Author Topic: sstc drive method  (Read 138 times)
sstc drive method
« on: January 04, 2018, 03:52:45 AM »
hey,
every now and then when i run my "big" sstc and occasionally blow some igbts, other times it works flawlessly. the problem is the breakout point and antenna needs to be positioned perfectly or else i start to have drive issues, essentially cutting out.
so it got me thinking.... would it just be better to convert it to a pll driver and still interrupt it using the enable pins of the ucc3732x drivers.
any help is highly appreciated.
cheers.
Offline Laci
Re: sstc drive method
« Reply #1 on: January 04, 2018, 09:31:19 AM »
I have a PLL driver circuit and it works great with my coil.The best thing about it in my opinion is that it can be audio modulated easily and makes great sounding CW arcs.This is the schematic: https://cdn.instructables.com/FXU/AK63/GRFN8J90/FXUAK63GRFN8J90.LARGE.gif
The IGBTs die due to overcurrent?I had the same problem with MOSFETs,but the problem was not the driving circuit,instead the long mains rectified power cable to the bridge.
« Reply #2 on: January 08, 2018, 06:07:22 AM »
Cheers for the reply Laci. I messed around with a pll circuit but it had troubles staying in tune for some reason. I ended up making a circuit (nothing new about the design) that I'll post up. It's basically Steve wards sstc 5 driver, the design with a 555 to start the oscillation.
Offline Laci
« Reply #3 on: January 08, 2018, 11:42:13 AM »
I am currently using the Kaizer SSTC I driver circuit and no need to start the oscillations.Maybe try a secondary base CT as feedback.
« Reply #4 on: January 08, 2018, 04:27:19 PM »
I am not sure that a PLL controlled driver would like to be cut on and off like that, I do not know, I never made a PLL controlled coil. But it needs a few cycles to lock on the frequency, so maybe it could get bad, hopefully someone knows better?
I also had stuttering behaviour on the SSTC when spark length became too long, like it can be seen in this video from 0:50
« Reply #5 on: January 10, 2018, 01:36:32 AM »
I've noticed your sstc ii had a metal enclosure, was it grounded?  My idea was to have the new driver enclosed for more reliable operation.
Laci, tbh I'm not sure why the driver is cutting out. I've tried both antenna and secondary CT feedback. I think it's due to emf or something along those lines.... But that's a big guess on my behalf
« Reply #6 on: January 10, 2018, 08:21:06 AM »
Yes the shielding was grounded and that is crucial! It is a strong EMF to be in for this little driver, when I did the audio modulation, I also had to shield the cable to the driver enclosure and all the way to keyboard, but even then it would still lock up from time to time.
The only thing getting outside the enclosure is the antenna and GDT wires.
post Re: Current transformers and burden resistors
Today at 12:52:55 AM
January 18, 2018, 10:43:38 AM
January 18, 2018, 12:26:48 AM
January 17, 2018, 05:10:20 PM
January 17, 2018, 04:46:32 PM
January 17, 2018, 02:24:49 PM
January 17, 2018, 02:13:41 PM
post Current transformers and burden resistors
January 17, 2018, 01:37:10 PM
post Re: Highway to DRSSTC
January 16, 2018, 07:42:32 PM
post Re: First DRSSTC
January 16, 2018, 07:28:44 PM
post Re: My first drsstc
January 16, 2018, 12:45:24 PM
January 16, 2018, 02:12:51 AM
Garyf
January 15, 2018, 06:20:00 PM
January 15, 2018, 03:51:57 AM
pawlox98
January 14, 2018, 04:40:30 PM
January 14, 2018, 01:20:37 PM
January 14, 2018, 01:10:37 PM
January 14, 2018, 11:11:40 AM
January 13, 2018, 09:27:22 PM
post Re: Geissler tube with a contact problem
[Transformer (iron core)]
Physikfan
January 13, 2018, 07:27:55 PM
post Re: Building the OpenTheremin V3
January 13, 2018, 02:56:15 PM
January 13, 2018, 07:50:32 AM
post Re: Best core for GDT and FBT
January 13, 2018, 06:57:34 AM
Garyf
January 12, 2018, 10:58:14 PM
January 12, 2018, 09:27:16 PM
January 12, 2018, 09:02:04 PM
January 12, 2018, 08:53:29 PM
January 12, 2018, 07:31:19 PM
January 12, 2018, 06:58:59 PM
post Re: My 160 (?)mm sstc
January 12, 2018, 01:17:52 PM
January 12, 2018, 10:19:20 AM
pawlox98
January 11, 2018, 10:07:19 PM
January 11, 2018, 09:55:31 PM
pawlox98
January 11, 2018, 08:27:35 PM
January 11, 2018, 03:17:44 PM
January 11, 2018, 01:12:18 PM
pawlox98
January 11, 2018, 12:40:05 PM
January 11, 2018, 12:16:47 PM
Garyf
January 11, 2018, 03:44:10 AM
Garyf
January 11, 2018, 03:36:40 AM
post First DRSSTC
pawlox98
January 11, 2018, 12:58:55 AM
January 11, 2018, 12:29:19 AM
January 11, 2018, 12:00:07 AM
January 10, 2018, 10:24:37 PM
post Re: Self-oscillating nano Tesla Coil (14.3 MHz)
tefatronix
January 10, 2018, 09:11:50 PM
January 10, 2018, 08:16:29 PM
NicholasTow
January 10, 2018, 06:02:54 PM
January 10, 2018, 05:12:25 PM
post My own SSTC Driver v1.0
January 10, 2018, 04:23:28 PM
January 10, 2018, 03:23:02 PM
