Author Topic: Odd MOSFET Driver Behavior  (Read 2165 times)
Offline KrisPringle
« on: September 12, 2023, 03:32:01 AM »
I've been testing my driver for my first SSTC and am having some very weird problems with my MOSFET drivers. I've looked through the forum and never seen anything like it. It seems like each driver has a little extra blip of on-time after the actual on-time.
I attached some images of relevant scope traces and the schematics I'm using (Profdc9's). For the unloaded case, I'm scoping the low and high side of the GDT driver outputs with no transformer on the outputs. For the loaded case, I'm scoping the outputs with the gate drive connected to the full bridge.
I have no idea what would be causing this. Any clues? The MOSFET drivers get pretty warm after a few minutes of running the driver (CW mode, 15V).
« Last Edit: September 12, 2023, 03:40:50 AM by KrisPringle »
Re: Odd MOSFET Driver Behavior
« Reply #1 on: September 12, 2023, 06:22:52 AM »
I might have time to make a better answer in a day or two.  Most likely your issue is with physical circuit construction.  Too much wire inductance in driver ground and supply connections, bypass caps not close enough, etc.
CW mode often stresses drivers, so warm isn't unusual for CW operation.
« Last Edit: September 12, 2023, 06:29:17 AM by davekni »
Offline KrisPringle
« Reply #2 on: September 12, 2023, 02:16:45 PM »
Not saying this definitely couldn't be true, but others seem to have had success using the same PCB layout. https://highvoltageforum.net/index.php?topic=1898.0
Is there anything I could scope that would confirm or reject your hypothesis?
I've attached a picture of the board as well as the board layout.
« Last Edit: September 12, 2023, 02:29:01 PM by KrisPringle »
« Reply #3 on: September 14, 2023, 05:37:20 AM »
Layout looks good.  I'd been guessing you were using a hand wired breadboard for my previous comment.
However, this circuit design looks quite sensitive to noise.  TC4420 input traces are slow, especially falling edge, where voltage must fall to ~1.5V for output to switch.  With only 0.3V hysteresis, it doesn't take much noise (such as ground bounce inside TC4420) to make the extra output edges you see.  Notice that these noise pulses are all on falling edges.
40106 is slow and 4.7k series resistors will slow output further by the time it reaches TC4420.
One option is to add ~1k to 1.5k resistors from TC4420 inputs to ground.  That will attenuate signals to be roughly symmetric around TC4420 input threshold.
Sockets contribute to ground bounce inside chips.  Convenient for chip replacement, but have a significant down side.
Good luck with debug!  Thank you for posting details.
Offline KrisPringle
« Reply #4 on: September 14, 2023, 03:07:24 PM »
Thanks for the help!
I will try removing the sockets. Also, the BOM called for 10k on those resistors but the schematic says 4.7k. I think I’ll also try replacing those 10k’s with 4.7k’s.
I will report back with results.
« Reply #5 on: September 14, 2023, 09:53:57 PM »
It's the driver (TC4420) sockets that are of particular concern.  The other low-power chips are much less likely to have any issues due to sockets.
You could try even lower than 4.7k.  Also you may want to try pull-down resistors after 4.7k.  Driver chip input signal could be even better with a combination of pull-down resistors after 4.7k and small caps across 4.7k resistors to peak high frequencies, something in the range of 33pF to 100pF.  See what makes driver chip inputs look best (sharp rise and fall transitions, especially in region around 1.5V which is driver input threshold voltage).
Offline KrisPringle
« Reply #6 on: September 16, 2023, 02:29:05 AM »
In an effort to not have to "jankify" the PCB, I tried just removing the MOSFET driver sockets and lowering the resistance to 4.7k. This didn't help, and the issue was still occurring. I wonder what is different about my board compared to others who have had success.
I tried using a 4.7k pull down resistor, and the GDT output looked good unloaded, but loaded, something was still wrong. (I think still the same issue as my original post, just to a lesser degree? I'm not sure through what mechanism the solution identified in the next paragraph works if it isn't the same issue.)
Unfortunately, I am not into much for hobby electronics outside this project, so I don't have a bunch of random capacitors lying around. I found a single 4700nf capacitor to throw across one of the 4.7ks, and voila! The rising edge of the waveform looks pretty good! Maybe a little over damped? The high frequency ringing before the output goes high: is that a problem? I don't have another capacitor to check if that's a symptom of the other driver not having the capacitor across it's resistor yet.
« Reply #7 on: September 16, 2023, 06:25:04 AM »
I'd guess that the 4.7k pull down resistors are working fine.  Loaded waveform is likely due to IGBT miller capacitance loading driver chip outputs.  However, it could be that 4.7k isn't enough pull-down.  Any ~2k resistors around?  Or enough 4.7k resistors to parallel 2 or 3 for each pull-down?
Did you mean 4700pF?  Even if so, that is still large.  Probably OK when used without a pull-down resistor.  I was suggesting a much smaller capacitor combined with a pull-down resistor.  However, combining the two does require getting capacitance correct to avoid driver chip inputs glitching too far below ground.
