Author Topic: F***-ups varnishing secondary  (Read 2466 times)
Offline Zipdox
    • Zipdox
« on: March 17, 2020, 07:25:45 PM »
So I bought some PU varnish and did the first coat early this afternoon using a rotating LEGO contraption.
Since you're reading this post I just messed up doing the second coat. I should probably have waited longer for the first coat to dry. I also found out that the varnish is meant to be sprayed on...
RIP surface finish.
Tomorrow I'll see how it looks and hopefully a third coat will cover the roughness a bit.
Re: F***-ups varnishing secondary
« Reply #1 on: March 17, 2020, 07:35:31 PM »
You don't have to spray varnish. You can use a brush. I have always used a brush with excellent results. The trick is that you have to continuously rotate the secondary until each coat is dry. You can use a hair dryer to speed things up.
« Reply #2 on: March 17, 2020, 08:48:24 PM »
The best results come with more thin layers when using polyurethane varnish. Even letting it harden up enough to give it a light sanding between layers will give a more even result as well.
I have very bad experience with spray on varnish, I only use brush on as well.
Sand it down before your 3rd coating if you want to even the surface, just be careful not to damage the original coating of the wire!
Offline John123
  • All the gear, no idea. UK
« Reply #3 on: March 17, 2020, 09:57:50 PM »
Does that mean its doomed to arc over when powered up now?
Offline Zipdox
    • Zipdox
« Reply #4 on: March 18, 2020, 12:35:25 AM »
Probably not, I can add more varnish.
Offline Zipdox
    • Zipdox
« Reply #5 on: March 18, 2020, 12:36:33 AM »
I will see if sanding is required. And I'll use a hot air station to pop bubbles and hair dryer to make it cure faster.
Today at 04:11:53 AM
Today at 04:02:44 AM
Today at 03:35:52 AM
April 17, 2024, 11:54:05 PM
April 17, 2024, 11:37:16 PM
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
post Medium Drsstc question
