Author Topic: The dramatic difference between wet and dry sphere splashes  (Read 479 times)
Offline haversin
This phenomenon was first reported by A. M. Worthington in 1882.
« Last Edit: June 15, 2021, 06:25:43 PM by haversin »
Offline haversin
Re: The dramatic difference between wet and dry sphere splashes
« Reply #1 on: June 16, 2021, 05:40:40 PM »
As a follow up, here is a link to a great little paper on the current theory about the sphere splashes:
https://www.nature.com/articles/nphys545.pdf
Online davekni
« Reply #2 on: June 16, 2021, 08:00:50 PM »
That second paper makes sense.  Are you sure the "wet" and "dry" labels in the first video are correct.  I'd expect the opposite.  I'd expect a wet sphere to behave more hydrophilic and the dry sphere more hydrophobic.
« Reply #3 on: June 16, 2021, 08:54:32 PM »
I am not quite following your experiment here.
The paper you reference is talking about chemical processes to make different material spheres more hydrophilic or more hydrophobic, not the difference of a wet and dry sphere. But your experiment is to show that a wet sphere is the same as a chemically treated more hydrophilic sphere?
To improve your high speed video, you should get some 250W of LED lighting, I build one myself from 5x 50W LED COBs ( https://kaizerpowerelectronics.dk/general-electronics/250w-led-flood-light/ ), that I use for high speed video recording :) I could try to replicate your experiment with some more details on all the parts of your experiment. Its a little thin to just drop a video with no explanations...
Offline haversin
« Reply #4 on: June 17, 2021, 02:49:00 AM »
The labels are correct. I got the same results as A. M. Worthington. He talks about it here:
https://www.gutenberg.org/files/39831/39831-h/39831-h.htm#Page_73
I was first trying to replicate A. M. Worthington's observation.
The camera I'm using only gets 224 x 64 pixels at 1000 frames per second. I don't think more light will help much!  :-\
I thought I explained my setup pretty well, what part don't you understand?
« Last Edit: June 17, 2021, 02:50:49 AM by haversin »
« Reply #5 on: June 17, 2021, 12:42:03 PM »
I understand it now, it was just the missing link between your experiment being a replica of the subsequent experiment as A.M.Worthington describes as
"By wetting the surface of a smooth sphere we can always convert a smooth or "sheath" splash into a rough or "basket" splash. Thus when the ivory sphere (which when dry and well-polished gave, with a fall of 60 cm., the splash of Series XI, p. 97), was allowed to fall wet into the liquid, all other circumstances remaining the same, the splash of Series XIII, p. 103, was obtained, which is entirely different from the first. The wetting was effected by dipping the sphere into the bowl of milky water into which it was to fall, and then shaking off as much as possible of the adherent liquid, but in all cases the splash quickly became unsymmetrical, probably through the liquid, during the fall, drifting to one side of the sphere."
Just as Dave, I thought you replicated the hydrophilic/hydrophobic experiment, because from not knowing the papers beforehand, its counterintuitive that a wet sphere is going to act hydrophobic :)
post Re: Idea for QCW DRSSTC
post Re: Tesla plate
post Tesla plate
post Re: Large Rectifier Tube
Chrisader
post Idea for QCW DRSSTC
