properly isolate it from mains power/ground, do I need an isolation transformer, or can I just not connect the 3rd pin (ground) to the mains plug?
An adequate torodial isolation transformer (I assume this kind will work) with adequate capacity sells on eBay for $225.
Abstruse1
   Been working with electricity for 60 years and still getting a tingle!
Re: Variac Isolation
« Reply #1 on: April 26, 2022, 08:29:05 AM »
I made a video about the differences on variacs, auto transformers and isolation transformers
Offline abstruse1
« Reply #2 on: April 28, 2022, 04:03:41 AM »
Thanx, Mads.  Good video and great collection of variacs.
But it doesn't answer my question, can merely cutting off the 3rd (ground) pin from my Variac is adequate to prevent safety mishaps, or do I need an isolation transformer?
Thanx.
Abstruse1
« Reply #3 on: April 28, 2022, 07:51:22 AM »
I think there is a more fundamental question - what "safety" do you think you're gaining with an isolation transformer? They are useful tools in certain circumstances, but sometimes can actually make safety worse, e.g. when they end up defeating RCD protection.
And to actually answer the question, the Variac offers no isolation and cutting off the ground pin is almost never the answer.
« Reply #4 on: April 28, 2022, 08:15:44 AM »
The usual meaning of "isolated output" is high or infinite resistance between the output terminal pair and the input terminal pair.
Safety benefit: with one hand on any output terminal, and other hand on any grounded object, you won't get a shock.
You can run a wire from any output terminal to any grounded object, and not get a spark or blow a fuse.
Disconnecting the plug's ground pin does not provide that isolation.
It would remove one kind of shock hazard: touching a hot wire and the variac case at the same time.
It would add a different kind of shock hazard, that's more sneaky: Accidental contact between a hot wire and case.
If the case is properly grounded, a fuse would blow and whole circuit would turn off.   If the case is not grounded, the accidental contact with hot wire would make the case "live" and dangerous to touch.
« Last Edit: April 28, 2022, 09:16:15 AM by klugesmith »
« Reply #5 on: April 28, 2022, 09:20:00 AM »
Safety benefit: with one hand on any output terminal, and other hand on any input terminal or grounded object, you won't get a shock.
You can run a wire from any output terminal to any input terminal or grounded object, and not get a spark or blow a fuse.
Yet if you end up grounding the "isolated" side anywhere e.g. via a scope ground lead, then you're back to the safety situation of the non-isolated case, except worse as a switchboard RCD won't help you due to the transformer in the way.
There are totally cases where it does make sense to use an isolation transformer, and they can increase safety if used appropriately, but the OP's original post and question about removing the earth pin didn't inspire confidence that this would be one of these cases, or that the implications of the transformer are fully understood. My question was really to try to get an idea of what the OP thought they were gaining from the transformer, and how it would be connected/used.
Range4Harry
May 16, 2022, 11:25:14 PM
Robert3z
May 16, 2022, 02:21:11 PM
CwhyteKGMS
May 16, 2022, 07:29:15 AM
May 16, 2022, 04:53:18 AM
May 16, 2022, 04:36:44 AM
CwhyteKGMS
May 16, 2022, 03:53:48 AM
Robert3z
May 16, 2022, 02:20:58 AM
post Re: Problem with SSTC
May 15, 2022, 11:59:37 PM
Nunu00
May 15, 2022, 11:08:49 PM
May 15, 2022, 09:43:07 PM
post Re: Kaizer DRSSTC 3
May 15, 2022, 08:22:11 PM
Nunu00
May 15, 2022, 08:03:13 PM
May 15, 2022, 07:49:51 PM
Nunu00
May 15, 2022, 06:58:45 PM
May 15, 2022, 06:47:53 PM
May 15, 2022, 04:13:02 PM
Nunu00
May 15, 2022, 02:38:18 PM
May 15, 2022, 03:53:35 AM
post Bipolar CW
May 15, 2022, 03:46:25 AM
May 15, 2022, 03:40:42 AM
[Static Electricity]
May 15, 2022, 02:06:53 AM
May 14, 2022, 10:26:32 PM
Nunu00
May 14, 2022, 09:52:06 PM
May 14, 2022, 09:25:23 PM
Nunu00
May 14, 2022, 08:14:38 PM
May 14, 2022, 08:02:22 PM
Coileone
May 14, 2022, 06:15:59 PM
Coileone
May 14, 2022, 06:12:32 PM
post Problem with SSTC
Nunu00
May 14, 2022, 05:18:16 PM
post Re: Wago "Lever Nuts"?
