Author Topic: Where's all this voltage coming from?  (Read 579 times)
Offline Terry
« on: March 17, 2024, 01:29:32 AM »
Designing the plate capacitor to be 20Kv rated, I come up with a dielectric of .050" plastic and air gaps of 2/3 cm.
So I tested .0078" aluminum separated with .0625" polyethylene and 1.125" air gaps and came up with about 38 layers to get the desired 20nf capacitance.
However, when I mocked up 3 plates (1.5nf) and hooked it up to the 10Kv rms OBIT, I got arcing through the air gaps. At 30Kv per cm of air, that comes out to 84Kv. WTF?
Not every time. Simply plugging in the OBIT and leaving it seemed ok with just a buzzing noise and no apparent arcing. It was when intermittently powering the OBIT (say 3 times per second) that the problem occurred.
Anybody know the cause and/or how to correct it?
How worried about it should I be if the goal is a good-running SGTC?
Re: Where's all this voltage coming from?
« Reply #1 on: March 17, 2024, 04:50:51 AM »
Home made HV capacitors are surprisingly difficult.  Creepage distance (distance along an insulating surface) is much larger than air gap distance for a given breakdown voltage.  And 30kV/cm is for perfectly uniform conductors on either side of a gap.  (Think large diameter smooth spheres with small gap distance compared to diameter.)  Other shapes cause field concentration at points and corners and edges.  I've tried making HV capacitors many times.  Only successes are for moderate voltage and limited lifetime use such as ~5kV for an air (nitrogen) laser.
Offline Twospoons
« Reply #2 on: March 18, 2024, 02:36:11 AM »
And thats for dry air at sea level. When the humidity or altitude get up a bit then you could be as low as 10kV/cm.
Offline Benbmw
« Reply #3 on: March 22, 2024, 09:21:13 PM »
Terry, in addition to what Dave and Twospoons commented, it sounds like you could be getting voltage spikes on the output of the transformer due to turn off transients. Im not sure how you are driving it (directly from mains AC?) or switching it on and off, but presumably when you switch it off it results in a large negative dI/dt across the primary as the switch opens. This quickly changing flux induces a large voltage in the secondary.
Today at 02:25:25 AM
Today at 01:39:11 AM
post Re: Plasma Toroid
Today at 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
Michelle_
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
Michelle_
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
Michelle_
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
Michelle_
May 12, 2024, 02:51:27 PM
Michelle_
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
Michelle_
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
Michelle_
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
Michelle_
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
May 10, 2024, 09:38:05 PM
Michelle_
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
Michelle_
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
Michelle_
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
Michelle_
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
Michelle_
May 09, 2024, 03:42:49 PM
Michelle_
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
Lasr8
May 09, 2024, 04:45:33 AM
May 09, 2024, 03:56:52 AM
Michelle_
May 09, 2024, 02:16:30 AM
Michelle_
May 09, 2024, 02:00:28 AM
unrealcrafter2
May 09, 2024, 12:48:57 AM
post Re: Capacitor Blowout
radioman
May 08, 2024, 09:04:54 PM
post Question about using mains power and variacs to power this circuit
Michelle_
May 08, 2024, 08:10:41 PM
Michelle_
May 08, 2024, 07:33:43 PM
unrealcrafter2
May 08, 2024, 07:33:31 PM
May 08, 2024, 01:31:28 PM
May 08, 2024, 06:41:48 AM
post Tesla coil amplitude dies after one corona discharge.
Simranjit
May 08, 2024, 05:42:07 AM
Michelle_
May 07, 2024, 06:46:16 PM
post What capacitor configuration to explode foil?
May 07, 2024, 03:51:32 PM
May 07, 2024, 03:20:23 PM
May 07, 2024, 11:00:00 AM
post Aluminum electrolytic capacitor ripple current issue
May 07, 2024, 06:07:48 AM
Michelle_
May 06, 2024, 04:43:19 PM
May 06, 2024, 04:26:44 PM
post Re: Feedback core for Tesla coil
May 06, 2024, 04:24:57 PM
May 06, 2024, 04:20:37 PM
post Feedback core for Tesla coil
Simranjit
May 06, 2024, 04:28:59 AM
May 06, 2024, 02:57:19 AM
May 06, 2024, 02:07:38 AM
Michelle_
May 05, 2024, 11:29:46 PM
May 05, 2024, 10:27:01 PM
May 05, 2024, 10:10:11 PM
Michelle_
May 05, 2024, 08:06:11 PM
post Re: Ferrite material for GDT SSTC/DRSSTC
May 05, 2024, 04:28:35 PM
Michelle_
May 05, 2024, 06:31:32 AM
post Re: Big Coil Build Log
May 05, 2024, 05:48:43 AM
thedark
May 05, 2024, 04:49:39 AM
thedark
May 05, 2024, 04:28:40 AM
May 05, 2024, 03:05:44 AM
May 05, 2024, 02:54:42 AM
post Ferrite material for GDT SSTC/DRSSTC
thedark
May 05, 2024, 02:21:54 AM
Michelle_
May 05, 2024, 01:46:25 AM
post Re: TVS diode vs RCD snubber for protect IGBT peak voltage
May 05, 2024, 12:26:38 AM
thedark
May 04, 2024, 10:48:10 PM
May 04, 2024, 10:40:15 PM
post TVS diode vs RCD snubber for protect IGBT peak voltage
thedark
May 04, 2024, 09:30:32 PM
May 04, 2024, 08:56:27 PM
May 04, 2024, 04:25:00 AM
May 04, 2024, 04:21:02 AM
May 04, 2024, 01:33:40 AM
May 04, 2024, 01:02:48 AM
May 03, 2024, 11:39:10 PM
May 03, 2024, 10:59:34 PM
markus
May 03, 2024, 09:59:22 AM
post What happened to ArcAttack?
rusirius
May 03, 2024, 02:34:36 AM
May 02, 2024, 05:18:56 AM
post Re: Adjustable High Voltage Electrostatic Precipitator Power Supply with 30KV 300W
dante
May 01, 2024, 10:06:40 PM
dante
May 01, 2024, 10:01:33 PM
post Re: Watercooling
May 01, 2024, 07:26:03 PM
Michelle_
May 01, 2024, 05:53:47 PM
May 01, 2024, 04:05:23 PM
post Re: X-ray generation from nixie bulbs?
May 01, 2024, 03:58:29 PM
May 01, 2024, 12:00:01 PM
