Author Topic: Looking for a high speed THT comparator >1MHz  (Read 1054 times)
Offline SalinsLV
  • Electronics experience starting from 2015.
« on: October 28, 2021, 03:25:41 PM »
Hello!
I am looking for a THT comparator that can compare vref(0V) with >1Mhz signals and give an output that looks like this:
Circuit looks like this:
Falstad simulation code:
* 1MHz comparator simulation.txt
So far I have used op-amps and comparators that i have - LM393N, LM393P, LM311P, LM358P, LM386N-1 and AD8055A.
At lower frequencies they work almost identical to the simulation. One exception is AD8055A which outputs distorted square wave with roughly 1.24V DC offset that i can't seem to get rid of:
(blue input, yellow output of AD8055A)
Another screenshot from the AD8055A output:
 Resistor to ground only increases the current draw and a capacitor at the output messes with the rise/fall times making the square wave with slow rising edges. Main reason why i bought AD8055A was that I thought that it will compare the inputs at even 300MHz (as mentioned in datasheet) but i was wrong.
At higher frequencies, every op-amp and comparator that i have gives an output similar to this:
or even worse:
Does anyone know a comparator that could complete the function that i described?
K. Salins
Re: Looking for a high speed THT comparator >1MHz
« Reply #1 on: October 29, 2021, 05:48:06 AM »
TLV3501 is the part I use for high-speed comparison.  The optimum part for your needs depends on how much delay you can tolerate, input and output voltages etc.  I think TLV3501 will be close to your ideal.  The UD2.7 uses TL3116, another option to consider.  These are SMT, however.
Make sure the comparitor - input is slightly above 0V if your input signal (+ input) goes down to 0V.  No comparitor works with zero overdrive voltage.  Also need good ECB layout to avoid parasitic oscillation.  Perhaps that is why new high-speed comparitors are rarely THT.  SMT allows lower parasitic lead inductances.
Offline Twospoons
« Reply #2 on: October 29, 2021, 10:54:14 PM »
Some of those scope traces look like you are trying to drive the comparator input below its negative rail (evidence: soft clipping).  That would explain the weird output from the AD8055. Post a schematic of what you are doing.
Also I wouldn't bother with a simulation unless you are using a proper spice model of the comparator/opamp - try either LTSpice or Simetrix, they will give you much more accurate results. Both are free, Simetrix is node limited but is my personal favorite due to ease of use and simulation speed.
Bobakman
Today at 11:15:15 PM
Today at 10:59:36 PM
unrealcrafter2
Today at 10:03:48 PM
Today at 09:53:25 PM
unrealcrafter2
Today at 09:50:09 PM
Michelle_
Today at 09:15:55 PM
post Re: 100kHz CM300 gate resistor choice
Today at 08:50:49 PM
unrealcrafter2
Today at 08:11:27 PM
Today at 07:28:05 PM
Bobakman
Today at 06:30:30 PM
Michelle_
Today at 06:03:57 PM
Michelle_
Today at 05:26:13 PM
Today at 04:03:38 PM
Michelle_
Today at 02:56:40 PM
post Re: DIY induction guns? (warning:long)
Today at 06:17:15 AM
Michelle_
Today at 05:46:07 AM
Today at 05:18:31 AM
Today at 04:34:52 AM
Today at 04:11:53 AM
Michelle_
Today at 04:02:44 AM
Today at 03:35:52 AM
April 17, 2024, 11:54:05 PM
post 100kHz CM300 gate resistor choice
April 17, 2024, 11:37:16 PM
post Re: Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
post Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
Michelle_
April 16, 2024, 06:18:40 PM
Michelle_
April 16, 2024, 06:14:53 PM
unrealcrafter2
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
unrealcrafter2
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
Michelle_
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
Michelle_
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
Michelle_
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
Michelle_
April 10, 2024, 09:56:35 PM
unrealcrafter2
April 10, 2024, 08:59:26 PM
markus
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