May 14, 2022, 03:24:48 PM
May 13, 2022, 11:06:50 PM
May 13, 2022, 09:28:35 PM
May 13, 2022, 09:24:22 PM
Coileone
May 13, 2022, 02:13:19 PM
Coileone
May 13, 2022, 02:09:23 PM
May 13, 2022, 06:16:20 AM
May 13, 2022, 01:57:25 AM
Coileone
May 12, 2022, 10:05:32 PM
May 12, 2022, 09:41:04 PM
post Re: Thermometers
May 12, 2022, 09:33:38 PM
May 12, 2022, 09:27:40 PM
Robert3z
May 12, 2022, 02:13:03 PM
May 12, 2022, 06:39:55 AM
May 12, 2022, 06:27:47 AM
May 12, 2022, 06:22:48 AM
post Wago "Lever Nuts"?
May 12, 2022, 04:32:19 AM
post Re: Transistor choice
May 12, 2022, 03:32:22 AM
May 12, 2022, 12:00:11 AM
May 11, 2022, 09:53:15 PM
post Kaizer DRSSTC 3
May 11, 2022, 09:40:00 PM
CarldeLevis
May 11, 2022, 09:39:21 PM
post Thermometers
May 11, 2022, 09:36:59 PM
Nicolas
May 11, 2022, 09:29:45 PM
post Re: Litz Wire?
May 11, 2022, 08:45:57 PM
May 11, 2022, 08:43:38 PM
CarldeLevis
May 11, 2022, 05:44:40 PM
May 11, 2022, 04:17:34 PM
Robert3z
May 11, 2022, 03:10:27 PM
May 11, 2022, 01:46:57 PM
Robert3z
May 11, 2022, 12:37:19 PM
May 11, 2022, 11:33:30 AM
May 11, 2022, 11:00:59 AM
May 11, 2022, 06:30:45 AM
May 11, 2022, 06:11:08 AM
post Re: Litz Wire?
May 11, 2022, 04:00:41 AM
Robert3z
May 11, 2022, 02:06:34 AM
May 10, 2022, 07:52:45 PM
Nicolas
May 10, 2022, 10:04:27 AM
May 10, 2022, 09:31:39 AM
post Re: Litz Wire?
May 10, 2022, 09:29:19 AM
May 10, 2022, 09:23:38 AM
May 10, 2022, 07:24:33 AM
post Transistor choice
May 10, 2022, 03:33:10 AM
post Litz Wire?
May 10, 2022, 03:16:29 AM
May 09, 2022, 07:41:51 AM
May 09, 2022, 05:39:51 AM
May 09, 2022, 12:44:13 AM
Nicolas
May 09, 2022, 12:24:37 AM
Nicolas
May 09, 2022, 12:21:40 AM
May 09, 2022, 12:13:01 AM
post Re: QCW questions
May 08, 2022, 06:43:31 PM
May 08, 2022, 07:43:13 AM
May 07, 2022, 07:59:36 PM
Robert3z
May 07, 2022, 06:41:41 PM
post Re: Capacitor Esoterica
May 07, 2022, 05:57:22 PM
May 07, 2022, 03:43:57 PM
May 07, 2022, 03:21:16 PM
May 07, 2022, 06:52:29 AM
May 07, 2022, 04:57:41 AM
May 06, 2022, 08:54:52 AM
May 06, 2022, 02:54:44 AM
Dhaygoh
May 05, 2022, 05:26:27 PM
Dhaygoh
May 05, 2022, 05:14:32 PM
May 05, 2022, 06:29:00 AM
May 05, 2022, 05:56:01 AM
May 05, 2022, 05:11:45 AM
May 05, 2022, 04:37:42 AM
May 05, 2022, 04:19:47 AM
May 04, 2022, 11:22:09 PM
May 04, 2022, 11:04:19 PM