Once the input is clean enough to not glitch due to driver chip ground bounce, any remaining characteristics of driver outputs are due to driver output impedance and load impedance (GDT and IGBT gates).
Probably not an issue.  For such relatively small ringing, it is difficult to know if it is real or magnetic pickup in loop from scope probe ground lead to probe tip.
Probably best to have both channels modified to be the same.  There can be some advantage to a slight delay in one driver relative to the other.  However, any of these fixes (caps or pull-down resistors) will affect rising and falling delays differently.  If you have any lower-value resistors (ie. 2k), I'd guess that to be a more reliable fix than capacitors alone.  (If you have extra 4.7k resistors, two in parallel for each pull-down would be better than just one each.)  The pull-down resistor solution should move duty cycle closer to 50%.
« Last Edit: September 16, 2023, 06:26:36 AM by davekni »
Offline KrisPringle
« Reply #8 on: September 16, 2023, 04:33:30 PM »
Gotcha, I have a resistor pack. The pulldown resistors are at 2k now, and unloaded output is good. No capacitors on it.
Loaded output still has a weird jump on one MOSFET driver. If this indeed from Miller Capacitance, that peak should reduce dramatically when the bridge is at mains voltage? Would you expect the traces to be asymmetric? The spikes are only on of the outputs.
« Reply #9 on: September 17, 2023, 05:19:47 AM »
This capture does look less like Miller capacitance, more like driver chip ground bounce.  Loading may be adding just enough additional ground current spike to cause trouble.  Perhaps one chip has slightly higher inductance in ground path or has slightly faster output transition or more shoot-through current.  Previous loaded captures may have been ground bounce too.  They looked more like flat spots than spikes, which is typical of Miller capacitance.
Offline KrisPringle
« Reply #10 on: March 25, 2024, 12:47:09 AM »
Picked my project back up, got everything ready for testing with the variac, and am running into more issues.
I believe my driver is working correctly, scoping at the full bridge shows some great looking square waves. However, something isn't working and I'm not sure what to even start looking for. These are symptoms I've seen, seems to be in line with IGBT shoot-through? The problem is if it's shoot through, I don't know how I can improve my GDT waveform any further.
  • The AC to DC bridge rectifier is getting obscenely hot at low voltage, like less than 10V. This has happened with 2 different bridge rectifiers (Mouser Part 78-GBU25H08-M3/P). The variac is also making a rather loud humming.
  • The IGBTs are also getting very hot at <10V to the bridge. All of them seem to be producing roughly equal amounts of heat.
  • When the driver is off, the bus capacitor holds its voltage and there's no short
Not an EE and not super experienced so I can't say for sure the IGBTs aren't broken, but I never saw the magic smoke, and testing resistances across the pins shows it's identical to a new IGBT. Is there anything else I can be looking for that can be causing this? For the low voltage testing I didn't have anything grounded, could that be causing this?
The driver and bridge design is the same as I've posted earlier in this thread from ProfDC9.
« Reply #11 on: March 25, 2024, 02:39:40 AM »
Most likely issue is GDT secondaries being mis-wired, causing the two IGBTs of a half-bridge to be on simultaneously.
Offline KrisPringle
« Reply #12 on: March 25, 2024, 04:43:25 AM »
I have verified that I have labeled my GDT phases correctly, however I took a look at the PCB, and I'm wondering if I'm just missing something obvious. Is the phase labeling on the PCB incorrect/meaningless? I've been matching all the phases on my GDT to the PCB, but looks to me like that might not be right.
See the attached image, both GDT terminals labeled "+" go to the gate pin.
EDIT:
Good call on the phasing, fixed it to be properly phased and it seems to be working well. Only pushed it up to 50 volts but the dummy load was singing with my interrupter! Waiting for my top load then I should be in business.
« Last Edit: March 26, 2024, 02:32:36 AM by KrisPringle »
Offline KrisPringle
« Reply #13 on: March 30, 2024, 01:33:25 AM »
Topload came in and I begun testing, ran into some issues.
I couldn't get any streamers to come out of the top-load, and a light bulb sitting on the topload didn't even light up. There's a section of my coil that was experiencing some secondary racing sparks, and I made some gnarly Lichtenberg figures on the inside of the PVC pipe (I think because my ground lead of the secondary coil was curled back up a few inches into the coil).
I transported my secondary before sealing it, and unfortunately it resulted in a less than perfect secondary with some crossing over. A few questions:
  • I can see how that would cause the racing sparks, but before I go ahead and make another secondary, is this indicative of a larger problem? Is a lack of streamers expected with a sub-par secondary experiencing racing sparks? I think I could stand to reduce the coupling or change the primary design, but I would figure that the current state would actually help create streamers at a higher risk of racing sparks. I had a breakout point on the toroid.
