Author Topic: Flyback EHT too high, change cap value?  (Read 296 times)
Offline Overkill
« on: March 30, 2024, 10:45:14 AM »
Hi all
I've been trying to repair some old Commodore computer monitors.
I've fitted a replacement Flyback but it's a slightly different model, and although it fits fine, I think the primary winding is different which results in a too high EHT.
I've measured the 15v output of the flyback and get 16v (about 8% too high).
I've been told that if I replace C207 or C208 with a higher rating it would lower the voltage. Well, the advice was to try keep adding 2200pf caps in parallel.
As a novice I see the logic, as this might be tuned circuit and changing a value of a component would change the output.
Also, I've seen people say that if these capacitors lose their value, the voltage goes high.
Also, I see on slightly different board versions that they use different value capacitors, I've seen 7300pf to 9100pf.
So, does this sound correct to you guys, if I increase the capacitor value it would lower the flybacks voltage?
Diagram attached.
Re: Flyback EHT too high, change cap value?
« Reply #1 on: March 30, 2024, 08:04:38 PM »
Yes, likely to work, but no guarantees.  Presumes driver circuit's off-time is long enough, likely true.  If same transistor drives horizontal deflection as is common, will increase retrace time by same ~8%.  Hopefully that isn't an issue either.
As a starting point, capacitance will need to increase by 16%.  (1.08 ^ 2 ~= 1.16).  Looks like existing capacitance is 7300pF.  Add ~1170pF.
Offline Overkill
« Reply #2 on: March 31, 2024, 11:20:29 AM »
Thanks for your reply.
I'm looking for some caps, I see in the diagram the 3000pf cap is 600v but the 4300pf is 1600v, I assume if 2200pf was used in parallel that 650v caps would be OK?
« Reply #3 on: March 31, 2024, 06:49:59 PM »
I suspect "0.6kV" is a typo and the real voltage is 1.6kV.  Normally 0.6kV would be written as 600V.  600V would be low for typical flyback use.
Today at 05:58:27 AM
Today at 05:17:22 AM
Today at 12:39:59 AM
April 23, 2024, 11:07:41 PM
April 23, 2024, 10:57:39 PM
April 23, 2024, 09:33:49 PM
April 23, 2024, 06:00:42 PM
April 23, 2024, 03:50:49 AM
April 23, 2024, 03:13:31 AM
April 23, 2024, 12:50:40 AM
April 22, 2024, 11:21:06 PM
April 22, 2024, 08:11:00 PM
April 22, 2024, 06:15:30 PM
April 22, 2024, 05:52:50 PM
April 22, 2024, 05:52:13 PM
April 22, 2024, 04:31:52 PM
April 22, 2024, 04:05:34 PM
April 22, 2024, 01:02:30 PM
April 22, 2024, 06:32:35 AM
April 22, 2024, 06:24:10 AM
April 22, 2024, 05:13:15 AM
April 22, 2024, 02:25:29 AM
April 22, 2024, 02:09:18 AM
April 22, 2024, 12:14:21 AM
April 21, 2024, 09:47:15 PM
April 21, 2024, 08:34:02 PM
April 21, 2024, 06:09:57 PM
April 21, 2024, 06:21:54 AM
April 21, 2024, 06:18:30 AM
April 21, 2024, 06:12:31 AM
April 21, 2024, 05:19:55 AM
April 21, 2024, 02:29:17 AM
April 21, 2024, 01:28:59 AM
April 21, 2024, 01:19:44 AM
April 21, 2024, 12:55:25 AM
April 20, 2024, 11:25:32 PM
April 20, 2024, 10:28:26 PM
April 20, 2024, 10:23:28 PM
April 20, 2024, 10:06:44 PM
April 20, 2024, 09:21:55 PM
April 20, 2024, 09:16:14 PM
April 20, 2024, 08:58:40 PM
April 20, 2024, 06:18:26 PM
April 20, 2024, 06:15:26 PM
April 20, 2024, 03:45:43 PM
April 20, 2024, 06:33:37 AM
April 20, 2024, 05:45:04 AM
April 20, 2024, 05:34:16 AM
April 20, 2024, 04:50:57 AM
April 20, 2024, 04:03:55 AM
April 20, 2024, 02:35:56 AM
April 19, 2024, 09:37:52 PM
April 19, 2024, 09:20:10 PM
April 19, 2024, 07:22:26 PM
April 19, 2024, 04:46:36 PM
April 19, 2024, 03:49:28 PM
April 19, 2024, 01:53:57 PM
April 19, 2024, 05:24:19 AM
Tesla Junior
April 19, 2024, 04:24:09 AM
April 19, 2024, 04:20:35 AM
April 19, 2024, 04:05:28 AM
April 19, 2024, 04:03:54 AM
April 19, 2024, 03:19:19 AM
April 19, 2024, 03:09:29 AM
April 19, 2024, 01:47:37 AM
April 19, 2024, 12:19:21 AM
April 18, 2024, 11:33:01 PM
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
April 18, 2024, 09:50:09 PM
April 18, 2024, 09:15:55 PM
April 18, 2024, 08:50:49 PM
April 18, 2024, 08:11:27 PM
April 18, 2024, 07:28:05 PM
April 18, 2024, 06:30:30 PM
April 18, 2024, 06:03:57 PM
April 18, 2024, 05:26:13 PM
April 18, 2024, 04:03:38 PM
April 18, 2024, 02:56:40 PM
April 18, 2024, 06:17:15 AM
April 18, 2024, 05:46:07 AM
April 18, 2024, 05:18:31 AM
April 18, 2024, 04:34:52 AM
April 18, 2024, 04:11:53 AM
April 18, 2024, 04:02:44 AM
April 18, 2024, 03:35:52 AM
April 17, 2024, 11:54:05 PM
April 17, 2024, 11:37:16 PM
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
