Author Topic: Setting OCD without blowing up transistors  (Read 4338 times)
« on: April 16, 2018, 12:36:29 AM »
My tesla coil has a full bridge of FGH60N60SMD IGBTs.  I am trying to get a handle on how to set the overcurrent without blowing up the transistors.
From what I have been told, these can handle about 300 A peak current.  My current sense transformer is 625:1 consisting of two 25:1 cascaded ferrite transformers.  The burden resistor I am using is 4.7 ohms.
For 300 A, assuming a 625:1 ratio, the current through the transformer on the secondary is 0.48 A.  This means I should set the voltage on the comparator to 2.25 V, correct?  Is there any correction for the forward drop of the Schottky diodes?   I am using a 625:1 transformer because I hope to add a second set of IGBTs to make the peak current 600 A.
Re: Setting OCD without blowing up transistors
« Reply #1 on: April 16, 2018, 02:00:36 AM »
I think Steve ward wrote in the drsstc log book about the voltage drop.
What I've been doing to set the ocd is set a voltage (let's say I want 300a ocd) at the comparator for a 200a limit. I then use a seperate ct connected to an oscilloscope and run the coil, slowly adjusting the voltage between runs until a 300a limit is achieved.
I've only done this method twice, and I'm also confident there's a better way of doing it. But it works for me.
« Reply #2 on: April 16, 2018, 10:18:16 AM »
You can ignore the forward drop of the diodes, they do not affect the current passed through the burden resistor (and thus voltage across it). The critical things are the CT ratio and the burden resistor value, and it sounds like you have the right idea about setting the voltage based on this.
I have also in the past set OCD with a measure & adjust strategy using a second CT, but either method should work. If you're aiming for a particular current then be a little conservative with the OCD setting, as the current can still rise for up to another half cycle after a trip. However the 300A goal you're after isn't likely critical, so it's reasonable to just set the correct voltage for a 300A trip and leave it be (unless the coil has a particularly low impedance primary tank, which I assume is not the case here).
post Re: DIY induction guns? (warning:long)
Today at 06:17:15 AM
Michelle_
Today at 05:46:07 AM
Today at 05:18:31 AM
Today at 04:34:52 AM
Today at 04:11:53 AM
Michelle_
Today at 04:02:44 AM
post Re: 100kHz CM300 gate resistor choice
Today at 03:35:52 AM
April 17, 2024, 11:54:05 PM
post 100kHz CM300 gate resistor choice
April 17, 2024, 11:37:16 PM
post Re: Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
post Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
Michelle_
April 16, 2024, 06:18:40 PM
Michelle_
April 16, 2024, 06:14:53 PM
unrealcrafter2
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
unrealcrafter2
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
Michelle_
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
Michelle_
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
Michelle_
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
Michelle_
April 10, 2024, 09:56:35 PM
unrealcrafter2
April 10, 2024, 08:59:26 PM
markus
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
post Medium Drsstc question
unrealcrafter2
April 10, 2024, 03:07:02 PM
Michelle_
April 10, 2024, 03:42:12 AM
Michelle_
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
markus
April 09, 2024, 06:08:53 PM
markus
April 09, 2024, 05:15:19 PM
Michelle_
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
