Author Topic: Search for opinions concerning the use or test of a yunbao / Ebay drsstc skp  (Read 2625 times)
Offline JCF
Good morning all.
Did someone manage to get this driver to work correctly with a current sensor on the feedback input ? Seller Source Ebay or Ali (2019 NEW Tesla coil DRSSTC SKP jump pulse driver + Arc extinguishing controller)
I spent time in experimentation: it is a failure for me with this driver. For me, it only works with a generator connected to the feedback
Info sur kechuang-org and 4vh.org
https://translate.google.com/translate?hl=fr&sl=zh-CN&tl=en&u=https%3A%2F%2Fwww.kechuang.org%2Ft%2F83919&sandbox=1
« Last Edit: February 27, 2021, 11:40:22 AM by JCF »
Offline Maju
Hi JCF!
Please send more information about your circuit (your current transformer, inverter, some scopes) - this will help with diagnosis.
See my drsstc post, I use an identical driver with a few modifications. While I'm still developing the project, the driver works great.
Quick tip (1) is: throw away that fiber optic cable - get a better one. Many people who use this driver complain that it is the source of the problems you describe.
Quick tip (2): Have you tried to reverse the input wires from CT?
Offline JCF
Thank you for message.
about coils see calculation (javaTC)
the schema of power full bridge, with protections (diode, TVS) sorry there is an error on the direction of the diodes on schematic
with generator on feedback input (3 volts max) frequency  100v I see spark
primary resonance  with 12nf  260KHZ measured, secondary resonance 280KHZ measured
with sense current 1/300  CST206-3 TRIAD. (or I have also 1/2000 from ebay) connected on feedback  very small primary current and no spark with 100V
« Last Edit: May 05, 2021, 11:45:10 AM by JCF »
Offline Netzpfuscher
You cannot use such current transformer with a standard driver. The driver has a input impedance of around 3 Ohm and your current transformer around 12 Ohm. Such transformers are for around 100mA on the secondary. The driver needs about 1A.
Build your own CT from two cores.
Offline GrantV
Hi there,
Please explain why you say that we can not use these CT's with the yunbao driver? Gao uses them with his UD2.7 driver and has never said that there is any problem using them.
With my coil I am expecting an average of 200A with a possible max of 250A so the CST206-3A (300:1) should be fine?
If I do need to wind my own cascaded pair, should I use 14:14 turns for 196:1 which would provide 1Amp at my average current? (1.27A at max) and ... would I do the same then for the overcurrent sense?
CST206-3 should work well.  It's internal 12.4 ohms is in series with whatever load (burden) resistor is used.  The total voltage across the burden resistor plus 12.4ohms will still be way under its 6000uVs rating.
Offline GrantV
Thank you David, that is what I expected, and was hoping to have confirmed :-)
Offline GrantV
Good morning all.
Hi there,
I did my first tests today and can confirm that the driver DOES work with the CST206/3 current transformers :-)
I did have to swop the leads around as the phasing was wrong when I first connected it but once I did that, it worked perfectly and held my fres of 131Khz even at very low power.
I hope you get yours working!
Offline JCF
For me it's always the same.
Tesla driver need to have a generator connected to feedback. I observe two resonances : one approximately 245khz and a big one at 330khz with spark (at DC 80VDC.
for testing I use the switch case provided with the driver and in SKP mode
Primary is 25µH and 13 nF, 13 turns spaced 1 cm (hight 15cm) wire is 0.4cm multi wire twist (??) sheathed copper
Secondary coil resonate at approximately 280/300khz (with top load). Diameter 8cm height 55 cm 900 turns
with the sense current  level is very low and fequency is 360khz ? sence current 1:300 CST 206-3
what else can I do?
« Last Edit: March 06, 2021, 05:43:05 PM by JCF »
Today at 06:50:47 AM
April 08, 2024, 01:29:53 AM
April 08, 2024, 12:55:50 AM
April 08, 2024, 12:38:52 AM
April 07, 2024, 11:56:02 PM
April 07, 2024, 07:49:29 PM
April 07, 2024, 06:28:12 PM
post First DRSSTC SKM100
April 07, 2024, 06:13:59 PM
April 07, 2024, 05:44:55 AM