  • Are the racing sparks at least an indicator the inverter and antennae feedback are functioning properly? I was getting them by about 40V on the bridge. The top of the secondary also got warm
« Last Edit: March 30, 2024, 01:37:25 AM by KrisPringle »
« Reply #14 on: March 30, 2024, 07:22:03 PM »
Not necessarily.  One issue I've seen here with antenna feedback is antenna picking up signal more from part-way up secondary than from top.  Results in oscillation at a higher frequency mode of secondary.  No way to tell for sure given your damaged secondary.  Likely shorted turns at places.
Looking at your JavaTC results:
Most SSTCs have higher coupling, closer to 0.3.  Many have primary wound around section of plastic pipe or other insulating material that fits over secondary.  That increases coupling while reducing chance of secondary-to-primary arcs.
Also, a gap between top of secondary and top load is helpful, on the order of secondary radius.  Allows space for magnetic field lines to return.
post Re: First DRSSTC SKM100
Today at 05:58:27 AM
post Tesla coil UV eye protection?
Today at 05:17:22 AM
post Re: Tenebrescent Potassium Iodide
Today at 12:39:59 AM
April 23, 2024, 11:07:41 PM
April 23, 2024, 10:57:39 PM
OmGigaTron
April 23, 2024, 09:33:49 PM
April 23, 2024, 06:00:42 PM
April 23, 2024, 03:50:49 AM
April 23, 2024, 03:13:31 AM
April 23, 2024, 12:50:40 AM
April 22, 2024, 11:21:06 PM
April 22, 2024, 08:11:00 PM
April 22, 2024, 06:15:30 PM
April 22, 2024, 05:52:50 PM
post Tenebrescent Potassium Iodide
April 22, 2024, 05:52:13 PM
April 22, 2024, 04:31:52 PM
April 22, 2024, 04:05:34 PM
April 22, 2024, 01:02:30 PM
April 22, 2024, 06:32:35 AM
April 22, 2024, 06:24:10 AM
post M2000NM1 toroid for gdt tesla coil
April 22, 2024, 05:13:15 AM
April 22, 2024, 02:25:29 AM
April 22, 2024, 02:09:18 AM
April 22, 2024, 12:14:21 AM
April 21, 2024, 09:47:15 PM
April 21, 2024, 08:34:02 PM
April 21, 2024, 06:09:57 PM
April 21, 2024, 06:21:54 AM
post Re: Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 06:18:30 AM
April 21, 2024, 06:12:31 AM
April 21, 2024, 05:19:55 AM
April 21, 2024, 02:29:17 AM
April 21, 2024, 01:28:59 AM
post Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 01:19:44 AM
April 21, 2024, 12:55:25 AM
April 20, 2024, 11:25:32 PM
April 20, 2024, 10:28:26 PM
April 20, 2024, 10:23:28 PM
April 20, 2024, 10:06:44 PM
April 20, 2024, 09:21:55 PM
April 20, 2024, 09:16:14 PM
April 20, 2024, 08:58:40 PM
April 20, 2024, 06:18:26 PM
April 20, 2024, 06:15:26 PM
April 20, 2024, 03:45:43 PM
April 20, 2024, 06:33:37 AM
April 20, 2024, 05:45:04 AM
April 20, 2024, 05:34:16 AM
April 20, 2024, 04:50:57 AM
April 20, 2024, 04:03:55 AM
April 20, 2024, 02:35:56 AM
Bobakman
April 19, 2024, 09:37:52 PM
April 19, 2024, 09:20:10 PM
April 19, 2024, 07:22:26 PM
April 19, 2024, 04:46:36 PM
April 19, 2024, 03:49:28 PM
Bobakman
April 19, 2024, 01:53:57 PM
April 19, 2024, 05:24:19 AM
Tesla Junior
April 19, 2024, 04:24:09 AM
April 19, 2024, 04:20:35 AM
Bobakman
April 19, 2024, 04:05:28 AM
April 19, 2024, 04:03:54 AM
April 19, 2024, 03:19:19 AM
April 19, 2024, 03:09:29 AM
April 19, 2024, 01:47:37 AM
Bobakman
April 19, 2024, 12:19:21 AM
April 18, 2024, 11:33:01 PM
Bobakman
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
April 18, 2024, 09:50:09 PM
April 18, 2024, 09:15:55 PM
April 18, 2024, 08:50:49 PM
April 18, 2024, 08:11:27 PM
April 18, 2024, 07:28:05 PM
Bobakman
April 18, 2024, 06:30:30 PM
April 18, 2024, 06:03:57 PM
April 18, 2024, 05:26:13 PM
April 18, 2024, 04:03:38 PM
April 18, 2024, 02:56:40 PM
post Re: DIY induction guns? (warning:long)
April 18, 2024, 06:17:15 AM
April 18, 2024, 05:46:07 AM
April 18, 2024, 05:18:31 AM
April 18, 2024, 04:34:52 AM
April 18, 2024, 04:11:53 AM
April 18, 2024, 04:02:44 AM
April 18, 2024, 03:35:52 AM
April 17, 2024, 11:54:05 PM
April 17, 2024, 11:37:16 PM
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
